RTEMS  5.1
Epiphany Architecture Support. More...
struct  Context_Control
 Thread register context. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define CPU_ISR_PASSES_FRAME_POINTER   TRUE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   64
#define CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
#define CPU_MODES_INTERRUPT_MASK   0x00000001
#define _CPU_Context_Get_SP(_context)   (_context)->r[13]
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_STACK_MINIMUM_SIZE   4096
#define CPU_ALIGNMENT   8
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   8
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define _CPU_Initialize_vectors()
#define _CPU_ISR_Disable(_level)   _level = epiphany_interrupt_disable()
#define _CPU_ISR_Enable(_level)   epiphany_interrupt_enable( _level )
#define _CPU_ISR_Flash(_level)
#define EPIPHANY_GCC_RED_ZONE_SIZE   128
 Account for GCC red-zone. More...
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) )
#define _CPU_Fatal_halt(_source, _error)
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_SIZEOF_POINTER   4
#define CPU_EXCEPTION_FRAME_SIZE   260
#define CPU_MAXIMUM_PROCESSORS   32
#define CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff))
#define CPU_PER_CPU_CONTROL_SIZE   0
typedef Context_Control CPU_Interrupt_frame
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled (uint32_t level)
void _CPU_ISR_Set_level (uint32_t level)
 Sets the hardware interrupt level by the level value. More...
uint32_t _CPU_ISR_Get_level (void)
void _CPU_Context_Initialize (Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context. More...
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
void _CPU_Initialize (void)
 CPU initialization. More...
void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN
void _CPU_Context_save_fp (void **fp_context_ptr)
void _CPU_Context_restore_fp (void **fp_context_ptr)
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
RTEMS_INLINE_ROUTINE void _CPU_Context_volatile_clobber (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Context_validate (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal (void)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation (void)
◆ _CPU_Fatal_halt
#define _CPU_Fatal_halt (   _source,
  _error
Value:
printk("Fatal Error %d.%" PRIu32 " Halted\n",_source, _error); \
asm("trap 3" :: "r" (_error)); \
for(;;)
int printk(const char *fmt,...) RTEMS_PRINTFLIKE(1
Kernel Print.
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _level)
Value:
do{ \
if ( (_level & 0x2) != 0 ) \
_CPU_ISR_Enable( _level ); \
epiphany_interrupt_disable(); \
} while(0)
◆ CPU_SIZEOF_POINTER
Size of a pointer.
This must be an integer literal that can be used by the assembler. This value will be used to calculate offsets of structure members. These offsets will be used in assembler code.
◆ EPIPHANY_GCC_RED_ZONE_SIZE
The following macro is used when initializing task's stack to account for GCC red-zone.
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
◆ _CPU_Context_Initialize()
void _CPU_Context_Initialize ( Context_Control *  context,
void *  stack_area_begin,
uint32_t  new_level,
void(*)(void)  entry_point,
bool  is_fp,
void *  tls_area
The following steps are performed:
  • setting a starting address
  • preparing the stack
  • preparing the stack and frame pointers
  • setting the proper interrupt level in the context
Parameters
[in]contextpoints to the context area
[in]stack_area_beginis the low address of the allocated stack area
[in]stack_area_sizeis the size of the stack area in bytes
[in]new_levelis the interrupt level for the task
[in]entry_pointis the task's entry point
[in]is_fpis set to true if the task is a floating point task
[in]tls_areais the thread-local storage (TLS) area
◆ _CPU_Context_restore()
void _CPU_Context_restore ( Context_Control *  new_context)
This routine is generally used only to restart self in an efficient manner. It may simply be a label in _CPU_Context_switch.
Parameters
[in]new_contextpoints to the context to be restored.
Note
May be unnecessary to reload some registers.
Port Specific Information:
XXX document implementation including references if appropriate
◆ _CPU_Context_switch()
void _CPU_Context_switch ( Context_Control *  run,
Context_Control *  heir
CPU switch context.
This routine switches from the run context to the heir context.
Parameters
[in]runpoints to the context of the currently executing task
[in]heirpoints to the context of the heir task
◆ _CPU_Exception_frame_print()
void _CPU_Exception_frame_print ( const CPU_Exception_frame *  frame)
See also
rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
◆ _CPU_Initialize()
void _CPU_Initialize ( void  )
CPU initialization.
CPU initialize. This routine performs CPU dependent initialization.
CPU initialization.
◆ _CPU_ISR_Get_level()
uint32_t _CPU_ISR_Get_level ( void  )
Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode.
Note
This routine usually must be implemented as a subroutine.
◆ _CPU_ISR_Set_level()
void _CPU_ISR_Set_level ( uint32_t  new_level)
Parameters
[in]levelfor or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15.
See also
OpenRISC architecture manual.
