RTEMS
5.1
V850 Set up Basic CPU Dependency Settings Based on Compiler Settings. More...
| #define | CPU_MODEL_NAME "v850" |
| #define | V850_HAS_FPU 0 |
| #define | V850_HAS_BYTE_SWAP_INSTRUCTION 0 |
| #define | CPU_NAME "v850 CPU" |
| #define | v850_set_psw(_psw) __asm__ __volatile__( "ldsr %0, psw" : : "r" (_psw) ) |
| #define | v850_get_psw(_psw) __asm__ __volatile__( "stsr psw, %0" : "=&r" (_psw) ) |
| #define | V850_PSW_ZERO_MASK 0x01 |
| #define | V850_PSW_IS_ZERO 0x01 |
| #define | V850_PSW_IS_NOT 0x00 |
| #define | V850_PSW_SIGN_MASK 0x02 |
| #define | V850_PSW_SIGN_IS_NEGATIVE 0x02 |
| #define | V850_PSW_SIGN_IS_ZERO_OR_POSITIVE 0x00 |
| #define | V850_PSW_OVERFLOW_MASK 0x02 |
| #define | V850_PSW_OVERFLOW_OCCURRED 0x02 |
| #define | V850_PSW_OVERFLOW_DID_NOT_OCCUR 0x00 |
| #define | V850_PSW_CARRY_OR_BORROW_MASK 0x04 |
| #define | V850_PSW_CARRY_OR_BORROW_OCCURRED 0x04 |
| #define | V850_PSW_CARRY_OR_BORROW_DID_NOT_OCCUR 0x00 |
| #define | V850_PSW_SATURATION_MASK 0x10 |
| #define | V850_PSW_SATURATION_OCCURRED 0x10 |
| #define | V850_PSW_SATURATION_DID_NOT_OCCUR 0x00 |
| #define | V850_PSW_INTERRUPT_DISABLE_MASK 0x20 |
| #define | V850_PSW_INTERRUPT_DISABLE 0x20 |
| #define | V850_PSW_INTERRUPT_ENABLE 0x00 |
| #define | V850_PSW_EXCEPTION_IN_PROCESS_MASK 0x40 |
| #define | V850_PSW_EXCEPTION_IN_PROCESS 0x40 |
| #define | V850_PSW_EXCEPTION_NOT_IN_PROCESS 0x00 |
| #define | V850_PSW_NMI_IN_PROCESS_MASK 0x80 |
| #define | V850_PSW_NMI_IN_PROCESS 0x80 |
| #define | V850_PSW_NMI_NOT_IN_PROCESS 0x00 |
This file sets up basic CPU dependency settings based on compiler settings. For example, it can determine if floating point is available. This particular implementation is specified to the Renesas v850 port.
1.8.15
