RTEMS  5.1
rtems_stdio_redirect Struct Reference
volatile uint32_t state
rtems_id reader
rtems_mutex lock
int fd
int fd_dup
int pipe [2]
char * input
ssize_t input_size
char * buffer
ssize_t buffer_size
ssize_t in
bool full
bool echo
rtems_stdio_redirect_handler handler
Field Documentation
◆ buffer
char* rtems_stdio_redirect::buffer
Captured redirected data.
◆ buffer_size
ssize_t rtems_stdio_redirect::buffer_size
Capture buffer size.
◆ echo
bool rtems_stdio_redirect::echo
Echo the data out the existing path.
◆ fd
int rtems_stdio_redirect::fd
The file descriptor to redirect.
◆ fd_dup
int rtems_stdio_redirect::fd_dup
Duplicated fd to write to.
◆ full
bool rtems_stdio_redirect::full
The buffer is full.
◆ handler
rtems_stdio_redirect_handler rtems_stdio_redirect::handler
Redirected data handler.
◆ in
ssize_t rtems_stdio_redirect::in
Buffer in index.
◆ input
char* rtems_stdio_redirect::input
The input buffer the reader uses.
◆ input_size
ssize_t rtems_stdio_redirect::input_size
The input buffer size.
◆ lock
rtems_mutex rtems_stdio_redirect::lock
Lock for this struct.
◆ pipe
int rtems_stdio_redirect::pipe[2]
The pipe to the reader thread.
◆ reader
rtems_id rtems_stdio_redirect::reader
The reader thread.
◆ state
volatile uint32_t rtems_stdio_redirect::state
The state.
