RTEMS  5.1
stdio-redirect.h
1 /*
2  * Copyright (C) 2014 Chris Johns (chrisj@rtems.org)
3  *
4  * The license and distribution terms for this file may be
5  * found in the file LICENSE in this distribution.
6  *
7  * This software with is provided ``as is'' and with NO WARRANTY.
8  */
9
10 /*
11  * @brief Redirect an stdio file decriptor.
12  *
13  * The is a helper module of code design to redirect an stdio file
14  * descriptor. You can optionally have the data buffered and/or you can provide
15  * a handler function that is called when data arrives.
16  *
17  * The module uses standard POSIX calls to implement the redirection and if the
18  * threading was POSIX based the code would be portable. Currently the code
19  * uses RTEMS threads.
20  *
21  * Redirecting stderr and stdout is useful in embedded system because you can
22  * transport the output off your device or create a web interface that can
23  * display the output. This can be a very powerful diagnostic and support tool.
24  *
25  * The implementation does:
26  *
27  * 1. Duplicate the file descriptor (fd) to redirect using the dup call. The
28  * duplicated desciptor is used to echo the output out the existing path.
29  *
30  * 2. Create a pipe using the pipe call.
31  *
32  * 3. Duplicate the pipe's writer file descriptor to user's file
33  * descriptor. This results in any writes to the user's fd being written to
34  * the pipe.
35  *
36  * 4. Create a reader task that blocks on the pipe. It optionally calls a
37  * handler and if configured buffers the data.
38  */
39
40 #if !defined(RTEMS_STDIO_REDIRECT_H)
41 #define RTEMS_STDIO_REDIRECT_H
42
43 #include <stdbool.h>
44 #include <rtems.h>
45 #include <rtems/thread.h>
46
47 #ifdef __cplusplus
48 extern "C" {
49 #endif /* __cplusplus */
50
51 /*
52  * Handler called whenever redirected data arrives.
53  *
54  * @param buffer The data.
55  * @param length The amount of data in the buffer.
56  */
57 typedef void (*rtems_stdio_redirect_handler)(const char* buffer,
58  ssize_t length);
59
60 /*
61  * Redirector data.
62  */
63 typedef struct
64 {
65  volatile uint32_t state;
67  rtems_mutex lock;
68  int fd;
69  int fd_dup;
70  int pipe[2];
71  char* input;
72  ssize_t input_size;
73  char* buffer;
74  ssize_t buffer_size;
75  ssize_t in;
76  bool full;
77  bool echo;
78  rtems_stdio_redirect_handler handler;
80
81 /*
82  * Open a redirector returning the handle to it.
83  *
84  * @param fd The file descriptor to redirect.
85  * @param priority The priority of the reader thread.
86  */
87 rtems_stdio_redirect* rtems_stdio_redirect_open(int fd,
88  rtems_task_priority priority,
89  size_t stack_size,
90  ssize_t input_size,
91  ssize_t buffer_size,
92  bool echo,
93  rtems_stdio_redirect_handler handler);
94
95 /*
96  * Close the redirector.
97  */
98 void rtems_stdio_redirect_close(rtems_stdio_redirect* sr);
99
100 /*
101  * Get data from the capture buffer. Data read is removed from the buffer.
102  *
103  * @param sr The stdio redirection handle.
104  * @param buffer The buffer data is written into.
105  * @param length The size of the buffer.
106  * @return ssize_t The amount of data written and -1 or an error.
107  */
108 ssize_t rtems_stdio_redirect_read(rtems_stdio_redirect* sr,
109  char* buffer,
110  ssize_t length);
111
112 #ifdef __cplusplus
113 }
114 #endif /* __cplusplus */
115
116 #endif
ssize_t in
Definition: stdio-redirect.h:75
char * input
Definition: stdio-redirect.h:71
char * buffer
Definition: stdio-redirect.h:73
int fd
Definition: stdio-redirect.h:68
rtems_mutex lock
Definition: stdio-redirect.h:67
bool echo
Definition: stdio-redirect.h:77
ssize_t buffer_size
Definition: stdio-redirect.h:74
ssize_t input_size
Definition: stdio-redirect.h:72
Definition: stdio-redirect.h:78
int fd_dup
Definition: stdio-redirect.h:69
bool full
Definition: stdio-redirect.h:76
Definition: stdio-redirect.h:65
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: stdio-redirect.h:63
rtems_id reader
Definition: stdio-redirect.h:66
uint32_t rtems_task_priority
Definition: tasks.h:55
