RTEMS  5.1
pci_bus Struct Reference
struct pci_bus * parent
struct pci_bus * children
struct pci_bus * next
struct pci_dev * self
struct pci_dev * devices
void * sysdata
struct proc_dir_entry * procdir
unsigned char number
unsigned char primary
unsigned char secondary
unsigned char subordinate
struct pci_dev dev
struct pci_dev * devs
unsigned int flags
int num
int pri
int sord
The documentation for this struct was generated from the following files:
