27 extern int pci_bus_count(
void);
    32 extern uint32_t pci_invalid_address;
    36     PCI_CONFIG_LIB_NONE = 0,
    37     PCI_CONFIG_LIB_AUTO = 1,
    38     PCI_CONFIG_LIB_STATIC = 2,
    39     PCI_CONFIG_LIB_READ = 3,
    40     PCI_CONFIG_LIB_PERIPHERAL = 4,
    42 extern const int pci_config_lib_type;
    49 extern int (*pci_config_lib_init)(void);
    50 extern void (*pci_config_lib_register)(
void *
config);
    57 extern int pci_config_init(
void);
    62 extern void pci_config_register(
void *
config);
    68 extern void pci_cfg_print(
void);
    78 #define SEARCH_CHILDREN 0       79 #define SEARCH_DEPTH 1          94 extern int pci_for_each_child(
    96     int (*func)(
struct pci_dev *,
void *arg),
   112 extern int pci_for_each_dev(
   113     int (*func)(
struct pci_dev *,
void *arg),
   123 extern int pci_find_dev(uint16_t ven, uint16_t dev,
int index,
   132 extern int pci_get_dev(pci_dev_t pcidev,
struct pci_dev **ppdev);
   136 #define PCI_RES_MEMIO 2   137 #define PCI_RES_MEM_PREFETCH 1   138 #define PCI_RES_MEM (PCI_RES_MEMIO | PCI_RES_MEM_PREFETCH)   139 #define PCI_RES_TYPE_MASK 0x3   140 #define PCI_RES_IO32 0x08   141 #define PCI_RES_FAIL 0x10    160 #define RES2DEV(res) ((struct pci_dev *) \   161     ((uintptr_t)res - (uintptr_t)(res->bar * (sizeof(struct pci_res)))))   164 #define PCI_DEV_BRIDGE    0x01     165 #define PCI_DEV_RES_FAIL  0x02     168 #define PCI_BUS_IO        0x01     169 #define PCI_BUS_MEMIO     0x02     170 #define PCI_BUS_MEM       0x04     171 #define PCI_BUS_IO32      0x08     173 #define BRIDGE_RES_COUNT 2    174 #define BUS_RES_START BRIDGE_RES_COUNT   200     BRIDGE_RES_MEMIO = 3,
   202     BRIDGE_RES_UNUSED1 = 5,
   207 #define DEV_RES_CNT (DEV_RES_ROM + 1)   211     struct pci_res  resources[DEV_RES_CNT];
   238 #if defined(PCI_CFG_AUTO_LIB)   249 #include <pci/cfg_auto.h>   250 #include <pci/cfg_static.h>   251 #include <pci/cfg_read.h>   252 #include <pci/cfg_peripheral.h> Definition: deflate.c:115
Definition: rtemscompat1.h:15
