unsigned char  | chipID |
unsigned char  | chipREV |
unsigned char  | gen_control |
unsigned char  | vector_base |
unsigned long  | timer_cmp_1 |
unsigned long  | timer_cnt_1 |
unsigned long  | timer_cmp_2 |
unsigned long  | timer_cnt_2 |
unsigned char  | LSB_prescaler_count |
unsigned char  | prescaler_clock_adjust |
unsigned char  | time_ctl_2 |
unsigned char  | time_ctl_1 |
unsigned char  | time_int_ctl_4 |
unsigned char  | time_int_ctl_3 |
unsigned char  | time_int_ctl_2 |
unsigned char  | time_int_ctl_1 |
unsigned char  | dram_err_int_ctl |
unsigned char  | SCC_int_ctl |
unsigned char  | time_ctl_4 |
unsigned char  | time_ctl_3 |
unsigned short  | DRAM_space_base |
unsigned short  | SRAM_space_base |
unsigned char  | DRAM_size |
unsigned char  | DRAM_SRAM_opt |
unsigned char  | SRAM_size |
unsigned char  | reserved |
unsigned char  | LANC_error |
unsigned char  | reserved1 |
unsigned char  | LANC_int_ctl |
unsigned char  | LANC_berr_ctl |
unsigned char  | SCSI_error |
unsigned char  | general_inputs |
unsigned char  | MVME_162_version |
unsigned char  | SCSI_int_ctl |
unsigned long  | timer_cmp_3 |
unsigned long  | timer_cnt_3 |
unsigned long  | timer_cmp_4 |
unsigned long  | timer_cnt_4 |
unsigned char  | bus_clk |
unsigned char  | PROM_acc_time_ctl |
unsigned char  | FLASH_acc_time_ctl |
unsigned char  | ABORT_int_ctl |
unsigned char  | RESET_ctl |
unsigned char  | watchdog_timer_ctl |
unsigned char  | acc_watchdog_time_base_sel |
unsigned char  | reserved2 |
unsigned char  | DRAM_ctl |
unsigned char  | reserved4 |
unsigned char  | MPU_status |
unsigned char  | reserved3 |
unsigned long  | prescaler_count |
- bsps/m68k/mvme162/include/bsp.h
