29 #ifndef LIBBSP_M68K_MVME162_BSP_H    30 #define LIBBSP_M68K_MVME162_BSP_H    55 typedef volatile struct {
    58   unsigned char     chipREV;
    59   unsigned char     gen_control;
    60   unsigned char     vector_base;
    62   unsigned long     timer_cmp_1;
    63   unsigned long     timer_cnt_1;
    64   unsigned long     timer_cmp_2;
    65   unsigned long     timer_cnt_2;
    67   unsigned char     LSB_prescaler_count;
    68   unsigned char     prescaler_clock_adjust;
    69   unsigned char     time_ctl_2;
    70   unsigned char     time_ctl_1;
    72   unsigned char     time_int_ctl_4;
    73   unsigned char     time_int_ctl_3;
    74   unsigned char     time_int_ctl_2;
    75   unsigned char     time_int_ctl_1;
    77   unsigned char     dram_err_int_ctl;
    78   unsigned char     SCC_int_ctl;
    79   unsigned char     time_ctl_4;
    80   unsigned char     time_ctl_3;
    82   unsigned short    DRAM_space_base;
    83   unsigned short    SRAM_space_base;
    85   unsigned char     DRAM_size;
    86   unsigned char     DRAM_SRAM_opt;
    87   unsigned char     SRAM_size;
    88   unsigned char     reserved;
    90   unsigned char     LANC_error;
    91   unsigned char     reserved1;
    92   unsigned char     LANC_int_ctl;
    93   unsigned char     LANC_berr_ctl;
    95   unsigned char     SCSI_error;
    96   unsigned char     general_inputs;
    97   unsigned char     MVME_162_version;
    98   unsigned char     SCSI_int_ctl;
   100   unsigned long     timer_cmp_3;
   101   unsigned long     timer_cnt_3;
   102   unsigned long     timer_cmp_4;
   103   unsigned long     timer_cnt_4;
   105   unsigned char     bus_clk;
   106   unsigned char     PROM_acc_time_ctl;
   107   unsigned char     FLASH_acc_time_ctl;
   108   unsigned char     ABORT_int_ctl;
   110   unsigned char     RESET_ctl;
   111   unsigned char     watchdog_timer_ctl;
   112   unsigned char     acc_watchdog_time_base_sel;
   113   unsigned char     reserved2;
   115   unsigned char     DRAM_ctl;
   116   unsigned char     reserved4;
   117   unsigned char     MPU_status;
   118   unsigned char     reserved3;
   120   unsigned long     prescaler_count;
   124 #define mcchip      ((mcchip_regs * const) 0xFFF42000)   145 extern bool char_ready(
int port,
char *ch);
   146 extern char char_wait(
int port);
   147 extern void char_put(
int port,
char ch);
   149 #define TX_BUFFER_EMPTY   0x04   150 #define RX_DATA_AVAILABLE 0x01   151 #define SCC_VECTOR        0x40   153 typedef volatile struct {
   155   volatile unsigned char          csr;
   157   volatile unsigned char          buf;
   160 #define scc       ((scc_regs * const) 0xFFF45000)   162 #define ZWRITE0(port, v)  (scc[port].csr = (unsigned char)(v))   163 #define ZREAD0(port)  (scc[port].csr)   165 #define ZREAD(port, n)  (ZWRITE0(port, n), (scc[port].csr))   166 #define ZREADD(port)  (scc[port].csr=0x08, scc[port].csr )   168 #define ZWRITE(port, n, v) (ZWRITE0(port, n), ZWRITE0(port, v))   169 #define ZWRITED(port, v)  (scc[port].csr = 0x08, \   170                            scc[port].csr = (unsigned char)(v))   178 #define EXTERN extern   200 #define MOT_162BUG_VEC_ADDRESS  0x00000000   202 extern rtems_isr_entry M68Kvec[];
   207   rtems_isr_entry     handler,
   215 bool char_ready(
int port,
char *ch);
 rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
