MVME162 Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | mcchip   ((mcchip_regs * const) 0xFFF42000) |
#define  | TX_BUFFER_EMPTY   0x04 |
#define  | RX_DATA_AVAILABLE   0x01 |
#define  | SCC_VECTOR   0x40 |
#define  | scc   ((scc_regs * const) 0xFFF45000) |
#define  | ZWRITE0(port,  v)   (scc[port].csr = (unsigned char)(v)) |
#define  | ZREAD0(port)   (scc[port].csr) |
#define  | ZREAD(port,  n)   (ZWRITE0(port, n), (scc[port].csr)) |
#define  | ZREADD(port)   (scc[port].csr=0x08, scc[port].csr ) |
#define  | ZWRITE(port,  n,  v)   (ZWRITE0(port, n), ZWRITE0(port, v)) |
| #define  | ZWRITED(port,  v) |
#define  | EXTERN   extern |
#define  | MOT_162BUG_VEC_ADDRESS   0x00000000 |
#define  | memc040_1   ((memc040_regs * const) 0xFFF43000) |
#define  | memc040_2   ((memc040_regs * const) 0xFFF43100) |
#define  | cd2401   ((cd2401_regs * const) 0xFFF45000) |
#define  | CD2401_CLK_RATE   20000000 |
bool  | char_ready (int port, char *ch) |
char  | char_wait (int port) |
void  | char_put (int port, char ch) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
rtems_isr_entry  | M68Kvec [] |
void *  | M68Kvec [] |
MVME167 Board Support Package.
◆ ZWRITED
          | #define ZWRITED |
          port,  |
          v  |
Value:                           scc[port].csr = (
unsigned char)(
v))
Definition: 8xx_immap.h:312
unsigned v
Definition: tte.h:73
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
