RTEMS
5.1
Structure type to access the Trace Port Interface Register (TPI). More...
#include <core_cm7.h>
Data Fields | |
__IOM uint32_t | SSPSR |
__IOM uint32_t | CSPSR |
uint32_t | RESERVED0 [2U] |
__IOM uint32_t | ACPR |
uint32_t | RESERVED1 [55U] |
__IOM uint32_t | SPPR |
uint32_t | RESERVED2 [131U] |
__IM uint32_t | FFSR |
__IOM uint32_t | FFCR |
__IM uint32_t | FSCR |
uint32_t | RESERVED3 [759U] |
__IM uint32_t | TRIGGER |
__IM uint32_t | FIFO0 |
__IM uint32_t | ITATBCTR2 |
uint32_t | RESERVED4 [1U] |
__IM uint32_t | ITATBCTR0 |
__IM uint32_t | FIFO1 |
__IOM uint32_t | ITCTRL |
uint32_t | RESERVED5 [39U] |
__IOM uint32_t | CLAIMSET |
__IOM uint32_t | CLAIMCLR |
uint32_t | RESERVED7 [8U] |
__IM uint32_t | DEVID |
__IM uint32_t | DEVTYPE |
__IOM uint32_t TPI_Type::ACPR |
Offset: 0x010 (R/W) Asynchronous Clock Prescaler Register
__IOM uint32_t TPI_Type::CLAIMCLR |
Offset: 0xFA4 (R/W) Claim tag clear
__IOM uint32_t TPI_Type::CLAIMSET |
Offset: 0xFA0 (R/W) Claim tag set
__IOM uint32_t TPI_Type::CSPSR |
Offset: 0x004 (R/W) Current Parallel Port Size Register
__IM uint32_t TPI_Type::DEVID |
Offset: 0xFC8 (R/ ) TPIU_DEVID
__IM uint32_t TPI_Type::DEVTYPE |
Offset: 0xFCC (R/ ) TPIU_DEVTYPE
__IOM uint32_t TPI_Type::FFCR |
Offset: 0x304 (R/W) Formatter and Flush Control Register
__IM uint32_t TPI_Type::FFSR |
Offset: 0x300 (R/ ) Formatter and Flush Status Register
__IM uint32_t TPI_Type::FIFO0 |
Offset: 0xEEC (R/ ) Integration ETM Data
__IM uint32_t TPI_Type::FIFO1 |
Offset: 0xEFC (R/ ) Integration ITM Data
__IM uint32_t TPI_Type::FSCR |
Offset: 0x308 (R/ ) Formatter Synchronization Counter Register
__IM uint32_t TPI_Type::ITATBCTR0 |
Offset: 0xEF8 (R/ ) ITATBCTR0
__IM uint32_t TPI_Type::ITATBCTR2 |
Offset: 0xEF0 (R/ ) ITATBCTR2
__IOM uint32_t TPI_Type::ITCTRL |
Offset: 0xF00 (R/W) Integration Mode Control
__IOM uint32_t TPI_Type::SPPR |
Offset: 0x0F0 (R/W) Selected Pin Protocol Register
__IOM uint32_t TPI_Type::SSPSR |
Offset: 0x000 (R/ ) Supported Parallel Port Size Register
__IM uint32_t TPI_Type::TRIGGER |
Offset: 0xEE8 (R/ ) TRIGGER
