RTEMS
5.1
Structure type to access the Data Watchpoint and Trace Register (DWT). More...
#include <core_cm7.h>
Data Fields | |
__IOM uint32_t | CTRL |
__IOM uint32_t | CYCCNT |
__IOM uint32_t | CPICNT |
__IOM uint32_t | EXCCNT |
__IOM uint32_t | SLEEPCNT |
__IOM uint32_t | LSUCNT |
__IOM uint32_t | FOLDCNT |
__IM uint32_t | PCSR |
__IOM uint32_t | COMP0 |
__IOM uint32_t | MASK0 |
__IOM uint32_t | FUNCTION0 |
uint32_t | RESERVED0 [1U] |
__IOM uint32_t | COMP1 |
__IOM uint32_t | MASK1 |
__IOM uint32_t | FUNCTION1 |
uint32_t | RESERVED1 [1U] |
__IOM uint32_t | COMP2 |
__IOM uint32_t | MASK2 |
__IOM uint32_t | FUNCTION2 |
uint32_t | RESERVED2 [1U] |
__IOM uint32_t | COMP3 |
__IOM uint32_t | MASK3 |
__IOM uint32_t | FUNCTION3 |
uint32_t | RESERVED3 [981U] |
__OM uint32_t | LAR |
__IM uint32_t | LSR |
__IOM uint32_t DWT_Type::COMP0 |
Offset: 0x020 (R/W) Comparator Register 0
__IOM uint32_t DWT_Type::COMP1 |
Offset: 0x030 (R/W) Comparator Register 1
__IOM uint32_t DWT_Type::COMP2 |
Offset: 0x040 (R/W) Comparator Register 2
__IOM uint32_t DWT_Type::COMP3 |
Offset: 0x050 (R/W) Comparator Register 3
__IOM uint32_t DWT_Type::CPICNT |
Offset: 0x008 (R/W) CPI Count Register
__IOM uint32_t DWT_Type::CTRL |
Offset: 0x000 (R/W) Control Register
__IOM uint32_t DWT_Type::CYCCNT |
Offset: 0x004 (R/W) Cycle Count Register
__IOM uint32_t DWT_Type::EXCCNT |
Offset: 0x00C (R/W) Exception Overhead Count Register
__IOM uint32_t DWT_Type::FOLDCNT |
Offset: 0x018 (R/W) Folded-instruction Count Register
__IOM uint32_t DWT_Type::FUNCTION0 |
Offset: 0x028 (R/W) Function Register 0
__IOM uint32_t DWT_Type::FUNCTION1 |
Offset: 0x038 (R/W) Function Register 1
__IOM uint32_t DWT_Type::FUNCTION2 |
Offset: 0x048 (R/W) Function Register 2
__IOM uint32_t DWT_Type::FUNCTION3 |
Offset: 0x058 (R/W) Function Register 3
__OM uint32_t DWT_Type::LAR |
Offset: 0xFB0 ( W) Lock Access Register
__IM uint32_t DWT_Type::LSR |
Offset: 0xFB4 (R ) Lock Status Register
__IOM uint32_t DWT_Type::LSUCNT |
Offset: 0x014 (R/W) LSU Count Register
__IOM uint32_t DWT_Type::MASK0 |
Offset: 0x024 (R/W) Mask Register 0
__IOM uint32_t DWT_Type::MASK1 |
Offset: 0x034 (R/W) Mask Register 1
__IOM uint32_t DWT_Type::MASK2 |
Offset: 0x044 (R/W) Mask Register 2
__IOM uint32_t DWT_Type::MASK3 |
Offset: 0x054 (R/W) Mask Register 3
__IM uint32_t DWT_Type::PCSR |
Offset: 0x01C (R/ ) Program Counter Sample Register
__IOM uint32_t DWT_Type::SLEEPCNT |
Offset: 0x010 (R/W) Sleep Count Register
