24 #ifndef _RTEMS_SCORE_CPU_H    25 #define _RTEMS_SCORE_CPU_H    47 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE    55 #define CPU_ISR_PASSES_FRAME_POINTER FALSE    64 #if ( SPARC_HAS_FPU == 1 )    65 #define CPU_HARDWARE_FP     TRUE    67 #define CPU_HARDWARE_FP     FALSE    69 #define CPU_SOFTWARE_FP     FALSE    78 #define CPU_ALL_TASKS_ARE_FP     FALSE    88 #define CPU_IDLE_TASK_IS_FP      FALSE   105 #define CPU_USE_DEFERRED_FP_SWITCH       TRUE   107 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE   119 #define CPU_STACK_GROWS_UP               FALSE   122 #define CPU_CACHE_LINE_BYTES 32   138 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( 16 )   148 #define CPU_MODES_INTERRUPT_MASK   0x0000000F   150 #define CPU_MAXIMUM_PROCESSORS 32   178   void       *structure_return_address;
   194 #define CPU_STACK_FRAME_L0_OFFSET             0x00   195 #define CPU_STACK_FRAME_L1_OFFSET             0x08   196 #define CPU_STACK_FRAME_L2_OFFSET             0x10   197 #define CPU_STACK_FRAME_L3_OFFSET             0x18   198 #define CPU_STACK_FRAME_L4_OFFSET             0x20   199 #define CPU_STACK_FRAME_L5_OFFSET             0x28   200 #define CPU_STACK_FRAME_L6_OFFSET             0x30   201 #define CPU_STACK_FRAME_L7_OFFSET             0x38   202 #define CPU_STACK_FRAME_I0_OFFSET             0x40   203 #define CPU_STACK_FRAME_I1_OFFSET             0x48   204 #define CPU_STACK_FRAME_I2_OFFSET             0x50   205 #define CPU_STACK_FRAME_I3_OFFSET             0x58   206 #define CPU_STACK_FRAME_I4_OFFSET             0x60   207 #define CPU_STACK_FRAME_I5_OFFSET             0x68   208 #define CPU_STACK_FRAME_I6_FP_OFFSET          0x70   209 #define CPU_STACK_FRAME_I7_OFFSET             0x78   210 #define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET   0x80   211 #define CPU_STACK_FRAME_SAVED_ARG0_OFFSET     0x88   212 #define CPU_STACK_FRAME_SAVED_ARG1_OFFSET     0x90   213 #define CPU_STACK_FRAME_SAVED_ARG2_OFFSET     0x98   214 #define CPU_STACK_FRAME_SAVED_ARG3_OFFSET     0xA0   215 #define CPU_STACK_FRAME_SAVED_ARG4_OFFSET     0xA8   216 #define CPU_STACK_FRAME_SAVED_ARG5_OFFSET     0xB0   217 #define CPU_STACK_FRAME_PAD0_OFFSET           0xB8   219 #define SPARC64_MINIMUM_STACK_FRAME_SIZE          0xC0   277     uint32_t   isr_dispatch_disable;
   281 #define _CPU_Context_Get_SP( _context ) \   290 #define G1_OFFSET    0x00   291 #define G2_OFFSET    0x08   292 #define G3_OFFSET    0x10   293 #define G4_OFFSET    0x18   294 #define G5_OFFSET    0x20   295 #define G6_OFFSET    0x28   296 #define G7_OFFSET    0x30   298 #define L0_OFFSET    0x38   299 #define L1_OFFSET    0x40   300 #define L2_OFFSET    0x48   301 #define L3_OFFSET    0x50   302 #define L4_OFFSET    0x58   303 #define L5_OFFSET    0x60   304 #define L6_OFFSET    0x68   305 #define L7_OFFSET    0x70   307 #define I0_OFFSET    0x78   308 #define I1_OFFSET    0x80   309 #define I2_OFFSET    0x88   310 #define I3_OFFSET    0x90   311 #define I4_OFFSET    0x98   312 #define I5_OFFSET    0xA0   313 #define I6_FP_OFFSET    0xA8   314 #define I7_OFFSET 0xB0   316 #define O0_OFFSET    0xB8   317 #define O1_OFFSET    0xC0   318 #define O2_OFFSET    0xC8   319 #define O3_OFFSET    0xD0   320 #define O4_OFFSET    0xD8   321 #define O5_OFFSET    0xE0   322 #define O6_SP_OFFSET    0xE8   323 #define O7_OFFSET 0xF0   325 #define ISR_DISPATCH_DISABLE_STACK_OFFSET 0xF8   326 #define ISR_PAD_OFFSET 0xFC   376 #define FO_OFFSET    0x00   377 #define F2_OFFSET    0x08   378 #define F4_OFFSET    0x10   379 #define F6_OFFSET    0x18   380 #define F8_OFFSET    0x20   381 #define F1O_OFFSET   0x28   382 #define F12_OFFSET   0x30   383 #define F14_OFFSET   0x38   384 #define F16_OFFSET   0x40   385 #define F18_OFFSET   0x48   386 #define F2O_OFFSET   0x50   387 #define F22_OFFSET   0x58   388 #define F24_OFFSET   0x60   389 #define F26_OFFSET   0x68   390 #define F28_OFFSET   0x70   391 #define F3O_OFFSET   0x78   392 #define F32_OFFSET   0x80   393 #define F34_OFFSET   0x88   394 #define F36_OFFSET   0x90   395 #define F38_OFFSET   0x98   396 #define F4O_OFFSET   0xA0   397 #define F42_OFFSET   0xA8   398 #define F44_OFFSET   0xB0   399 #define F46_OFFSET   0xB8   400 #define F48_OFFSET   0xC0   401 #define F5O_OFFSET   0xC8   402 #define F52_OFFSET   0xD0   403 #define F54_OFFSET   0xD8   404 #define F56_OFFSET   0xE0   405 #define F58_OFFSET   0xE8   406 #define F6O_OFFSET   0xF0   407 #define F62_OFFSET   0xF8   408 #define FSR_OFFSET   0x100   410 #define CONTEXT_CONTROL_FP_SIZE 0x108   456 #define ISF_TSTATE_OFFSET      SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x00   457 #define ISF_TPC_OFFSET         SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x08   458 #define ISF_TNPC_OFFSET        SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x10   459 #define ISF_PIL_OFFSET         SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x18   460 #define ISF_Y_OFFSET           SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x20   461 #define ISF_G1_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x28   462 #define ISF_G2_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x30   463 #define ISF_G3_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x38   464 #define ISF_G4_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x40   465 #define ISF_G5_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x48   466 #define ISF_G6_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x50   467 #define ISF_G7_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x58   468 #define ISF_O0_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x60   469 #define ISF_O1_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x68   470 #define ISF_O2_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x70   471 #define ISF_O3_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x78   472 #define ISF_O4_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x80   473 #define ISF_O5_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x88   474 #define ISF_O6_SP_OFFSET       SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x90   475 #define ISF_O7_OFFSET          SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x98   476 #define ISF_TVEC_OFFSET        SPARC64_MINIMUM_STACK_FRAME_SIZE + 0xA0   478 #define CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE SPARC64_MINIMUM_STACK_FRAME_SIZE + 0xA8   495 extern volatile uint32_t _CPU_ISR_Dispatch_disable;
   518   uint32_t     rdpr_tstate_g4;
   519   uint32_t     sethi_of_hh_handler_to_g2;
   520   uint32_t     or_g2_hm_handler_to_g2;
   521   uint32_t     sllx_g2_by_32_to_g2;
   522   uint32_t     sethi_of_handler_to_g3;
   523   uint32_t     or_g3_g2_to_g3;
   524   uint32_t     jmp_to_low_of_handler_plus_g3;
   525   uint32_t     mov_vector_g2;
   544 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )   554 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024   582 #define CPU_INTERRUPT_NUMBER_OF_VECTORS     512   583 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER 1023   585 #define SPARC_SYNCHRONOUS_TRAP_BIT_MASK     0x200   586 #define SPARC_ASYNCHRONOUS_TRAP( _trap )    (_trap)   587 #define SPARC_SYNCHRONOUS_TRAP( _trap )     ((_trap) + 512 )   589 #define SPARC_REAL_TRAP_NUMBER( _trap )     ((_trap) % 512)   596 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE   607 #define CPU_STACK_MINIMUM_SIZE  (1024*8)   609 #define CPU_SIZEOF_POINTER 8   621 #define CPU_ALIGNMENT      8   635 #define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT   651 #define CPU_STACK_ALIGNMENT        16   653 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES   665 #define _CPU_Initialize_vectors()   672  #define _CPU_ISR_Disable( _level ) \   673   (_level) = sparc_disable_interrupts()   681 #define _CPU_ISR_Enable( _level ) \   682   sparc_enable_interrupts( _level )   691 #define _CPU_ISR_Flash( _level ) \   692    sparc_flash_interrupts( _level )   696   return ( level & SPARC_PSTATE_IE_MASK ) != 0;
   705 #define _CPU_ISR_Set_level( _newlevel ) \   706    sparc_enable_interrupts( _newlevel)   752 #define _CPU_Context_Initialization_at_thread_begin() \   754     __asm__ volatile ("set _Thread_Handler,%%i7\n"::); \   766 #define _CPU_Context_Restart_self( _the_context ) \   767    _CPU_Context_restore( (_the_context) );   778 #define _CPU_Context_Initialize_fp( _destination ) \   780    *(*(_destination)) = _CPU_Null_fp_context; \   793 #define _CPU_Fatal_halt( _source, _error ) \   797     level = sparc_disable_interrupts(); \   798     __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) ); \   811 #if ( SPARC_HAS_BITSCAN == 0 )   812 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE   814 #error "scan instruction not currently supported by RTEMS!!"   826 #if ( SPARC_HAS_BITSCAN == 1 )   827 #error "scan instruction not currently supported by RTEMS!!"   842 typedef void ( *CPU_ISR_raw_handler )( void );
   846   CPU_ISR_raw_handler  new_handler,
   847   CPU_ISR_raw_handler *old_handler
   850 typedef void ( *CPU_ISR_handler )( uint32_t );
   854   CPU_ISR_handler  new_handler,
   855   CPU_ISR_handler *old_handler
   926 static inline uint32_t CPU_swap_u32(
   930   uint32_t   byte1, byte2, byte3, byte4, swapped;
   932   byte4 = (value >> 24) & 0xff;
   933   byte3 = (value >> 16) & 0xff;
   934   byte2 = (value >> 8)  & 0xff;
   935   byte1 =  value        & 0xff;
   937   swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
   941 #define CPU_swap_u16( value ) \   942   (((value&0xff) << 8) | ((value >> 8)&0xff))   950 static inline CPU_Counter_ticks _CPU_Counter_difference(
   951   CPU_Counter_ticks second,
   952   CPU_Counter_ticks first
   955   return second - first;
 #define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
Information Required to Build RTEMS for a Particular Member of the SPARC Family.
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
SPARC basic context.
const CPU_Trap_table_entry _CPU_Trap_slot_template
Definition: cpu.c:156
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
Context_Control_fp _CPU_Null_fp_context
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
unsigned size
Definition: tte.h:74
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
