#define  | CPU_SIMPLE_VECTORED_INTERRUPTS   TRUE |
#define  | CPU_ISR_PASSES_FRAME_POINTER   FALSE |
#define  | CPU_HARDWARE_FP   FALSE |
#define  | CPU_SOFTWARE_FP   FALSE |
#define  | CPU_ALL_TASKS_ARE_FP   FALSE |
#define  | CPU_IDLE_TASK_IS_FP   FALSE |
#define  | CPU_USE_DEFERRED_FP_SWITCH   TRUE |
#define  | CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE |
#define  | CPU_STACK_GROWS_UP   FALSE |
#define  | CPU_CACHE_LINE_BYTES   32 |
#define  | CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( 16 ) |
#define  | CPU_MODES_INTERRUPT_MASK   0x0000000F |
#define  | CPU_MAXIMUM_PROCESSORS   32 |
#define  | CPU_STACK_FRAME_L0_OFFSET   0x00 |
#define  | CPU_STACK_FRAME_L1_OFFSET   0x08 |
#define  | CPU_STACK_FRAME_L2_OFFSET   0x10 |
#define  | CPU_STACK_FRAME_L3_OFFSET   0x18 |
#define  | CPU_STACK_FRAME_L4_OFFSET   0x20 |
#define  | CPU_STACK_FRAME_L5_OFFSET   0x28 |
#define  | CPU_STACK_FRAME_L6_OFFSET   0x30 |
#define  | CPU_STACK_FRAME_L7_OFFSET   0x38 |
#define  | CPU_STACK_FRAME_I0_OFFSET   0x40 |
#define  | CPU_STACK_FRAME_I1_OFFSET   0x48 |
#define  | CPU_STACK_FRAME_I2_OFFSET   0x50 |
#define  | CPU_STACK_FRAME_I3_OFFSET   0x58 |
#define  | CPU_STACK_FRAME_I4_OFFSET   0x60 |
#define  | CPU_STACK_FRAME_I5_OFFSET   0x68 |
#define  | CPU_STACK_FRAME_I6_FP_OFFSET   0x70 |
#define  | CPU_STACK_FRAME_I7_OFFSET   0x78 |
#define  | CPU_STRUCTURE_RETURN_ADDRESS_OFFSET   0x80 |
#define  | CPU_STACK_FRAME_SAVED_ARG0_OFFSET   0x88 |
#define  | CPU_STACK_FRAME_SAVED_ARG1_OFFSET   0x90 |
#define  | CPU_STACK_FRAME_SAVED_ARG2_OFFSET   0x98 |
#define  | CPU_STACK_FRAME_SAVED_ARG3_OFFSET   0xA0 |
#define  | CPU_STACK_FRAME_SAVED_ARG4_OFFSET   0xA8 |
#define  | CPU_STACK_FRAME_SAVED_ARG5_OFFSET   0xB0 |
#define  | CPU_STACK_FRAME_PAD0_OFFSET   0xB8 |
#define  | SPARC64_MINIMUM_STACK_FRAME_SIZE   0xC0 |
#define  | _CPU_Context_Get_SP(_context)   (_context)->o6_sp |
#define  | G1_OFFSET   0x00 |
#define  | G2_OFFSET   0x08 |
#define  | G3_OFFSET   0x10 |
#define  | G4_OFFSET   0x18 |
#define  | G5_OFFSET   0x20 |
#define  | G6_OFFSET   0x28 |
#define  | G7_OFFSET   0x30 |
#define  | L0_OFFSET   0x38 |
#define  | L1_OFFSET   0x40 |
#define  | L2_OFFSET   0x48 |
#define  | L3_OFFSET   0x50 |
#define  | L4_OFFSET   0x58 |
#define  | L5_OFFSET   0x60 |
#define  | L6_OFFSET   0x68 |
#define  | L7_OFFSET   0x70 |
#define  | I0_OFFSET   0x78 |
#define  | I1_OFFSET   0x80 |
#define  | I2_OFFSET   0x88 |
#define  | I3_OFFSET   0x90 |
#define  | I4_OFFSET   0x98 |
#define  | I5_OFFSET   0xA0 |
#define  | I6_FP_OFFSET   0xA8 |
#define  | I7_OFFSET   0xB0 |
#define  | O0_OFFSET   0xB8 |
#define  | O1_OFFSET   0xC0 |
#define  | O2_OFFSET   0xC8 |
#define  | O3_OFFSET   0xD0 |
#define  | O4_OFFSET   0xD8 |
#define  | O5_OFFSET   0xE0 |
#define  | O6_SP_OFFSET   0xE8 |
#define  | O7_OFFSET   0xF0 |
#define  | ISR_DISPATCH_DISABLE_STACK_OFFSET   0xF8 |
#define  | ISR_PAD_OFFSET   0xFC |
#define  | FO_OFFSET   0x00 |
#define  | F2_OFFSET   0x08 |
#define  | F4_OFFSET   0x10 |
#define  | F6_OFFSET   0x18 |
#define  | F8_OFFSET   0x20 |
#define  | F1O_OFFSET   0x28 |
#define  | F12_OFFSET   0x30 |
#define  | F14_OFFSET   0x38 |
#define  | F16_OFFSET   0x40 |
#define  | F18_OFFSET   0x48 |
#define  | F2O_OFFSET   0x50 |
#define  | F22_OFFSET   0x58 |
#define  | F24_OFFSET   0x60 |
#define  | F26_OFFSET   0x68 |
#define  | F28_OFFSET   0x70 |
#define  | F3O_OFFSET   0x78 |
#define  | F32_OFFSET   0x80 |
#define  | F34_OFFSET   0x88 |
#define  | F36_OFFSET   0x90 |
#define  | F38_OFFSET   0x98 |
#define  | F4O_OFFSET   0xA0 |
#define  | F42_OFFSET   0xA8 |
#define  | F44_OFFSET   0xB0 |
#define  | F46_OFFSET   0xB8 |
#define  | F48_OFFSET   0xC0 |
#define  | F5O_OFFSET   0xC8 |
#define  | F52_OFFSET   0xD0 |
#define  | F54_OFFSET   0xD8 |
#define  | F56_OFFSET   0xE0 |
#define  | F58_OFFSET   0xE8 |
#define  | F6O_OFFSET   0xF0 |
#define  | F62_OFFSET   0xF8 |
#define  | FSR_OFFSET   0x100 |
#define  | CONTEXT_CONTROL_FP_SIZE   0x108 |
#define  | ISF_TSTATE_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x00 |
#define  | ISF_TPC_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x08 |
#define  | ISF_TNPC_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x10 |
#define  | ISF_PIL_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x18 |
#define  | ISF_Y_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x20 |
#define  | ISF_G1_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x28 |
#define  | ISF_G2_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x30 |
#define  | ISF_G3_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x38 |
#define  | ISF_G4_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x40 |
#define  | ISF_G5_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x48 |
#define  | ISF_G6_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x50 |
#define  | ISF_G7_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x58 |
#define  | ISF_O0_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x60 |
#define  | ISF_O1_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x68 |
#define  | ISF_O2_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x70 |
#define  | ISF_O3_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x78 |
#define  | ISF_O4_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x80 |
#define  | ISF_O5_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x88 |
#define  | ISF_O6_SP_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x90 |
#define  | ISF_O7_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x98 |
#define  | ISF_TVEC_OFFSET   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0xA0 |
#define  | CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE   SPARC64_MINIMUM_STACK_FRAME_SIZE + 0xA8 |
#define  | CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp ) |
#define  | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024 |
#define  | CPU_INTERRUPT_NUMBER_OF_VECTORS   512 |
#define  | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER   1023 |
#define  | SPARC_SYNCHRONOUS_TRAP_BIT_MASK   0x200 |
#define  | SPARC_ASYNCHRONOUS_TRAP(_trap)   (_trap) |
#define  | SPARC_SYNCHRONOUS_TRAP(_trap)   ((_trap) + 512 ) |
#define  | SPARC_REAL_TRAP_NUMBER(_trap)   ((_trap) % 512) |
#define  | CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE |
#define  | CPU_STACK_MINIMUM_SIZE   (1024*8) |
#define  | CPU_SIZEOF_POINTER   8 |
#define  | CPU_ALIGNMENT   8 |
#define  | CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT |
#define  | CPU_STACK_ALIGNMENT   16 |
#define  | CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES |
#define  | _CPU_Initialize_vectors() |
#define  | _CPU_ISR_Disable(_level)   (_level) = sparc_disable_interrupts() |
#define  | _CPU_ISR_Enable(_level)   sparc_enable_interrupts( _level ) |
#define  | _CPU_ISR_Flash(_level)   sparc_flash_interrupts( _level ) |
#define  | _CPU_ISR_Set_level(_newlevel)   sparc_enable_interrupts( _newlevel) |
| #define  | _CPU_Context_Initialization_at_thread_begin() |
#define  | _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) ); |
| #define  | _CPU_Context_Initialize_fp(_destination) |
| #define  | _CPU_Fatal_halt(_source,  _error) |
#define  | CPU_USE_GENERIC_BITFIELD_CODE   TRUE |
#define  | CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff)) |
| RTEMS_INLINE_ROUTINE bool  | _CPU_ISR_Is_enabled (uint32_t level) |
|   | Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.  More...
| uint32_t  | _CPU_ISR_Get_level (void) |
|   | Returns the interrupt level of the executing thread.  More...
void  | _CPU_Context_Initialize (Context_Control *the_context, void *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
| void  | _CPU_Initialize (void) |
|   | CPU initialization.  More...
| void  | _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler) |
|   | SPARC specific raw ISR installer.  More...
| void  | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
|   | SPARC specific RTEMS ISR installer.  More...
| void *  | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void  | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
|   | CPU switch context.  More...
| void  | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
|   | SPARC specific context restore.  More...
void  | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
void  | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
| void  | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
|   | Prints the exception frame via printk().  More...
| uint32_t  | _CPU_Counter_frequency (void) |
|   | Returns the current CPU counter frequency in Hz.  More...
| CPU_Counter_ticks  | _CPU_Counter_read (void) |
|   | Returns the current CPU counter value.  More...
SPARC64 CPU Department Source.
This include file contains information pertaining to the port of the executive to the SPARC64 processor.
