RTEMS  5.1
cpu.h
1
5 /*
6  * This include file contains information pertaining to the Hitachi SH
7  * processor.
8  *
9  * Authors: Ralf Corsepius (corsepiu@faw.uni-ulm.de) and
10  * Bernd Becker (becker@faw.uni-ulm.de)
11  *
12  * COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
17  *
18  *
19  * COPYRIGHT (c) 1998-2006.
20  * On-Line Applications Research Corporation (OAR).
21  *
22  * The license and distribution terms for this file may be
23  * found in the file LICENSE in this distribution or at
24  * http://www.rtems.org/license/LICENSE.
25  */
26
27 #ifndef _RTEMS_SCORE_CPU_H
28 #define _RTEMS_SCORE_CPU_H
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif
33
34 #include <rtems/score/basedefs.h>
35 #include <rtems/score/sh.h>
36
37 /* conditional compilation parameters */
38
39 /*
40  * Does the CPU follow the simple vectored interrupt model?
41  *
42  * If TRUE, then RTEMS allocates the vector table it internally manages.
43  * If FALSE, then the BSP is assumed to allocate and manage the vector
44  * table
45  *
46  * SH Specific Information:
47  *
48  * XXX document implementation including references if appropriate
49  */
50 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
51
52 /*
53  * Does the RTEMS invoke the user's ISR with the vector number and
54  * a pointer to the saved interrupt frame (1) or just the vector
55  * number (0)?
56  */
57
58 #define CPU_ISR_PASSES_FRAME_POINTER FALSE
59
60 /*
61  * Does the CPU have hardware floating point?
62  *
63  * If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
64  * If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
65  *
66  * We currently support sh1 only, which has no FPU, other SHes have an FPU
67  *
68  * The macro name "SH_HAS_FPU" should be made CPU specific.
69  * It indicates whether or not this CPU model has FP support. For
70  * example, it would be possible to have an i386_nofp CPU model
71  * which set this to false to indicate that you have an i386 without
72  * an i387 and wish to leave floating point support out of RTEMS.
73  */
74
75 #if SH_HAS_FPU
76 #define CPU_HARDWARE_FP TRUE
77 #define CPU_SOFTWARE_FP FALSE
78 #else
79 #define CPU_SOFTWARE_FP FALSE
80 #define CPU_HARDWARE_FP FALSE
81 #endif
82
83 /*
84  * Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
85  *
86  * If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
87  * If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
88  *
89  * If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
90  */
91
92 #if SH_HAS_FPU
93 #define CPU_ALL_TASKS_ARE_FP TRUE
94 #else
95 #define CPU_ALL_TASKS_ARE_FP FALSE
96 #endif
97
98 /*
99  * Should the IDLE task have a floating point context?
100  *
101  * If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
102  * and it has a floating point context which is switched in and out.
103  * If FALSE, then the IDLE task does not have a floating point context.
104  *
105  * Setting this to TRUE negatively impacts the time required to preempt
106  * the IDLE task from an interrupt because the floating point context
107  * must be saved as part of the preemption.
108  */
109
110 #if SH_HAS_FPU
111 #define CPU_IDLE_TASK_IS_FP TRUE
112 #else
113 #define CPU_IDLE_TASK_IS_FP FALSE
114 #endif
115
116 /*
117  * Should the saving of the floating point registers be deferred
118  * until a context switch is made to another different floating point
119  * task?
120  *
121  * If TRUE, then the floating point context will not be stored until
122  * necessary. It will remain in the floating point registers and not
123  * disturned until another floating point task is switched to.
124  *
125  * If FALSE, then the floating point context is saved when a floating
126  * point task is switched out and restored when the next floating point
127  * task is restored. The state of the floating point registers between
128  * those two operations is not specified.
129  *
130  * If the floating point context does NOT have to be saved as part of
131  * interrupt dispatching, then it should be safe to set this to TRUE.
132  *
133  * Setting this flag to TRUE results in using a different algorithm
134  * for deciding when to save and restore the floating point context.
135  * The deferred FP switch algorithm minimizes the number of times
136  * the FP context is saved and restored. The FP context is not saved
137  * until a context switch is made to another, different FP task.
138  * Thus in a system with only one FP task, the FP context will never
139  * be saved or restored.
140  */
141
142 #if SH_HAS_FPU
143 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
144 #else
145 #define CPU_USE_DEFERRED_FP_SWITCH TRUE
146 #endif
147
148 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
149
150 /*
151  * Does the stack grow up (toward higher addresses) or down
152  * (toward lower addresses)?
153  *
154  * If TRUE, then the grows upward.
155  * If FALSE, then the grows toward smaller addresses.
156  */
157
158 #define CPU_STACK_GROWS_UP FALSE
159
160 /* FIXME: Is this the right value? */
161 #define CPU_CACHE_LINE_BYTES 16
162
163 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
164
165 /*
166  * The following defines the number of bits actually used in the
167  * interrupt field of the task mode. How those bits map to the
168  * CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
169  */
170
171 #define CPU_MODES_INTERRUPT_MASK 0x0000000f
172
173 #define CPU_MAXIMUM_PROCESSORS 32
174
175 /*
176  * Processor defined structures required for cpukit/score.
177  */
178
179 /* may need to put some structures here. */
180
181 /*
182  * Contexts
183  *
184  * Generally there are 2 types of context to save.
185  * 1. Interrupt registers to save
186  * 2. Task level registers to save
187  *
188  * This means we have the following 3 context items:
189  * 1. task level context stuff:: Context_Control
190  * 2. floating point task stuff:: Context_Control_fp
191  * 3. special interrupt level context :: Context_Control_interrupt
192  *
193  * On some processors, it is cost-effective to save only the callee
194  * preserved registers during a task context switch. This means
195  * that the ISR code needs to save those registers which do not
196  * persist across function calls. It is not mandatory to make this
197  * distinctions between the caller/callee saves registers for the
198  * purpose of minimizing context saved during task switch and on interrupts.
199  * If the cost of saving extra registers is minimal, simplicity is the
200  * choice. Save the same context on interrupt entry as for tasks in
201  * this case.
202  *
203  * Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
204  * care should be used in designing the context area.
205  *
206  * On some CPUs with hardware floating point support, the Context_Control_fp
207  * structure will not be used or it simply consist of an array of a
208  * fixed number of bytes. This is done when the floating point context
209  * is dumped by a "FP save context" type instruction and the format
210  * is not really defined by the CPU. In this case, there is no need
211  * to figure out the exact format -- only the size. Of course, although
212  * this is enough information for RTEMS, it is probably not enough for
213  * a debugger such as gdb. But that is another problem.
214  */
215
216 typedef struct {
217  uint32_t *r15; /* stack pointer */
218
219  uint32_t macl;
220  uint32_t mach;
221  uint32_t *pr;
222
223  uint32_t *r14; /* frame pointer/call saved */
224
225  uint32_t r13; /* call saved */
226  uint32_t r12; /* call saved */
227  uint32_t r11; /* call saved */
228  uint32_t r10; /* call saved */
229  uint32_t r9; /* call saved */
230  uint32_t r8; /* call saved */
231
232  uint32_t *r7; /* arg in */
233  uint32_t *r6; /* arg in */
234
235 #if 0
236  uint32_t *r5; /* arg in */
237  uint32_t *r4; /* arg in */
238 #endif
239
240  uint32_t *r3; /* scratch */
241  uint32_t *r2; /* scratch */
242  uint32_t *r1; /* scratch */
243
244  uint32_t *r0; /* arg return */
245
246  uint32_t gbr;
247  uint32_t sr;
248
250
251 #define _CPU_Context_Get_SP( _context ) \
252  (_context)->r15
253
254 typedef struct {
255 #if SH_HAS_FPU
256 #ifdef SH4_USE_X_REGISTERS
257  union {
258  float f[16];
259  double d[8];
260  } x;
261 #endif
262  union {
263  float f[16];
264  double d[8];
265  } r;
266  float fpul; /* fp communication register */
267  uint32_t fpscr; /* fp control register */
268 #endif /* SH_HAS_FPU */
270
271 typedef struct {
273
274 /*
275  * This variable is optional. It is used on CPUs on which it is difficult
276  * to generate an "uninitialized" FP context. It is filled in by
277  * _CPU_Initialize and copied into the task's FP context area during
278  * _CPU_Context_Initialize.
279  */
280
281 #if SH_HAS_FPU
283 #endif
284
285 /*
286  * Nothing prevents the porter from declaring more CPU specific variables.
287  */
288
289 /* XXX: if needed, put more variables here */
290 void CPU_delay( uint32_t microseconds );
291
292 /*
293  * The size of the floating point context area. On some CPUs this
294  * will not be a "sizeof" because the format of the floating point
295  * area is not defined -- only the size is. This is usually on
296  * CPUs with a "floating point save context" instruction.
297  */
298
299 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
300
301 /*
302  * Amount of extra stack (above minimum stack size) required by
303  * MPCI receive server thread. Remember that in a multiprocessor
304  * system this thread must exist and be able to process all directives.
305  */
306
307 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
308
309 /*
310  * This defines the number of entries in the ISR_Vector_table managed
311  * by RTEMS.
312  */
313
314 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 256
315 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
316
317 /*
318  * This is defined if the port has a special way to report the ISR nesting
319  * level. Most ports maintain the variable _ISR_Nest_level.
320  */
321
322 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
323
324 /*
325  * Should be large enough to run all RTEMS tests. This ensures
326  * that a "reasonable" small application should not have any problems.
327  *
328  * We have been able to run the sptests with this value, but have not
329  * been able to run the tmtest suite.
330  */
331
332 #define CPU_STACK_MINIMUM_SIZE 4096
333
334 #define CPU_SIZEOF_POINTER 4
335
336 /*
337  * CPU's worst alignment requirement for data types on a byte boundary. This
338  * alignment does not take into account the requirements for the stack.
339  */
340 #if defined(__SH4__)
341 /* FIXME: sh3 and SH3E? */
342 #define CPU_ALIGNMENT 8
343 #else
344 #define CPU_ALIGNMENT 4
345 #endif
346
347 /*
348  * This number corresponds to the byte alignment requirement for the
349  * heap handler. This alignment requirement may be stricter than that
350  * for the data types alignment specified by CPU_ALIGNMENT. It is
351  * common for the heap to follow the same alignment requirement as
352  * CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap,
353  * then this should be set to CPU_ALIGNMENT.
354  *
355  * NOTE: This does not have to be a power of 2. It does have to
356  * be greater or equal to than CPU_ALIGNMENT.
357  */
358
359 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
360
361 /*
362  * This number corresponds to the byte alignment requirement for the
363  * stack. This alignment requirement may be stricter than that for the
364  * data types alignment specified by CPU_ALIGNMENT. If the CPU_ALIGNMENT
365  * is strict enough for the stack, then this should be set to 0.
366  *
367  * NOTE: This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
368  */
369
370 #define CPU_STACK_ALIGNMENT CPU_ALIGNMENT
371
372 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
373
374 /*
375  * ISR handler macros
376  */
377
378 /*
379  * Support routine to initialize the RTEMS vector table after it is allocated.
380  *
381  * SH Specific Information: NONE
382  */
383
384 #define _CPU_Initialize_vectors()
385
386 /*
387  * Disable all interrupts for an RTEMS critical section. The previous
388  * level is returned in _level.
389  */
390
391 #define _CPU_ISR_Disable( _level) \
392  sh_disable_interrupts( _level )
393
394 /*
395  * Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
396  * This indicates the end of an RTEMS critical section. The parameter
397  * _level is not modified.
398  */
399
400 #define _CPU_ISR_Enable( _level) \
401  sh_enable_interrupts( _level)
402
403 /*
404  * This temporarily restores the interrupt to _level before immediately
405  * disabling them again. This is used to divide long RTEMS critical
406  * sections into two or more parts. The parameter _level is not
407  * modified.
408  */
409
410 #define _CPU_ISR_Flash( _level) \
411  sh_flash_interrupts( _level)
412
414 {
415  sh_get_interrupt_level( level );
416  return level == 0;
417 }
418
419 /*
420  * Map interrupt level in task mode onto the hardware that the CPU
421  * actually provides. Currently, interrupt levels which do not
422  * map onto the CPU in a generic fashion are undefined. Someday,
423  * it would be nice if these were "mapped" by the application
424  * via a callout. For example, m68k has 8 levels 0 - 7, levels
425  * 8 - 255 would be available for bsp/application specific meaning.
426  * This could be used to manage a programmable interrupt controller
427  * via the rtems_task_mode directive.
428  */
429
430 #define _CPU_ISR_Set_level( _newlevel) \
431  sh_set_interrupt_level(_newlevel)
432
433 uint32_t _CPU_ISR_Get_level( void );
434
435 /* end of ISR handler macros */
436
437 /* Context handler macros */
438
439 /*
440  * Initialize the context to a state suitable for starting a
441  * task after a context restore operation. Generally, this
442  * involves:
443  *
444  * - setting a starting address
445  * - preparing the stack
446  * - preparing the stack and frame pointers
447  * - setting the proper interrupt level in the context
448  * - initializing the floating point context
449  *
450  * This routine generally does not set any unnecessary register
451  * in the context. The state of the "general data" registers is
452  * undefined at task start time.
453  *
454  * NOTE: This is_fp parameter is TRUE if the thread is to be a floating
455  * point thread. This is typically only used on CPUs where the
456  * FPU may be easily disabled by software such as on the SPARC
457  * where the PSR contains an enable FPU bit.
458  */
459
460 /*
461  * FIXME: defined as a function for debugging - should be a macro
462  */
464  Context_Control *_the_context,
465  void *_stack_base,
466  uint32_t _size,
467  uint32_t _isr,
468  void (*_entry_point)(void),
469  int _is_fp,
470  void *_tls_area );
471
472 /*
473  * This routine is responsible for somehow restarting the currently
474  * executing task. If you are lucky, then all that is necessary
475  * is restoring the context. Otherwise, there will need to be
476  * a special assembly routine which does something special in this
477  * case. Context_Restore should work most of the time. It will
478  * not work if restarting self conflicts with the stack frame
479  * assumptions of restoring a context.
480  */
481
482 #define _CPU_Context_Restart_self( _the_context ) \
483  _CPU_Context_restore( (_the_context) );
484
485 /*
486  * This routine initializes the FP context area passed to it to.
487  * There are a few standard ways in which to initialize the
488  * floating point context. The code included for this macro assumes
489  * that this is a CPU in which a "initial" FP context was saved into
490  * _CPU_Null_fp_context and it simply copies it to the destination
491  * context passed to it.
492  *
493  * Other models include (1) not doing anything, and (2) putting
494  * a "null FP status word" in the correct place in the FP context.
495  * SH1, SH2, SH3 have no FPU, but the SH3e and SH4 have.
496  */
497
498 #if SH_HAS_FPU
499 #define _CPU_Context_Initialize_fp( _destination ) \
500  do { \
501  *(*(_destination)) = _CPU_Null_fp_context;\
502  } while(0)
503 #else
504 #define _CPU_Context_Initialize_fp( _destination ) \
505  { }
506 #endif
507
508 /* end of Context handler macros */
509
510 /* Fatal Error manager macros */
511
512 /*
513  * FIXME: Trap32 ???
514  *
515  * This routine copies _error into a known place -- typically a stack
516  * location or a register, optionally disables interrupts, and
517  * invokes a Trap32 Instruction which returns to the breakpoint
518  * routine of cmon.
519  */
520
521 #ifdef BSP_FATAL_HALT
522  /* we manage the fatal error in the board support package */
523  void bsp_fatal_halt( uint32_t _error);
524 #define _CPU_Fatal_halt( _source, _error ) bsp_fatal_halt( _error)
525 #else
526 #define _CPU_Fatal_halt( _source, _error)\
527 { \
528  __asm__ volatile("mov.l %0,r0"::"m" (_error)); \
529  __asm__ volatile("mov #1, r4"); \
530  __asm__ volatile("trapa #34"); \
531 }
532 #endif
533
534 /* end of Fatal Error manager macros */
535
536 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
537
538 /* functions */
539
540 /*
541  * @brief CPU Initialize
542  *
543  * _CPU_Initialize
544  *
545  * This routine performs CPU dependent initialization.
546  */
547 void _CPU_Initialize(void);
548
549 typedef void ( *CPU_ISR_raw_handler )( void );
550
551 extern CPU_ISR_raw_handler _Hardware_isr_Table[];
552
554  uint32_t vector,
555  CPU_ISR_raw_handler new_handler,
556  CPU_ISR_raw_handler *old_handler
557 );
558
559 typedef void ( *CPU_ISR_handler )( uint32_t );
560
562  uint32_t vector,
563  CPU_ISR_handler new_handler,
564  CPU_ISR_handler *old_handler
565 );
566
567 void *_CPU_Thread_Idle_body( uintptr_t ignored );
568
569 /*
570  * _CPU_Context_switch
571  *
572  * This routine switches from the run context to the heir context.
573  */
574
576  Context_Control *run,
577  Context_Control *heir
578 );
579
580 /*
581  * _CPU_Context_restore
582  *
583  * This routine is generally used only to restart self in an
584  * efficient manner. It may simply be a label in _CPU_Context_switch.
585  */
586
588  Context_Control *new_context
590
591 /*
592  * @brief This routine saves the floating point context passed to it.
593  *
594  * _CPU_Context_save_fp
595  *
596  */
598  Context_Control_fp **fp_context_ptr
599 );
600
601 /*
602  * @brief This routine restores the floating point context passed to it.
603  *
604  * _CPU_Context_restore_fp
605  *
606  */
608  Context_Control_fp **fp_context_ptr
609 );
610
611 /* FIXME */
613
615
616 typedef uint32_t CPU_Counter_ticks;
617
618 uint32_t _CPU_Counter_frequency( void );
619
620 CPU_Counter_ticks _CPU_Counter_read( void );
621
622 static inline CPU_Counter_ticks _CPU_Counter_difference(
623  CPU_Counter_ticks second,
624  CPU_Counter_ticks first
625 )
626 {
627  return second - first;
628 }
629
631 typedef uintptr_t CPU_Uint32ptr;
632
634 typedef void sh_isr;
635 typedef void ( *sh_isr_entry )( void );
636
637 #ifdef __cplusplus
638 }
639 #endif
640
641 #endif
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void sh_isr
Definition: cpu.h:634
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
Hitachi SH CPU Department Source.
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
unsigned pr
Definition: tlb.h:225
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
CPU initialization.
Definition: cpu.c:45
SPARC basic context.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
Context_Control_fp _CPU_Null_fp_context
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
