Hitachi SH CPU Department Source.
More...
#define | SH_HAS_FPU 0 |
#define | CPU_MODEL_NAME "SH-Multilib" |
#define | SH_HAS_SEPARATE_STACKS 1 |
#define | CPU_NAME "Hitachi SH" |
#define | SH_IRQDIS_MASK 0xf0 |
| #define | sh_disable_interrupts(_level) |
| #define | sh_enable_interrupts(_level) |
| #define | sh_flash_interrupts(_level) |
| #define | sh_get_interrupt_level(_level) |
| #define | sh_set_interrupt_level(_newlevel) |
#define | CPU_swap_u32(value) sh_swap_u32( value ) |
#define | CPU_swap_u16(value) sh_swap_u16( value ) |
unsigned int | sh_set_irq_priority (unsigned int irq, unsigned int prio) |
This include file contains information pertaining to the Hitachi SH processor.
◆ sh_disable_interrupts
| #define sh_disable_interrupts |
_level | ) |
Value: "stc sr,%0\n\t" \
"mov %0,r5\n\t" \
"or %1,r5\n\t" \
"ldc r5,sr\n\t"\
: "=&r" (_level ) \
: "r" (SH_IRQDIS_MASK) \
: "r5" );
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
◆ sh_enable_interrupts
| #define sh_enable_interrupts |
_level | ) |
Value:__asm__ volatile(
"ldc %0,sr\n\t" \
"nop\n\t" \
:: "r" (_level) );
◆ sh_flash_interrupts
| #define sh_flash_interrupts |
_level | ) |
Value: "stc sr,r5\n\t" \
"ldc %1,sr\n\t" \
"nop\n\t" \
"or %0,r5\n\t" \
"ldc r5,sr\n\t" \
"nop\n\t" \
: : "r" (SH_IRQDIS_MASK), "r" (_level) : "r5");
◆ sh_get_interrupt_level
| #define sh_get_interrupt_level |
_level | ) |
Value:{ \
uint32_t _tmpsr ; \
__asm__ volatile( "stc sr, %0" : "=r" (_tmpsr) ); \
_level = (_tmpsr & 0xf0) >> 4 ; \
◆ sh_set_interrupt_level
| #define sh_set_interrupt_level |
_newlevel | ) |
Value:{ \
uint32_t _tmpsr; \
__asm__ volatile ( "stc sr, %0" : "=r" (_tmpsr) ); \
_tmpsr = ( _tmpsr & ~0xf0 ) | ((_newlevel) << 4) ; \
__asm__ volatile( "ldc %0,sr" :: "r" (_tmpsr) ); \
