#define | SCHEDULER_CBS_MAXIMUM_PRIORITY SCHEDULER_EDF_MAXIMUM_PRIORITY |
| #define | SCHEDULER_CBS_ENTRY_POINTS |
#define | SCHEDULER_CBS_OK 0 |
#define | SCHEDULER_CBS_ERROR_GENERIC -16 |
#define | SCHEDULER_CBS_ERROR_NO_MEMORY -17 |
#define | SCHEDULER_CBS_ERROR_INVALID_PARAMETER -18 |
#define | SCHEDULER_CBS_ERROR_UNAUTHORIZED -19 |
#define | SCHEDULER_CBS_ERROR_UNIMPLEMENTED -20 |
#define | SCHEDULER_CBS_ERROR_MISSING_COMPONENT -21 |
#define | SCHEDULER_CBS_ERROR_INCONSISTENT_STATE -22 |
#define | SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD -23 |
#define | SCHEDULER_CBS_ERROR_INTERNAL_ERROR -24 |
#define | SCHEDULER_CBS_ERROR_NOT_FOUND -25 |
#define | SCHEDULER_CBS_ERROR_FULL -26 |
#define | SCHEDULER_CBS_ERROR_EMPTY -27 |
#define | SCHEDULER_CBS_ERROR_NOSERVER SCHEDULER_CBS_ERROR_NOT_FOUND |
| void | _Scheduler_CBS_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| | Unblocks a thread. More...
| void | _Scheduler_CBS_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context) |
| | Releases a job. More...
| void | _Scheduler_CBS_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
| | Cancels a job. More...
| int | _Scheduler_CBS_Initialize (void) |
| | _Scheduler_CBS_Initialize More...
| int | _Scheduler_CBS_Attach_thread (Scheduler_CBS_Server_id server_id, rtems_id task_id) |
| | Attaches a task to an already existing server. More...
| int | _Scheduler_CBS_Detach_thread (Scheduler_CBS_Server_id server_id, rtems_id task_id) |
| | Detaches from the CBS Server. More...
| int | _Scheduler_CBS_Cleanup (void) |
| | Cleans up resources associated to the CBS Library. More...
| int | _Scheduler_CBS_Create_server (Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id) |
| | Creates a new server with specified parameters. More...
| int | _Scheduler_CBS_Destroy_server (Scheduler_CBS_Server_id server_id) |
| | Detaches all tasks from a server and destroys it. More...
| int | _Scheduler_CBS_Get_approved_budget (Scheduler_CBS_Server_id server_id, time_t *approved_budget) |
| | Retrieves the approved budget. More...
| int | _Scheduler_CBS_Get_remaining_budget (Scheduler_CBS_Server_id server_id, time_t *remaining_budget) |
| | Retrieves remaining budget for the current server instance. More...
| int | _Scheduler_CBS_Get_execution_time (Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time) |
| | Gets relative time info. More...
| int | _Scheduler_CBS_Get_parameters (Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params) |
| | Retrieves CBS scheduling parameters. More...
| int | _Scheduler_CBS_Get_server_id (rtems_id task_id, Scheduler_CBS_Server_id *server_id) |
| | Gets a thread server id. More...
| int | _Scheduler_CBS_Set_parameters (Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters) |
| | Sets parameters for CBS scheduling. More...
| void | _Scheduler_CBS_Budget_callout (Thread_Control *the_thread) |
| | Invoked when a limited time quantum is exceeded. More...
| void | _Scheduler_CBS_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| | Initializes a CBS specific scheduler node of the_thread. More...
Thread manipulation for the CBS scheduler.
This include file contains all the constants and structures associated with the manipulation of threads for the CBS scheduler.
