RTEMS  5.1
Files | Data Structures | Macros | Typedefs | Functions | Variables
CBS Scheduler. More...
file  schedulercbs.h
 Thread manipulation for the CBS scheduler.
file  schedulercbsimpl.h
 CBS Scheduler Implementation.
struct  Scheduler_CBS_Parameters
struct  Scheduler_CBS_Server
struct  Scheduler_CBS_Node
#define SCHEDULER_CBS_MAXIMUM_PRIORITY   SCHEDULER_EDF_MAXIMUM_PRIORITY
#define SCHEDULER_CBS_ENTRY_POINTS
#define SCHEDULER_CBS_OK   0
#define SCHEDULER_CBS_ERROR_GENERIC   -16
#define SCHEDULER_CBS_ERROR_NO_MEMORY   -17
#define SCHEDULER_CBS_ERROR_INVALID_PARAMETER   -18
#define SCHEDULER_CBS_ERROR_UNAUTHORIZED   -19
#define SCHEDULER_CBS_ERROR_UNIMPLEMENTED   -20
#define SCHEDULER_CBS_ERROR_MISSING_COMPONENT   -21
#define SCHEDULER_CBS_ERROR_INCONSISTENT_STATE   -22
#define SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD   -23
#define SCHEDULER_CBS_ERROR_INTERNAL_ERROR   -24
#define SCHEDULER_CBS_ERROR_NOT_FOUND   -25
#define SCHEDULER_CBS_ERROR_FULL   -26
#define SCHEDULER_CBS_ERROR_EMPTY   -27
#define SCHEDULER_CBS_ERROR_NOSERVER   SCHEDULER_CBS_ERROR_NOT_FOUND
typedef uint32_t Scheduler_CBS_Server_id
typedef void(* Scheduler_CBS_Budget_overrun) (Scheduler_CBS_Server_id server_id)
void _Scheduler_CBS_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Unblocks a thread. More...
void _Scheduler_CBS_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
 Releases a job. More...
void _Scheduler_CBS_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
 Cancels a job. More...
int _Scheduler_CBS_Initialize (void)
 _Scheduler_CBS_Initialize More...
int _Scheduler_CBS_Attach_thread (Scheduler_CBS_Server_id server_id, rtems_id task_id)
 Attaches a task to an already existing server. More...
int _Scheduler_CBS_Detach_thread (Scheduler_CBS_Server_id server_id, rtems_id task_id)
 Detaches from the CBS Server. More...
int _Scheduler_CBS_Cleanup (void)
 Cleans up resources associated to the CBS Library. More...
int _Scheduler_CBS_Create_server (Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id)
 Creates a new server with specified parameters. More...
int _Scheduler_CBS_Destroy_server (Scheduler_CBS_Server_id server_id)
 Detaches all tasks from a server and destroys it. More...
int _Scheduler_CBS_Get_approved_budget (Scheduler_CBS_Server_id server_id, time_t *approved_budget)
 Retrieves the approved budget. More...
int _Scheduler_CBS_Get_remaining_budget (Scheduler_CBS_Server_id server_id, time_t *remaining_budget)
 Retrieves remaining budget for the current server instance. More...
int _Scheduler_CBS_Get_execution_time (Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time)
 Gets relative time info. More...
int _Scheduler_CBS_Get_parameters (Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params)
 Retrieves CBS scheduling parameters. More...
int _Scheduler_CBS_Get_server_id (rtems_id task_id, Scheduler_CBS_Server_id *server_id)
 Gets a thread server id. More...
int _Scheduler_CBS_Set_parameters (Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters)
 Sets parameters for CBS scheduling. More...
void _Scheduler_CBS_Budget_callout (Thread_Control *the_thread)
 Invoked when a limited time quantum is exceeded. More...
void _Scheduler_CBS_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes a CBS specific scheduler node of the_thread. More...
RTEMS_INLINE_ROUTINE Scheduler_CBS_Node * _Scheduler_CBS_Thread_get_node (Thread_Control *the_thread)
 Gets the CBS node of the thread. More...
RTEMS_INLINE_ROUTINE Scheduler_CBS_Node * _Scheduler_CBS_Node_downcast (Scheduler_Node *node)
 Casts the scheduler node to a scheduler CBS node. More...
const uint32_t _Scheduler_CBS_Maximum_servers
Scheduler_CBS_Server _Scheduler_CBS_Server_list []
CBS Scheduler.
◆ SCHEDULER_CBS_ENTRY_POINTS
Value:
_Scheduler_EDF_Initialize, /* initialize entry point */ \
_Scheduler_EDF_Schedule, /* schedule entry point */ \
_Scheduler_EDF_Yield, /* yield entry point */ \
_Scheduler_EDF_Block, /* block entry point */ \
_Scheduler_CBS_Unblock, /* unblock entry point */ \
_Scheduler_EDF_Update_priority, /* update priority entry point */ \
_Scheduler_EDF_Map_priority, /* map priority entry point */ \
_Scheduler_EDF_Unmap_priority, /* unmap priority entry point */ \
_Scheduler_CBS_Node_initialize, /* node initialize entry point */ \
_Scheduler_default_Node_destroy, /* node destroy entry point */ \
_Scheduler_CBS_Release_job, /* new period of task */ \
_Scheduler_CBS_Cancel_job, /* cancel period of task */ \
_Scheduler_default_Tick, /* tick entry point */ \
_Scheduler_default_Start_idle /* start idle entry point */ \
SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
void _Scheduler_CBS_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Definition: schedulercbsnodeinit.c:23
Entry points for the Constant Bandwidth Server Scheduler.
Note
: The CBS scheduler is an enhancement of EDF scheduler, therefor some routines are similar.
Typedef Documentation
◆ Scheduler_CBS_Budget_overrun
Callback function invoked when a budget overrun of a task occurs.
◆ Scheduler_CBS_Server_id
Server id.
◆ _Scheduler_CBS_Attach_thread()
int _Scheduler_CBS_Attach_thread ( Scheduler_CBS_Server_id  server_id,
rtems_id  task_id
Attach a task to an already existing server.
Parameters
server_idThe id of the existing server.
task_idThe id of the task to attach.
Return values
SCHEDULER_CBS_OKThe operation was successful.
SCHEDULER_CBS_ERROR_INVALID_PARAMETERThe server id is so big or there is no thread for this task id.
SCHEDULER_CBS_ERROR_NOSERVERThe server is not yet initialized.
SCHEDULER_CBS_ERROR_FULLThe server already has a task.
◆ _Scheduler_CBS_Budget_callout()
void _Scheduler_CBS_Budget_callout ( Thread_Control *  the_thread)
This routine is invoked when a limited time quantum is exceeded.
Parameters
the_threadThe thread that exceeded a limited time quantum.
◆ _Scheduler_CBS_Cancel_job()
void _Scheduler_CBS_Cancel_job ( const Scheduler_Control *  scheduler,
Thread_Control *  the_thread,
Priority_Node *  priority_node,
Thread_queue_Context *  queue_context
Cancels a job.
Parameters
schedulerThe scheduler for the operation.
the_threadThe corresponding thread.
priority_nodeThe priority node for the operation.
queue_contextThe thread queue context.
◆ _Scheduler_CBS_Cleanup()
int _Scheduler_CBS_Cleanup ( void  )
Cleanup resources associated to the CBS Library.
Returns
This method always returns SCHEDULER_CBS_OK.
◆ _Scheduler_CBS_Create_server()
int _Scheduler_CBS_Create_server ( Scheduler_CBS_Parameters *  params,
rtems_id *  server_id
Create a new server with specified parameters.
Parameters
paramsThe parameters for the server.
budget_overrun_callbackThe budget overrun for the new server.
[out]server_idIn the case of success, this parameter contains the id of the newly created server.
Return values
SCHEDULER_CBS_OKThe operation succeeded.
SCHEDULER_CBS_ERROR_INVALID_PARAMETERThe given parameters are invalid.
SCHEDULER_CBS_ERROR_FULLThe maximum number of servers was already created, a new server cannot be created.
◆ _Scheduler_CBS_Destroy_server()
int _Scheduler_CBS_Destroy_server ( Scheduler_CBS_Server_id  server_id)
Detach all tasks from a server and destroy it.
Parameters
server_idThe id of the server to destroy.
Return values
SCHEDULER_CBS_ERROR_INVALID_PARAMETERThe server id is too big.
SCHEDULER_CBS_ERROR_NOSERVERThere is no initialized server with this id.
◆ _Scheduler_CBS_Detach_thread()
int _Scheduler_CBS_Detach_thread ( Scheduler_CBS_Server_id  server_id,
rtems_id  task_id
Detach from the CBS Server.
Parameters
Return values
SCHEDULER_CBS_ERROR_INVALID_PARAMETERThe server id is to big, or the task with this id is not attached to this server or there is no thread with this task.
◆ _Scheduler_CBS_Get_approved_budget()
int _Scheduler_CBS_Get_approved_budget ( Scheduler_CBS_Server_id  server_id,
time_t *  approved_budget
Retrieve the budget that has been approved for the subsequent server instances.
Parameters
server_idThe id of the server instance of which the budget is wanted.
[out]approved_budgetContains the approved budget after a successful method call.
Return values
◆ _Scheduler_CBS_Get_execution_time()
int _Scheduler_CBS_Get_execution_time ( Scheduler_CBS_Server_id  server_id,
time_t *  exec_time,
time_t *  abs_time
Retrieve time info relative to server_id. The server status code is returned.
Parameters
server_idis the server to get the status code from.
[out]exec_timeContains the execution time after a successful method call.
abs_timeNot apparently used.
Return values
◆ _Scheduler_CBS_Get_parameters()
int _Scheduler_CBS_Get_parameters ( Scheduler_CBS_Server_id  server_id,
Retrieve CBS scheduling parameters.
Parameters
server_idThe id of the server to get the scheduling parameters from.
[out]paramsWill contain the scheduling parameters after successful method call.
Return values
◆ _Scheduler_CBS_Get_remaining_budget()
int _Scheduler_CBS_Get_remaining_budget ( Scheduler_CBS_Server_id  server_id,
time_t *  remaining_budget
Retrieve remaining budget for the current server instance.
Parameters
server_idThe id of the server instance of which the remaining budget is wanted.
[out]remaining_budgetContains the remaining budget after a successful method call.
Return values
◆ _Scheduler_CBS_Get_server_id()
int _Scheduler_CBS_Get_server_id ( rtems_id  task_id,
Scheduler_CBS_Server_id *  server_id
Get a thread server id, or SCHEDULER_CBS_ERROR_NOT_FOUND if it is not attached to any server.
Parameters
task_idThe id of the task to get the corresponding server.
[out]server_idWill contain the server id after successful method call.
Return values
SCHEDULER_CBS_ERROR_NOSERVERThere is no server with this task attached.
◆ _Scheduler_CBS_Initialize()
int _Scheduler_CBS_Initialize ( void  )
Initializes the CBS library.
Returns
SCHEDULER_CBS_OK This method always returns this status.
◆ _Scheduler_CBS_Node_downcast()
RTEMS_INLINE_ROUTINE Scheduler_CBS_Node* _Scheduler_CBS_Node_downcast ( Scheduler_Node *  node)
Parameters
nodeThe node to be casted to a scheduler CBS node.
Returns
CBS Node pointer to node.
◆ _Scheduler_CBS_Node_initialize()
void _Scheduler_CBS_Node_initialize ( const Scheduler_Control *  scheduler,
Scheduler_Node *  node,
Parameters
schedulerThe scheduler control for the operation.
[out]nodeThe scheduler node to initalize.
the_threadThe thread to initialize a scheduler node for.
priorityThe priority for the node.
◆ _Scheduler_CBS_Release_job()
void _Scheduler_CBS_Release_job ( const Scheduler_Control *  scheduler,
uint64_t  deadline,
Releases a job.
Parameters
deadlineThe deadline for the job.
◆ _Scheduler_CBS_Set_parameters()
int _Scheduler_CBS_Set_parameters ( Scheduler_CBS_Server_id  server_id,
Scheduler_CBS_Parameters *  parameters
Change CBS scheduling parameters.
Parameters
server_idThe id of the server.
parametersThe parameters to set.
Return values
SCHEDULER_CBS_ERROR_INVALID_PARAMETERThe server id is too big or the given parameters are invalid.
SCHEDULER_CBS_ERROR_NOSERVERThere is no server with this id.
◆ _Scheduler_CBS_Thread_get_node()
RTEMS_INLINE_ROUTINE Scheduler_CBS_Node* _Scheduler_CBS_Thread_get_node ( Thread_Control *  the_thread)
Parameters
the_threadThe thread to get the CBS node of.
Returns
Pointer to the scheduler node of the_thread.
◆ _Scheduler_CBS_Unblock()
void _Scheduler_CBS_Unblock ( const Scheduler_Control *  scheduler,
Unblocks a thread.
Parameters
schedulerThe scheduler control.
the_threadThe thread to unblock.
nodeThe scheduler node.
Variable Documentation
◆ _Scheduler_CBS_Maximum_servers
Maximum number of simultaneous servers.
◆ _Scheduler_CBS_Server_list
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
List of servers. The Scheduler_CBS_Server is the index to the array of pointers to _Scheduler_CBS_Server_list.
