RTEMS  5.1
scheduler.h
1
12 /*
13  * Copyright (C) 2010 Gedare Bloom.
14  * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_SCORE_SCHEDULER_H
22 #define _RTEMS_SCORE_SCHEDULER_H
23
24 #include <rtems/score/thread.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
30 struct Per_CPU_Control;
31
44
48 typedef struct {
50  void ( *initialize )( const Scheduler_Control * );
51
53  void ( *schedule )( const Scheduler_Control *, Thread_Control *);
54
56  void ( *yield )(
57  const Scheduler_Control *,
60  );
61
63  void ( *block )(
64  const Scheduler_Control *,
67  );
68
70  void ( *unblock )(
71  const Scheduler_Control *,
74  );
75
77  void ( *update_priority )(
78  const Scheduler_Control *,
81  );
82
84  Priority_Control ( *map_priority )(
85  const Scheduler_Control *,
87  );
88
90  Priority_Control ( *unmap_priority )(
91  const Scheduler_Control *,
93  );
94
95 #if defined(RTEMS_SMP)
96
106  bool ( *ask_for_help )(
107  const Scheduler_Control *scheduler,
108  Thread_Control *the_thread,
109  Scheduler_Node *node
110  );
111
120  void ( *reconsider_help_request )(
121  const Scheduler_Control *scheduler,
122  Thread_Control *the_thread,
123  Scheduler_Node *node
124  );
125
135  void ( *withdraw_node )(
136  const Scheduler_Control *scheduler,
137  Thread_Control *the_thread,
138  Scheduler_Node *node,
139  Thread_Scheduler_state next_state
140  );
141
150  void ( *pin )(
151  const Scheduler_Control *scheduler,
152  Thread_Control *the_thread,
153  Scheduler_Node *node,
154  struct Per_CPU_Control *cpu
155  );
156
165  void ( *unpin )(
166  const Scheduler_Control *scheduler,
167  Thread_Control *the_thread,
168  Scheduler_Node *node,
169  struct Per_CPU_Control *cpu
170  );
171
178  void ( *add_processor )(
179  const Scheduler_Control *scheduler,
180  Thread_Control *idle
181  );
182
191  Thread_Control *( *remove_processor )(
192  const Scheduler_Control *scheduler,
193  struct Per_CPU_Control *cpu
194  );
195 #endif
196
198  void ( *node_initialize )(
199  const Scheduler_Control *,
200  Scheduler_Node *,
201  Thread_Control *,
203  );
204
206  void ( *node_destroy )( const Scheduler_Control *, Scheduler_Node * );
207
209  void ( *release_job ) (
210  const Scheduler_Control *,
211  Thread_Control *,
212  Priority_Node *,
213  uint64_t,
215  );
216
218  void ( *cancel_job ) (
219  const Scheduler_Control *,
220  Thread_Control *,
221  Priority_Node *,
223  );
224
226  void ( *tick )( const Scheduler_Control *, Thread_Control * );
227
229  void ( *start_idle )(
230  const Scheduler_Control *,
231  Thread_Control *,
232  struct Per_CPU_Control *
233  );
234
235 #if defined(RTEMS_SMP)
236
237  bool ( *set_affinity )(
238  const Scheduler_Control *,
239  Thread_Control *,
240  Scheduler_Node *,
241  const Processor_mask *
242  );
243 #endif
245
252 typedef struct Scheduler_Context {
256  ISR_LOCK_MEMBER( Lock )
257
258 #if defined(RTEMS_SMP)
259
262  Processor_mask Processors;
263 #endif
265
274
279
287
291  uint32_t name;
292
293 #if defined(RTEMS_SMP)
294
298  bool is_non_preempt_mode_supported;
299 #endif
300 };
301
309 extern const Scheduler_Control _Scheduler_Table[];
310
322 #if defined(RTEMS_SMP)
323  extern const size_t _Scheduler_Count;
324 #else
325  #define _Scheduler_Count ( (size_t) 1 )
326 #endif
327
328 #if defined(RTEMS_SMP)
329
332  #define SCHEDULER_ASSIGN_DEFAULT UINT32_C(0x0)
333
337  #define SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL SCHEDULER_ASSIGN_DEFAULT
338
342  #define SCHEDULER_ASSIGN_PROCESSOR_MANDATORY UINT32_C(0x1)
343
347  typedef struct {
351  const Scheduler_Control *scheduler;
352
362  uint32_t attributes;
363  } Scheduler_Assignment;
364
374  extern const Scheduler_Assignment _Scheduler_Initial_assignments[];
375 #endif
376
387  const Scheduler_Control *scheduler,
388  Priority_Control priority
389 );
390
401  const Scheduler_Control *scheduler,
402  Priority_Control priority
403 );
404
405 #if defined(RTEMS_SMP)
406
415  bool _Scheduler_default_Ask_for_help(
416  const Scheduler_Control *scheduler,
417  Thread_Control *the_thread,
418  Scheduler_Node *node
419  );
420
428  void _Scheduler_default_Reconsider_help_request(
429  const Scheduler_Control *scheduler,
430  Thread_Control *the_thread,
431  Scheduler_Node *node
432  );
433
442  void _Scheduler_default_Withdraw_node(
443  const Scheduler_Control *scheduler,
444  Thread_Control *the_thread,
445  Scheduler_Node *node,
446  Thread_Scheduler_state next_state
447  );
448
458  void _Scheduler_default_Pin_or_unpin(
459  const Scheduler_Control *scheduler,
460  Thread_Control *the_thread,
461  Scheduler_Node *node,
462  struct Per_CPU_Control *cpu
463  );
464
465  #define SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP \
466  _Scheduler_default_Ask_for_help, \
467  _Scheduler_default_Reconsider_help_request, \
468  _Scheduler_default_Withdraw_node, \
469  _Scheduler_default_Pin_or_unpin, \
470  _Scheduler_default_Pin_or_unpin, \
471  NULL, \
472  NULL,
473 #else
474  #define SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP
475 #endif
476
484  const Scheduler_Control *scheduler,
485  Thread_Control *the_thread
486 );
487
497  const Scheduler_Control *scheduler,
498  Scheduler_Node *node,
499  Thread_Control *the_thread,
500  Priority_Control priority
501 );
502
510  const Scheduler_Control *scheduler,
511  Scheduler_Node *node
512 );
513
526  const Scheduler_Control *scheduler,
527  Thread_Control *the_thread,
528  Priority_Node *priority_node,
529  uint64_t deadline,
530  Thread_queue_Context *queue_context
531 );
532
544  const Scheduler_Control *scheduler,
545  Thread_Control *the_thread,
546  Priority_Node *priority_node,
547  Thread_queue_Context *queue_context
548 );
549
560  const Scheduler_Control *scheduler,
561  Thread_Control *executing
562 );
563
572  const Scheduler_Control *scheduler,
573  Thread_Control *the_thread,
574  struct Per_CPU_Control *cpu
575 );
576
577 #if defined(RTEMS_SMP)
578
591  bool _Scheduler_default_Set_affinity(
592  const Scheduler_Control *scheduler,
593  Thread_Control *thread,
594  Scheduler_Node *node,
595  const Processor_mask *affinity
596  );
597
598  #define SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
599  , _Scheduler_default_Set_affinity
600 #else
601  #define SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY
602 #endif
603
608 #define PRIORITY_MAXIMUM ( _Scheduler_Table[ 0 ].maximum_priority )
609
612 #ifdef __cplusplus
613 }
614 #endif
615
616 #endif
617 /* end of include file */
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
void _Scheduler_default_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Does nothing.
Definition: schedulerdefaultreleasejob.c:24
Scheduler context.
Definition: scheduler.h:252
The scheduler operations.
Definition: scheduler.h:48
Thread queue context for the thread queue methods.
Definition: threadq.h:198
The priority node to build up a priority aggregation.
Definition: priority.h:98
Priority_Control _Scheduler_default_Map_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the scheduler internal thread priority mapped by SCHEDULER_PRIORITY_MAP().
Definition: schedulerdefaultmappriority.c:15
uint32_t name
The scheduler name.
Definition: scheduler.h:291
void _Scheduler_default_Schedule(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Does nothing.
Definition: schedulerdefaultschedule.c:15
struct Scheduler_Context Scheduler_Context
Scheduler context.
Definition: thread.h:732
#define ISR_LOCK_MEMBER(_designator)
Defines an ISR lock member.
Definition: isrlock.h:89
Per CPU Core Structure.
Definition: percpu.h:347
void _Scheduler_default_Node_destroy(const Scheduler_Control *scheduler, Scheduler_Node *node)
Does nothing.
Definition: schedulerdefaultnodedestroy.c:24
Count of registered schedulers.
Definition: scheduler.h:325
Priority_Control maximum_priority
The maximum priority value of this scheduler.
Definition: scheduler.h:286
Registered schedulers.
void _Scheduler_default_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Performs the scheduler base node initialization.
Definition: schedulerdefaultnodeinit.c:24
Scheduler_Operations Operations
Definition: scheduler.h:278
Scheduler control.
Definition: scheduler.h:269
Scheduler node for per-thread data.
Definition: schedulernode.h:79
void _Scheduler_default_Tick(const Scheduler_Control *scheduler, Thread_Control *executing)
Performs tick operations depending on the CPU budget algorithm for each executing thread.
Definition: schedulerdefaulttick.c:27
void _Scheduler_default_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Does nothing.
Definition: schedulerdefaultreleasejob.c:39
Scheduler_Context * context
Reference to a statically allocated scheduler context.
Definition: scheduler.h:273
Priority_Control _Scheduler_default_Unmap_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the user visible thread priority unmapped by SCHEDULER_PRIORITY_UNMAP().
Definition: schedulerdefaultmappriority.c:23
void _Scheduler_default_Start_idle(const Scheduler_Control *scheduler, Thread_Control *the_thread, struct Per_CPU_Control *cpu)
Starts an idle thread.
Definition: schedulerdefaultstartidle.c:15
Constants and Structures Related with the Thread Control Block.
