RTEMS  5.1
RTEMS File Systems Group Routines. More...
#include <inttypes.h>
#include <rtems/rfs/rtems-rfs-group.h>
int rtems_rfs_group_open (rtems_rfs_file_system *fs, rtems_rfs_buffer_block base, size_t size, size_t inodes, rtems_rfs_group *group)
 Open a group. More...
int rtems_rfs_group_close (rtems_rfs_file_system *fs, rtems_rfs_group *group)
 Close a group. More...
int rtems_rfs_group_bitmap_alloc (rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, bool inode, rtems_rfs_bitmap_bit *result)
 Allocate an inode or block. More...
int rtems_rfs_group_bitmap_free (rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no)
 Free the group allocated bit. More...
int rtems_rfs_group_bitmap_test (rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no, bool *state)
 Test the group allocated bit. More...
int rtems_rfs_group_usage (rtems_rfs_file_system *fs, size_t *blocks, size_t *inodes)
 Determine the number of blocks and inodes used. More...
These functions open and close a group as well as manage bit allocations within a group.
◆ rtems_rfs_group_bitmap_alloc()
int rtems_rfs_group_bitmap_alloc ( rtems_rfs_file_system *  fs,
bool  inode,
rtems_rfs_bitmap_bit *  result
The groups are searched to find the next available inode or block.
Parameters
fsThe file system data.
goalThe goal to seed the bitmap search.
inodeIf true allocate an inode else allocate a block.
resultThe allocated bit in the bitmap.
Return values
intThe error number (errno). No error if 0.
◆ rtems_rfs_group_bitmap_free()
int rtems_rfs_group_bitmap_free ( rtems_rfs_file_system *  fs,
bool  inode,
Parameters
inodeIf true the number to free is an inode else it is a block.
blockThe inode or block number to free.
Return values
◆ rtems_rfs_group_bitmap_test()
int rtems_rfs_group_bitmap_test ( rtems_rfs_file_system *  fs,
bool  inode,
bool *  state
Parameters
stateReturn the state of the bit.
Return values
◆ rtems_rfs_group_close()
int rtems_rfs_group_close ( rtems_rfs_file_system *  fs,
rtems_rfs_group *  group
Close a group.
Release all resources the group holds.
Parameters
fsThe file system.
groupThe group to close.
Return values
◆ rtems_rfs_group_open()
int rtems_rfs_group_open ( rtems_rfs_file_system *  fs,
size_t  size,
size_t  inodes,
Open a group.
Allocate all the resources including the bitmaps.
Parameters
fsThe file system.
baseThe base block number.
sizeThe number of blocks in the group.
groupReference to the group to open.
Return values
◆ rtems_rfs_group_usage()
int rtems_rfs_group_usage ( rtems_rfs_file_system *  fs,
size_t *  blocks,
size_t *  inodes
Parameters
blocksThe number of blocks used.
inodesThe number of inodes used.
Return values
