RTEMS  5.1
qreslib.h File Reference
Constants and Structures Associated with the QoS RES library in RTEMS. More...
#include <stdint.h>
#include <rtems/score/schedulercbs.h>
struct  qres_params_t
#define QOS_OK   SCHEDULER_CBS_OK
#define QOS_E_GENERIC   SCHEDULER_CBS_ERROR_GENERIC
#define QOS_E_NO_MEMORY   SCHEDULER_CBS_ERROR_NO_MEMORY
#define QOS_E_INVALID_PARAM   SCHEDULER_CBS_ERROR_INVALID_PARAMETER
#define QOS_E_UNAUTHORIZED   SCHEDULER_CBS_ERROR_UNAUTHORIZED
#define QOS_E_UNIMPLEMENTED   SCHEDULER_CBS_ERROR_UNIMPLEMENTED
#define QOS_E_MISSING_COMPONENT   SCHEDULER_CBS_ERROR_MISSING_COMPONENT
#define QOS_E_INCONSISTENT_STATE   SCHEDULER_CBS_ERROR_INCONSISTENT_STATE
#define QOS_E_SYSTEM_OVERLOAD   SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD
#define QOS_E_INTERNAL_ERROR   SCHEDULER_CBS_ERROR_INTERNAL_ERROR
#define QOS_E_NOT_FOUND   SCHEDULER_CBS_ERROR_NOT_FOUND
#define QOS_E_FULL   SCHEDULER_CBS_ERROR_FULL
#define QOS_E_EMPTY   SCHEDULER_CBS_ERROR_EMPTY
#define QOS_E_NOSERVER   SCHEDULER_CBS_ERROR_NOSERVER
typedef int qos_rv
typedef Scheduler_CBS_Server_id qres_sid_t
typedef rtems_id tid_t
typedef time_t qres_time_t
typedef time_t qres_atime_t
RTEMS_INLINE_ROUTINE qos_rv qres_init (void)
 qres init More...
RTEMS_INLINE_ROUTINE qos_rv qres_cleanup (void)
 qres cleanup More...
RTEMS_INLINE_ROUTINE qos_rv qres_create_server (qres_params_t *params, qres_sid_t *server_id)
 qres create server More...
RTEMS_INLINE_ROUTINE qos_rv qres_attach_thread (qres_sid_t server_id, pid_t pid, tid_t task_id)
 qres attach thread More...
RTEMS_INLINE_ROUTINE qos_rv qres_detach_thread (qres_sid_t server_id, pid_t pid, tid_t task_id)
 qres detach thread More...
RTEMS_INLINE_ROUTINE qos_rv qres_destroy_server (qres_sid_t server_id)
 qres destroy server More...
RTEMS_INLINE_ROUTINE qos_rv qres_get_sid (pid_t pid, tid_t task_id, qres_sid_t *server_id)
 qres get server id More...
RTEMS_INLINE_ROUTINE qos_rv qres_get_params (qres_sid_t server_id, qres_params_t *params)
 qres get params More...
RTEMS_INLINE_ROUTINE qos_rv qres_set_params (qres_sid_t server_id, qres_params_t *params)
 qres set params More...
RTEMS_INLINE_ROUTINE qos_rv qres_get_exec_time (qres_sid_t server_id, qres_time_t *exec_time, qres_atime_t *abs_time)
 qres get execution time More...
RTEMS_INLINE_ROUTINE qos_rv qres_get_curr_budget (qres_sid_t server_id, qres_time_t *current_budget)
 qres get current budget More...
RTEMS_INLINE_ROUTINE qos_rv qres_get_appr_budget (qres_sid_t server_id, qres_time_t *appr_budget)
 qres get approved budget More...
This include file contains all the constants and structures associated with the QoS RES library in RTEMS.
Note
The library is available only together with CBS scheduler.
Typedef Documentation
◆ qos_rv
typedef int qos_rv
Return values.
◆ qres_atime_t
Absolute time value
◆ qres_sid_t
Server id.
◆ qres_time_t
Time value.
◆ tid_t
Task id.
◆ qres_attach_thread()
RTEMS_INLINE_ROUTINE qos_rv qres_attach_thread ( qres_sid_t  server_id,
pid_t  pid,
tid_t  task_id
qres attach thread
Attach a task to an already existing server.
Returns
status code.
◆ qres_cleanup()
RTEMS_INLINE_ROUTINE qos_rv qres_cleanup ( void  )
qres cleanup
Cleanup resources associated to the QoS RES Library.
Returns
status code.
◆ qres_create_server()
RTEMS_INLINE_ROUTINE qos_rv qres_create_server ( qres_params_t *  params,
qres_sid_t *  server_id
qres create server
Create a new server with specified parameters.
Returns
status code.
◆ qres_destroy_server()
RTEMS_INLINE_ROUTINE qos_rv qres_destroy_server ( qres_sid_t  server_id)
qres destroy server
Detach all tasks from a server and destroy it.
Returns
status code.
◆ qres_detach_thread()
RTEMS_INLINE_ROUTINE qos_rv qres_detach_thread ( qres_sid_t  server_id,
pid_t  pid,
tid_t  task_id
qres detach thread
Detach from the QoS Server.
Returns
status code.
◆ qres_get_appr_budget()
RTEMS_INLINE_ROUTINE qos_rv qres_get_appr_budget ( qres_sid_t  server_id,
qres_time_t *  appr_budget
Retrieve the budget that has been approved for the subsequent server instances.
Returns
status code.
◆ qres_get_curr_budget()
RTEMS_INLINE_ROUTINE qos_rv qres_get_curr_budget ( qres_sid_t  server_id,
qres_time_t *  current_budget
Retrieve remaining budget for the current server instance.
Returns
status code.
◆ qres_get_exec_time()
RTEMS_INLINE_ROUTINE qos_rv qres_get_exec_time ( qres_sid_t  server_id,
qres_time_t *  exec_time,
qres_atime_t *  abs_time
Retrieve time info relative to the current server.
Returns
status code.
◆ qres_get_params()
RTEMS_INLINE_ROUTINE qos_rv qres_get_params ( qres_sid_t  server_id,
qres get params
Retrieve QoS scheduling parameters.
Returns
status code.
◆ qres_get_sid()
RTEMS_INLINE_ROUTINE qos_rv qres_get_sid ( pid_t  pid,
tid_t  task_id,
qres get server id
Get a thread server id, or QOS_E_NOT_FOUND if it is not attached to any server.
Returns
status code.
◆ qres_init()
RTEMS_INLINE_ROUTINE qos_rv qres_init ( void  )
qres init
Initializes the QoS RES library.
Returns
status code.
◆ qres_set_params()
RTEMS_INLINE_ROUTINE qos_rv qres_set_params ( qres_sid_t  server_id,
qres set params
Change QoS scheduling parameters.
Returns
status code.
