#define | CPU_ISR_PASSES_FRAME_POINTER TRUE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 32 |
#define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define | CPU_MODES_INTERRUPT_MASK 0x00000001 |
#define | or1kreg uint32_t |
#define | _CPU_Context_Get_SP(_context) (_context)->r1 |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_STACK_MINIMUM_SIZE 4096 |
#define | CPU_ALIGNMENT 8 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
| #define | CPU_SIZEOF_POINTER 4 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 0 |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | _CPU_Initialize_vectors() |
#define | _CPU_ISR_Disable(_level) _level = or1k_interrupt_disable() |
#define | _CPU_ISR_Enable(_level) or1k_interrupt_enable( _level ) |
| #define | _CPU_ISR_Flash(_level) |
#define | OR1K_FAST_CONTEXT_SWITCH_ENABLED FALSE |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | _CPU_Fatal_halt(_source, _error) |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
| RTEMS_INLINE_ROUTINE bool | _CPU_ISR_Is_enabled (uint32_t level) |
| | Returns true if interrupts are enabled in the specified ISR level, otherwise returns false. More...
| void | _CPU_ISR_Set_level (uint32_t level) |
| | Sets the interrupt level for the executing thread. More...
| uint32_t | _CPU_ISR_Get_level (void) |
| | Returns the interrupt level of the executing thread. More...
| void | _CPU_Context_Initialize (Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| | Initializes the CPU context. More...
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| | Prints the exception frame via printk(). More...
| void | _CPU_Initialize (void) |
| | CPU initialization. More...
void | _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler) |
| RTEMS_INLINE_ROUTINE void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
| | SPARC specific RTEMS ISR installer. More...
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| | CPU switch context. More...
| void | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
void | _CPU_Context_save_fp (void **fp_context_ptr) |
void | _CPU_Context_restore_fp (void **fp_context_ptr) |
| uint32_t | _CPU_Counter_frequency (void) |
| | Returns the current CPU counter frequency in Hz. More...
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| | Returns the current CPU counter value. More...
