22 #ifndef _RTEMS_SCORE_CPU_H    23 #define _RTEMS_SCORE_CPU_H    32 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE    34 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 32    36 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)    38 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS TRUE    40 #define CPU_ISR_PASSES_FRAME_POINTER FALSE    42 #define CPU_HARDWARE_FP FALSE    44 #define CPU_SOFTWARE_FP FALSE    46 #define CPU_ALL_TASKS_ARE_FP FALSE    48 #define CPU_IDLE_TASK_IS_FP FALSE    50 #define CPU_USE_DEFERRED_FP_SWITCH FALSE    52 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE    54 #define CPU_STACK_GROWS_UP FALSE    57 #define CPU_CACHE_LINE_BYTES 32    59 #define CPU_STRUCTURE_ALIGNMENT \    60   RTEMS_SECTION( ".sdata" ) RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )    62 #define CPU_STACK_MINIMUM_SIZE (4 * 1024)    64 #define CPU_SIZEOF_POINTER 4    70 #define CPU_ALIGNMENT 4    72 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT    78 #define CPU_STACK_ALIGNMENT 4    80 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES    89 #define CPU_MODES_INTERRUPT_MASK 0x3f    91 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE    93 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0    95 #define CPU_MAXIMUM_PROCESSORS 32   126   uint32_t thread_dispatch_disabled;
   127   uint32_t stack_mpubase;
   128   uint32_t stack_mpuacc;
   131 #define _CPU_Context_Get_SP( _context ) \   171 #define _CPU_Initialize_vectors()   193 #define _CPU_ISR_Disable( _isr_cookie ) \   197       "rdctl %0, status\n" \   198       "movhi %1, %%hiadj(_Nios2_ISR_Status_mask)\n" \   199       "addi %1, %1, %%lo(_Nios2_ISR_Status_mask)\n" \   201       "ori %1, %1, %%lo(_Nios2_ISR_Status_bits)\n" \   203       : "=&r" (_isr_cookie), "=&r" (_tmp) \   213 #define _CPU_ISR_Enable( _isr_cookie ) \   214   __builtin_wrctl( 0, (int) _isr_cookie )   227 #define _CPU_ISR_Flash( _isr_cookie ) \   229     int _status = __builtin_rdctl( 0 ); \   230     __builtin_wrctl( 0, (int) _isr_cookie ); \   231     __builtin_wrctl( 0, _status ); \   280   void *stack_area_begin,
   281   size_t stack_area_size,
   283   void (*entry_point)(
void ),
   288 #define _CPU_Context_Restart_self( _the_context ) \   289   _CPU_Context_restore( (_the_context) );   299 typedef void ( *CPU_ISR_handler )( uint32_t );
   303   CPU_ISR_handler  new_handler,
   304   CPU_ISR_handler *old_handler
   317 static inline uint32_t CPU_swap_u32( uint32_t value )
   319   uint32_t byte1, byte2, byte3, byte4, swapped;
   321   byte4 = (value >> 24) & 0xff;
   322   byte3 = (value >> 16) & 0xff;
   323   byte2 = (value >> 8)  & 0xff;
   324   byte1 =  value        & 0xff;
   326   swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
   331 #define CPU_swap_u16( value ) \   332   (((value&0xff) << 8) | ((value >> 8)&0xff))   340 static inline CPU_Counter_ticks _CPU_Counter_difference(
   341   CPU_Counter_ticks second,
   342   CPU_Counter_ticks first
   345   return second - first;
 #define sp
stack-pointer */
Definition: regs.h:64
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:57
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define fp
frame-pointer */
Definition: regs.h:65
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
NIOS II Set up Basic CPU Dependency Settings Based on Compiler Settings.
void _CPU_Fatal_halt(uint32_t source, uint32_t error) RTEMS_NO_RETURN
Definition: bsp_fatal_halt.c:12
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
unsigned context
Definition: tlb.h:108
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
#define ra
return address */
Definition: regs.h:66
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define gp
global data pointer */
Definition: regs.h:63
