    RTEMS
    5.1
| struct | Context_Control |
| Thread register context.  More... | |
| struct | CPU_Exception_frame |
| The set of registers that specifies the complete processor state.  More... | |
| #define | CPU_SIMPLE_VECTORED_INTERRUPTS TRUE |
| #define | CPU_INTERRUPT_NUMBER_OF_VECTORS 32 |
| #define | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
| #define | CPU_PROVIDES_ISR_IS_IN_PROGRESS TRUE |
| #define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
| #define | CPU_HARDWARE_FP FALSE |
| #define | CPU_SOFTWARE_FP FALSE |
| #define | CPU_ALL_TASKS_ARE_FP FALSE |
| #define | CPU_IDLE_TASK_IS_FP FALSE |
| #define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
| #define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
| #define | CPU_STACK_GROWS_UP FALSE |
| #define | CPU_CACHE_LINE_BYTES 32 |
| #define | CPU_STRUCTURE_ALIGNMENT RTEMS_SECTION( ".sdata" ) RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
| #define | CPU_STACK_MINIMUM_SIZE (4 * 1024) |
| #define | CPU_SIZEOF_POINTER 4 |
| #define | CPU_ALIGNMENT 4 |
| #define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_STACK_ALIGNMENT 4 |
| #define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
| #define | CPU_MODES_INTERRUPT_MASK 0x3f |
| #define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
| #define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
| #define | CPU_MAXIMUM_PROCESSORS 32 |
| #define | _CPU_Context_Get_SP(_context) (_context)->sp |
| #define | _CPU_Initialize_vectors() |
| #define | _CPU_ISR_Disable(_isr_cookie) |
| Macro to disable interrupts.  More... | |
| #define | _CPU_ISR_Enable(_isr_cookie) __builtin_wrctl( 0, (int) _isr_cookie ) |
| Macro to restore the processor status.  More... | |
| #define | _CPU_ISR_Flash(_isr_cookie) |
| Macro to restore the processor status and disable the interrupts again.  More... | |
| #define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
Typedefs | |
| typedef void | CPU_Interrupt_frame |
| typedef void(* | CPU_ISR_handler) (uint32_t) |
| typedef uint32_t | CPU_Counter_ticks |
| typedef uintptr_t | CPU_Uint32ptr |
| bool | _CPU_ISR_Is_enabled (uint32_t level) |
| Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.  More... | |
| void | _CPU_ISR_Set_level (uint32_t new_level) |
| Sets the interrupt level for the executing thread.  More... | |
| uint32_t | _CPU_ISR_Get_level (void) |
| Returns the interrupt level of the executing thread.  More... | |
| void | _CPU_Context_Initialize (Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| Initializes the CPU context.  More... | |
| void | _CPU_Fatal_halt (uint32_t _source, uint32_t _error) RTEMS_NO_RETURN |
| void | _CPU_Initialize (void) |
| CPU initialization.  More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| CPU switch context.  More... | |
| void | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| Prints the exception frame via printk().  More... | |
| uint32_t | _CPU_Counter_frequency (void) |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| #define _CPU_ISR_Disable | ( | _isr_cookie | ) |
The processor status before disabling the interrupts will be stored in _isr_cookie. This value will be used in _CPU_ISR_Flash() and _CPU_ISR_Enable().
The global symbol _Nios2_ISR_Status_mask will be used to clear the bits in the status register representing the interrupt level. The global symbol _Nios2_ISR_Status_bits will be used to set the bits representing an interrupt level that disables interrupts. Both global symbols must be provided by the board support package.
In case the Nios II uses the internal interrupt controller (IIC), then only the PIE status bit is used.
In case the Nios II uses the external interrupt controller (EIC), then the RSIE status bit or the IL status field is used depending on the interrupt handling variant and the shadow register usage.
| #define _CPU_ISR_Enable | ( | _isr_cookie | ) | __builtin_wrctl( 0, (int) _isr_cookie ) |
The _isr_cookie must contain the processor status returned by _CPU_ISR_Disable(). The value is not modified.
| #define _CPU_ISR_Flash | ( | _isr_cookie | ) |
This flash code is optimal for all Nios II configurations. The rdctl does not flush the pipeline and has only a late result penalty. The wrctl on the other hand leads to a pipeline flush.
| typedef uintptr_t CPU_Uint32ptr |
Type that can store a 32-bit integer or a pointer.
 1.8.15
