38 #ifndef LIBCPU_POWERPC_MPC55XX_H    39 #define LIBCPU_POWERPC_MPC55XX_H    50 int mpc55xx_flash_copy(
void *dest,
const void *src,
size_t nbytes);
    51 int mpc55xx_flash_copy_op(
void *rdest,
const void *src,
size_t nbytes,
    52   uint32_t opmask, uint32_t *p_fail_addr);
    53 int mpc55xx_flash_size(uint32_t *p_size);
    54 int mpc55xx_flash_writable(
void);
    55 uint32_t mpc55xx_flash_address(
void);
    56 void mpc55xx_flash_set_read_only(
void);
    57 void mpc55xx_flash_set_read_write(
void);
    59 int mpc55xx_physical_address(
const void *addr, uint32_t *p_result);
    60 int mpc55xx_mapped_address(
    63 #define MPC55XX_FLASH_BLANK_CHECK 0x01    64 #define MPC55XX_FLASH_UNLOCK      0x02    65 #define MPC55XX_FLASH_ERASE       0x04    66 #define MPC55XX_FLASH_PROGRAM     0x08    67 #define MPC55XX_FLASH_VERIFY      0x10    79 #define MPC55XX_FLASH_CONFIG_ERR    (-1)    80 #define MPC55XX_FLASH_SIZE_ERR      (-2)    81 #define MPC55XX_FLASH_RANGE_ERR     (-3)    82 #define MPC55XX_FLASH_ERASE_ERR     (-4)    83 #define MPC55XX_FLASH_PROGRAM_ERR   (-5)    84 #define MPC55XX_FLASH_NOT_BLANK_ERR (-6)    85 #define MPC55XX_FLASH_VERIFY_ERR    (-7)    86 #define MPC55XX_FLASH_LOCK_ERR      (-8)    88 #define MPC55XX_CACHE_ALIGNED_MASK ((uintptr_t) 0x1f)    90 #define MPC55XX_CACHE_LINE_SIZE 32    95 static inline int mpc55xx_is_cache_aligned(
const void *s,
size_t n)
    97     return !(((uintptr_t) s & MPC55XX_CACHE_ALIGNED_MASK) || (n & MPC55XX_CACHE_ALIGNED_MASK));
   100 static inline uintptr_t mpc55xx_cache_aligned_start(
const void *s)
   102     return ((uintptr_t) s & MPC55XX_CACHE_ALIGNED_MASK) ? (((uintptr_t) s & ~MPC55XX_CACHE_ALIGNED_MASK) + MPC55XX_CACHE_LINE_SIZE) : (uintptr_t)s;
   105 static inline size_t mpc55xx_non_cache_aligned_size(
const void *s)
   107     return (uintptr_t) mpc55xx_cache_aligned_start( s) - (uintptr_t) s;
   110 static inline size_t mpc55xx_cache_aligned_size(
const void *s,
size_t n)
   112     return (n - mpc55xx_non_cache_aligned_size( s)) & ~MPC55XX_CACHE_ALIGNED_MASK;
   118 static inline uint32_t mpc55xx_count_leading_zeros( uint32_t value)
   129 static inline void mpc55xx_wait_for_interrupt(
void)
   131   #ifdef MPC55XX_HAS_WAIT_INSTRUCTION   138 static inline void mpc55xx_mmu_apply_config(
const struct MMU_tag *
config)
 Definition: deflate.c:115
Definition: regs-mmu.h:66
#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val)
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:576
General purpose assembler macros, linker command file support and some inline functions for direct re...
Register definitions for the MPC55xx and MPC56xx microcontroller family.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
