Documentation for this file.
More...
#define  | MPC55XX_FLASH_BLANK_CHECK   0x01 |
#define  | MPC55XX_FLASH_UNLOCK   0x02 |
#define  | MPC55XX_FLASH_ERASE   0x04 |
#define  | MPC55XX_FLASH_PROGRAM   0x08 |
#define  | MPC55XX_FLASH_VERIFY   0x10 |
#define  | MPC55XX_FLASH_CONFIG_ERR   (-1) |
#define  | MPC55XX_FLASH_SIZE_ERR   (-2) |
#define  | MPC55XX_FLASH_RANGE_ERR   (-3) |
#define  | MPC55XX_FLASH_ERASE_ERR   (-4) |
#define  | MPC55XX_FLASH_PROGRAM_ERR   (-5) |
#define  | MPC55XX_FLASH_NOT_BLANK_ERR   (-6) |
#define  | MPC55XX_FLASH_VERIFY_ERR   (-7) |
#define  | MPC55XX_FLASH_LOCK_ERR   (-8) |
#define  | MPC55XX_CACHE_ALIGNED_MASK   ((uintptr_t) 0x1f) |
#define  | MPC55XX_CACHE_LINE_SIZE   32 |
int  | mpc55xx_flash_copy (void *dest, const void *src, size_t nbytes) |
int  | mpc55xx_flash_copy_op (void *rdest, const void *src, size_t nbytes, uint32_t opmask, uint32_t *p_fail_addr) |
int  | mpc55xx_flash_size (uint32_t *p_size) |
int  | mpc55xx_flash_writable (void) |
uint32_t  | mpc55xx_flash_address (void) |
void  | mpc55xx_flash_set_read_only (void) |
void  | mpc55xx_flash_set_read_write (void) |
int  | mpc55xx_physical_address (const void *addr, uint32_t *p_result) |
int  | mpc55xx_mapped_address (const void *addr, uint32_t *p_result) |
