    RTEMS
    5.1
PowerPC Utility Module. More...
| #define | LINKER_SYMBOL(sym) extern char sym []; |
| #define | CPU_Get_timebase_low(_value) __asm__ volatile( "mfspr %0,268" : "=r" (_value) ) |
| #define | rtems_bsp_delay(_microseconds) |
| #define | rtems_bsp_delay_in_bus_cycles(_cycles) |
| #define | PPC_Set_decrementer(_clicks) |
| #define | PPC_Get_decrementer(_clicks) __asm__ volatile( "mfdec %0" : "=r" (_clicks) ) |
| #define | PPC_STRINGOF(x) #x |
| Preprocessor magic for stringification of x.  | |
| #define | PPC_SPECIAL_PURPOSE_REGISTER(spr) |
| Returns the value of the Special Purpose Register with number spr.  More... | |
| #define | PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val) |
| Sets the Special Purpose Register with number spr to the value in val.  More... | |
| #define | PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits) |
| Sets in the Special Purpose Register with number spr all bits which are set in bits.  More... | |
| #define | PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED(spr, bits, mask) |
| Sets in the Special Purpose Register with number spr all bits which are set in bits. The previous register value will be masked with mask.  More... | |
| #define | PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits) |
| Clears in the Special Purpose Register with number spr all bits which are set in bits.  More... | |
| #define | PPC_THREAD_MGMT_REGISTER(tmr) |
| Returns the value of the Thread Management Register with number tmr.  More... | |
| #define | PPC_SET_THREAD_MGMT_REGISTER(tmr, val) |
| Sets the Thread Management Register with number tmr to the value in val.  More... | |
| #define | PPC_DEVICE_CONTROL_REGISTER(dcr) |
| Returns the value of the Device Control Register with number dcr.  More... | |
| #define | PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val) |
| Sets the Device Control Register with number dcr to the value in val.  More... | |
| #define | PPC_SET_DEVICE_CONTROL_REGISTER_BITS(dcr, bits) |
| Sets in the Device Control Register with number dcr all bits which are set in bits.  More... | |
| #define | PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED(dcr, bits, mask) |
| Sets in the Device Control Register with number dcr all bits which are set in bits. The previous register value will be masked with mask.  More... | |
| #define | PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS(dcr, bits) |
| Clears in the Device Control Register with number dcr all bits which are set in bits.  More... | |
| void | ppc_code_copy (void *dest, const void *src, size_t n) |
| void | printBAT (int bat, uint32_t upper, uint32_t lower) |
| void | ShowBATS (void) |
| uint32_t | bsp_clicks_per_usec |
| #define PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS | ( | dcr, | |
| bits | |||
Interrupts are disabled throughout this operation.
| #define PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS | ( | spr, | |
| bits | |||
| #define PPC_DEVICE_CONTROL_REGISTER | ( | dcr | ) |
The PowerPC 4XX family has Device Control Registers.
| #define PPC_Set_decrementer | ( | _clicks | ) |
| #define PPC_SET_DEVICE_CONTROL_REGISTER | ( | dcr, | |
| val | |||
| #define PPC_SET_DEVICE_CONTROL_REGISTER_BITS | ( | dcr, | |
| bits | |||
| #define PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED | ( | dcr, | |
| bits, | |||
| mask | |||
| #define PPC_SET_SPECIAL_PURPOSE_REGISTER | ( | spr, | |
| val | |||
| #define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS | ( | spr, | |
| bits | |||
| #define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED | ( | spr, | |
| bits, | |||
| mask | |||
| #define PPC_SET_THREAD_MGMT_REGISTER | ( | tmr, | |
| val | |||
| #define PPC_SPECIAL_PURPOSE_REGISTER | ( | spr | ) |
| #define PPC_THREAD_MGMT_REGISTER | ( | tmr | ) |
| #define rtems_bsp_delay | ( | _microseconds | ) |
| #define rtems_bsp_delay_in_bus_cycles | ( | _cycles | ) |
 1.8.15
