22 #ifndef _RTEMS_SCORE_CPU_H    23 #define _RTEMS_SCORE_CPU_H    40 #define RTEMS_USE_32_BIT_OBJECT    53 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE    55 #define CPU_HARDWARE_FP FALSE    57 #define CPU_SOFTWARE_FP FALSE    59 #define CPU_ALL_TASKS_ARE_FP FALSE    61 #define CPU_IDLE_TASK_IS_FP FALSE    63 #define CPU_USE_DEFERRED_FP_SWITCH FALSE    65 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE    78 #define CPU_STACK_GROWS_UP               FALSE    81 #define CPU_CACHE_LINE_BYTES 32    83 #define CPU_STRUCTURE_ALIGNMENT    94 #define CPU_MODES_INTERRUPT_MASK   0x00000001    96 #define CPU_MAXIMUM_PROCESSORS 32   147 #define nogap __attribute__ ((packed))   168 #define _CPU_Context_Get_SP( _context ) \   184 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0   194 #define CPU_INTERRUPT_NUMBER_OF_VECTORS      64   195 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER \   196     (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)   202 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE   212 #define CPU_STACK_MINIMUM_SIZE          (1536)   221 #define CPU_SIZEOF_POINTER         4   231 #define CPU_ALIGNMENT              8   248 #define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT   262 #define CPU_STACK_ALIGNMENT        0   264 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES   273 #define _CPU_Initialize_vectors()   283 #define _CPU_ISR_Disable( _isr_cookie ) \   297 #define _CPU_ISR_Enable( _isr_cookie ) \   299     (_isr_cookie) = (_isr_cookie); \   312 #define _CPU_ISR_Flash( _isr_cookie ) \   314     _CPU_ISR_Enable( _isr_cookie ); \   315     _CPU_ISR_Disable( _isr_cookie ); \   337 #define _CPU_ISR_Set_level( _new_level )        \   339     if (_new_level)   asm volatile ( "nop\n" );         \   340     else              asm volatile ( "nop\n" );         \   374 #define CPU_CCR_INTERRUPTS_ON  0x80   375 #define CPU_CCR_INTERRUPTS_OFF 0x00   377 #define _CPU_Context_Initialize( _the_context, _stack_base, _size, \   378                                  _isr, _entry_point, _is_fp, _tls_area ) \   385     _stack = ((uintptr_t)(_stack_base)) + (_size) - 8;             \   386     *((void (**)(void))(_stack)) = (_entry_point);                 \   388     (_the_context)->fp = (void *)_stack;                           \   389     (_the_context)->sp = (void *)_stack;                           \   406 #define _CPU_Context_Restart_self( _the_context ) \   407    _CPU_Context_restore( (_the_context) );   422 #define _CPU_Fatal_halt( _source, _error ) \   423         printk("Fatal Error %d.%lu Halted\n",_source,_error); \   428 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE   443 typedef void ( *CPU_ISR_handler )( uint32_t );
   447   CPU_ISR_handler  new_handler,
   448   CPU_ISR_handler *old_handler
   493   uint32_t integer_registers [16];
   526 static inline uint32_t   CPU_swap_u32(
   530   uint32_t   byte1, byte2, byte3, byte4, swapped;
   532   byte4 = (value >> 24) & 0xff;
   533   byte3 = (value >> 16) & 0xff;
   534   byte2 = (value >> 8)  & 0xff;
   535   byte1 =  value        & 0xff;
   537   swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
   541 #define CPU_swap_u16( value ) \   542   (((value&0xff) << 8) | ((value >> 8)&0xff))   550 static inline CPU_Counter_ticks _CPU_Counter_difference(
   551   CPU_Counter_ticks second,
   552   CPU_Counter_ticks first
   555   return second - first;
 #define sp
stack-pointer */
Definition: regs.h:64
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define fp
frame-pointer */
Definition: regs.h:65
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
uint32_t special_interrupt_register
Definition: cpu.h:172
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
Interface to Kernel Print Methods.
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
