    RTEMS
    5.1
| struct | Context_Control |
| Thread register context.  More... | |
| struct | CPU_Interrupt_frame |
| Interrupt stack frame (ISF).  More... | |
| struct | CPU_Exception_frame |
| The set of registers that specifies the complete processor state.  More... | |
| #define | RTEMS_USE_32_BIT_OBJECT |
| #define | CPU_SIMPLE_VECTORED_INTERRUPTS TRUE |
| #define | CPU_HARDWARE_FP FALSE |
| #define | CPU_SOFTWARE_FP FALSE |
| #define | CPU_ALL_TASKS_ARE_FP FALSE |
| #define | CPU_IDLE_TASK_IS_FP FALSE |
| #define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
| #define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
| #define | CPU_STACK_GROWS_UP FALSE |
| #define | CPU_CACHE_LINE_BYTES 32 |
| #define | CPU_STRUCTURE_ALIGNMENT |
| #define | CPU_MODES_INTERRUPT_MASK 0x00000001 |
| #define | CPU_MAXIMUM_PROCESSORS 32 |
| #define | nogap __attribute__ ((packed)) |
| #define | _CPU_Context_Get_SP(_context) (_context)->sp |
| #define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
| #define | CPU_INTERRUPT_NUMBER_OF_VECTORS 64 |
| #define | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
| #define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
| #define | CPU_STACK_MINIMUM_SIZE (1536) |
| #define | CPU_SIZEOF_POINTER 4 |
| #define | CPU_ALIGNMENT 8 |
| #define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_STACK_ALIGNMENT 0 |
| #define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
| #define | _CPU_Initialize_vectors() |
| #define | _CPU_ISR_Disable(_isr_cookie) |
| #define | _CPU_ISR_Enable(_isr_cookie) |
| #define | _CPU_ISR_Flash(_isr_cookie) |
| #define | _CPU_ISR_Set_level(_new_level) |
| #define | CPU_CCR_INTERRUPTS_ON 0x80 |
| #define | CPU_CCR_INTERRUPTS_OFF 0x00 |
| #define | _CPU_Context_Initialize(_the_context, _stack_base, _size, _isr, _entry_point, _is_fp, _tls_area) |
| #define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | _CPU_Fatal_halt(_source, _error) |
| #define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
| #define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
Typedefs | |
| typedef void(* | CPU_ISR_handler) (uint32_t) |
| typedef uint32_t | CPU_Counter_ticks |
| typedef uintptr_t | CPU_Uint32ptr |
| RTEMS_INLINE_ROUTINE bool | _CPU_ISR_Is_enabled (uint32_t level) |
| uint32_t | _CPU_ISR_Get_level (void) |
| void | _CPU_Initialize (void) |
| CPU initialization.  More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
| void * | _CPU_Thread_Idle_body (uintptr_t) |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| CPU switch context.  More... | |
| void | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| Prints the exception frame via printk().  More... | |
| uint32_t | _CPU_Counter_frequency (void) |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| #define _CPU_Context_Initialize | ( | _the_context, | |
| _stack_base, | |||
| _size, | |||
| _isr, | |||
| _entry_point, | |||
| _is_fp, | |||
| _tls_area | |||
| #define _CPU_Fatal_halt | ( | _source, | |
| _error | |||
| #define _CPU_ISR_Disable | ( | _isr_cookie | ) |
| #define _CPU_ISR_Enable | ( | _isr_cookie | ) |
| #define _CPU_ISR_Flash | ( | _isr_cookie | ) |
| #define _CPU_ISR_Set_level | ( | _new_level | ) |
| #define CPU_SIZEOF_POINTER 4 |
Size of a pointer.
This must be an integer literal that can be used by the assembler. This value will be used to calculate offsets of structure members. These offsets will be used in assembler code.
| typedef uintptr_t CPU_Uint32ptr |
Type that can store a 32-bit integer or a pointer.
 1.8.15
