44 #ifndef _RTEMS_SCORE_CPU_H    45 #define _RTEMS_SCORE_CPU_H    73 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE    82 #define CPU_ISR_PASSES_FRAME_POINTER TRUE   102 #if ( MIPS_HAS_FPU == 1 )   103 #define CPU_HARDWARE_FP     TRUE   105 #define CPU_HARDWARE_FP     FALSE   128 #define CPU_ALL_TASKS_ARE_FP CPU_HARDWARE_FP   142 #define CPU_IDLE_TASK_IS_FP      FALSE   170 #define CPU_USE_DEFERRED_FP_SWITCH       TRUE   172 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE   183 #define CPU_STACK_GROWS_UP               FALSE   186 #define CPU_CACHE_LINE_BYTES 16   188 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )   196 #define CPU_MODES_INTERRUPT_MASK   0x000000ff   198 #define CPU_SIZEOF_POINTER 4   200 #define CPU_MAXIMUM_PROCESSORS 32   249 #if (__mips == 1) || (__mips == 32)   250 #define __MIPS_REGISTER_TYPE     uint32_t   251 #define __MIPS_FPU_REGISTER_TYPE uint32_t   253 #define __MIPS_REGISTER_TYPE     uint64_t   254 #define __MIPS_FPU_REGISTER_TYPE uint64_t   256 #error "mips register size: unknown architecture level!!"   259     __MIPS_REGISTER_TYPE s0;
   260     __MIPS_REGISTER_TYPE s1;
   261     __MIPS_REGISTER_TYPE s2;
   262     __MIPS_REGISTER_TYPE s3;
   263     __MIPS_REGISTER_TYPE s4;
   264     __MIPS_REGISTER_TYPE s5;
   265     __MIPS_REGISTER_TYPE s6;
   266     __MIPS_REGISTER_TYPE s7;
   267     __MIPS_REGISTER_TYPE
sp;
   268     __MIPS_REGISTER_TYPE
fp;
   269     __MIPS_REGISTER_TYPE
ra;
   270     __MIPS_REGISTER_TYPE c0_sr;
   271     __MIPS_REGISTER_TYPE c0_epc;
   274 #define _CPU_Context_Get_SP( _context ) \   275   (uintptr_t) (_context)->sp   282 #if ( CPU_HARDWARE_FP == TRUE )   283     __MIPS_FPU_REGISTER_TYPE fp0;
   284     __MIPS_FPU_REGISTER_TYPE fp1;
   285     __MIPS_FPU_REGISTER_TYPE fp2;
   286     __MIPS_FPU_REGISTER_TYPE fp3;
   287     __MIPS_FPU_REGISTER_TYPE fp4;
   288     __MIPS_FPU_REGISTER_TYPE fp5;
   289     __MIPS_FPU_REGISTER_TYPE fp6;
   290     __MIPS_FPU_REGISTER_TYPE fp7;
   291     __MIPS_FPU_REGISTER_TYPE fp8;
   292     __MIPS_FPU_REGISTER_TYPE fp9;
   293     __MIPS_FPU_REGISTER_TYPE fp10;
   294     __MIPS_FPU_REGISTER_TYPE fp11;
   295     __MIPS_FPU_REGISTER_TYPE fp12;
   296     __MIPS_FPU_REGISTER_TYPE fp13;
   297     __MIPS_FPU_REGISTER_TYPE fp14;
   298     __MIPS_FPU_REGISTER_TYPE fp15;
   299     __MIPS_FPU_REGISTER_TYPE fp16;
   300     __MIPS_FPU_REGISTER_TYPE fp17;
   301     __MIPS_FPU_REGISTER_TYPE fp18;
   302     __MIPS_FPU_REGISTER_TYPE fp19;
   303     __MIPS_FPU_REGISTER_TYPE fp20;
   304     __MIPS_FPU_REGISTER_TYPE fp21;
   305     __MIPS_FPU_REGISTER_TYPE fp22;
   306     __MIPS_FPU_REGISTER_TYPE fp23;
   307     __MIPS_FPU_REGISTER_TYPE fp24;
   308     __MIPS_FPU_REGISTER_TYPE fp25;
   309     __MIPS_FPU_REGISTER_TYPE fp26;
   310     __MIPS_FPU_REGISTER_TYPE fp27;
   311     __MIPS_FPU_REGISTER_TYPE fp28;
   312     __MIPS_FPU_REGISTER_TYPE fp29;
   313     __MIPS_FPU_REGISTER_TYPE fp30;
   314     __MIPS_FPU_REGISTER_TYPE fp31;
   344   __MIPS_REGISTER_TYPE  r0;
   345   __MIPS_REGISTER_TYPE  at;
   346   __MIPS_REGISTER_TYPE  v0;
   347   __MIPS_REGISTER_TYPE  v1;
   348   __MIPS_REGISTER_TYPE  a0;
   349   __MIPS_REGISTER_TYPE  a1;
   350   __MIPS_REGISTER_TYPE  a2;
   351   __MIPS_REGISTER_TYPE  a3;
   352   __MIPS_REGISTER_TYPE  t0;
   353   __MIPS_REGISTER_TYPE  t1;
   354   __MIPS_REGISTER_TYPE  t2;
   355   __MIPS_REGISTER_TYPE  t3;
   356   __MIPS_REGISTER_TYPE  t4;
   357   __MIPS_REGISTER_TYPE  t5;
   358   __MIPS_REGISTER_TYPE  t6;
   359   __MIPS_REGISTER_TYPE  t7;
   360   __MIPS_REGISTER_TYPE  s0;
   361   __MIPS_REGISTER_TYPE  s1;
   362   __MIPS_REGISTER_TYPE  s2;
   363   __MIPS_REGISTER_TYPE  s3;
   364   __MIPS_REGISTER_TYPE  s4;
   365   __MIPS_REGISTER_TYPE  s5;
   366   __MIPS_REGISTER_TYPE  s6;
   367   __MIPS_REGISTER_TYPE  s7;
   368   __MIPS_REGISTER_TYPE  t8;
   369   __MIPS_REGISTER_TYPE  t9;
   370   __MIPS_REGISTER_TYPE
k0;
   371   __MIPS_REGISTER_TYPE
k1;
   372   __MIPS_REGISTER_TYPE
gp;
   373   __MIPS_REGISTER_TYPE
sp;
   374   __MIPS_REGISTER_TYPE
fp;
   375   __MIPS_REGISTER_TYPE
ra;
   376   __MIPS_REGISTER_TYPE  c0_sr;
   378   __MIPS_REGISTER_TYPE  mdlo;
   379   __MIPS_REGISTER_TYPE  mdhi;
   380   __MIPS_REGISTER_TYPE  badvaddr;
   381   __MIPS_REGISTER_TYPE  cause;
   382   __MIPS_REGISTER_TYPE  epc;
   384   __MIPS_FPU_REGISTER_TYPE f0;
   385   __MIPS_FPU_REGISTER_TYPE f1;
   386   __MIPS_FPU_REGISTER_TYPE f2;
   387   __MIPS_FPU_REGISTER_TYPE f3;
   388   __MIPS_FPU_REGISTER_TYPE f4;
   389   __MIPS_FPU_REGISTER_TYPE f5;
   390   __MIPS_FPU_REGISTER_TYPE f6;
   391   __MIPS_FPU_REGISTER_TYPE f7;
   392   __MIPS_FPU_REGISTER_TYPE f8;
   393   __MIPS_FPU_REGISTER_TYPE f9;
   394   __MIPS_FPU_REGISTER_TYPE f10;
   395   __MIPS_FPU_REGISTER_TYPE f11;
   396   __MIPS_FPU_REGISTER_TYPE f12;
   397   __MIPS_FPU_REGISTER_TYPE f13;
   398   __MIPS_FPU_REGISTER_TYPE f14;
   399   __MIPS_FPU_REGISTER_TYPE f15;
   400   __MIPS_FPU_REGISTER_TYPE f16;
   401   __MIPS_FPU_REGISTER_TYPE f17;
   402   __MIPS_FPU_REGISTER_TYPE f18;
   403   __MIPS_FPU_REGISTER_TYPE f19;
   404   __MIPS_FPU_REGISTER_TYPE f20;
   405   __MIPS_FPU_REGISTER_TYPE f21;
   406   __MIPS_FPU_REGISTER_TYPE f22;
   407   __MIPS_FPU_REGISTER_TYPE f23;
   408   __MIPS_FPU_REGISTER_TYPE f24;
   409   __MIPS_FPU_REGISTER_TYPE f25;
   410   __MIPS_FPU_REGISTER_TYPE f26;
   411   __MIPS_FPU_REGISTER_TYPE f27;
   412   __MIPS_FPU_REGISTER_TYPE f28;
   413   __MIPS_FPU_REGISTER_TYPE f29;
   414   __MIPS_FPU_REGISTER_TYPE f30;
   415   __MIPS_FPU_REGISTER_TYPE f31;
   416   __MIPS_REGISTER_TYPE     fcsr;
   418   __MIPS_REGISTER_TYPE     feir;
   423   __MIPS_REGISTER_TYPE  tlbhi;
   426   __MIPS_REGISTER_TYPE  tlblo;
   429 #if  (__mips == 3) || (__mips == 32)   430   __MIPS_REGISTER_TYPE  tlblo0;
   434   __MIPS_REGISTER_TYPE  inx;
   436   __MIPS_REGISTER_TYPE  rand;
   438   __MIPS_REGISTER_TYPE
ctxt;
   440   __MIPS_REGISTER_TYPE  exctype;
   441   __MIPS_REGISTER_TYPE  mode;
   442   __MIPS_REGISTER_TYPE  prid;
   443   __MIPS_REGISTER_TYPE  tar ;
   445 #if  (__mips == 3) || (__mips == 32)   446   __MIPS_REGISTER_TYPE  tlblo1;
   447   __MIPS_REGISTER_TYPE  pagemask;
   448   __MIPS_REGISTER_TYPE  wired;
   449   __MIPS_REGISTER_TYPE  count;
   450   __MIPS_REGISTER_TYPE  compare;
   451   __MIPS_REGISTER_TYPE
config;
   452   __MIPS_REGISTER_TYPE  lladdr;
   453   __MIPS_REGISTER_TYPE  watchlo;
   454   __MIPS_REGISTER_TYPE  watchhi;
   455   __MIPS_REGISTER_TYPE  ecc;
   456   __MIPS_REGISTER_TYPE  cacheerr;
   457   __MIPS_REGISTER_TYPE  taglo;
   458   __MIPS_REGISTER_TYPE  taghi;
   459   __MIPS_REGISTER_TYPE  errpc;
   460   __MIPS_REGISTER_TYPE  xctxt;
   490 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )   498 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0   505 #define CPU_STACK_MINIMUM_SIZE          (8 * 1024)   512 #define CPU_ALIGNMENT              8   526 #define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT   537 #define CPU_STACK_ALIGNMENT        CPU_ALIGNMENT   539 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES   552 uint32_t mips_interrupt_mask(
void );
   559 #define _CPU_ISR_Disable( _level ) \   561     unsigned int _scratch; \   562     mips_get_sr( _scratch ); \   563     mips_set_sr( _scratch & ~SR_INTERRUPT_ENABLE_BITS ); \   564     _level = _scratch & SR_INTERRUPT_ENABLE_BITS; \   573 #define _CPU_ISR_Enable( _level )  \   575     unsigned int _scratch; \   576     mips_get_sr( _scratch ); \   577     mips_set_sr( (_scratch & ~SR_INTERRUPT_ENABLE_BITS) | (_level & SR_INTERRUPT_ENABLE_BITS) ); \   587 #define _CPU_ISR_Flash( _xlevel ) \   589     unsigned int _scratch2 = _xlevel; \   590     _CPU_ISR_Enable( _scratch2 ); \   591     _CPU_ISR_Disable( _scratch2 ); \   592     _xlevel = _scratch2; \   597   return ( level & SR_INTERRUPT_ENABLE_BITS ) != 0;
   663 #if (__mips == 3) || (__mips == 32)   666 #define _EXTRABITS      SR_FR   672 #define _INTON          SR_IEC   679   uintptr_t        *stack_base,
   698 #define _CPU_Context_Restart_self( _the_context ) \   699    _CPU_Context_restore( (_the_context) );   713 #if ( CPU_HARDWARE_FP == TRUE )   714 #define _CPU_Context_Initialize_fp( _destination ) \   716    *(*(_destination)) = _CPU_Null_fp_context; \   730 #define _CPU_Fatal_halt( _source, _error ) \   732     unsigned int _level; \   733     _CPU_ISR_Disable(_level); \   739 extern void mips_break(
int error );
   741 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE   821 static inline uint32_t CPU_swap_u32(
   825   uint32_t   byte1, byte2, byte3, byte4, swapped;
   827   byte4 = (value >> 24) & 0xff;
   828   byte3 = (value >> 16) & 0xff;
   829   byte2 = (value >> 8)  & 0xff;
   830   byte1 =  value        & 0xff;
   832   swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
   836 #define CPU_swap_u16( value ) \   837   (((value&0xff) << 8) | ((value >> 8)&0xff))   845 static inline CPU_Counter_ticks _CPU_Counter_difference(
   846   CPU_Counter_ticks second,
   847   CPU_Counter_ticks first
   850   return second - first;
 #define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
#define sp
stack-pointer */
Definition: regs.h:64
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:57
Definition: deflate.c:115
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define fp
frame-pointer */
Definition: regs.h:65
#define k0
kernel private register 0 */
Definition: regs.h:61
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
#define k1
kernel private register 1 */
Definition: regs.h:62
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
SPARC basic context.
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
Context_Control_fp _CPU_Null_fp_context
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
#define ra
return address */
Definition: regs.h:66
unsigned size
Definition: tte.h:74
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Information to build RTEMS for a "no cpu" while in protected mode.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
#define gp
global data pointer */
Definition: regs.h:63
