RTEMS  5.1
Modules | Data Structures | Macros | Typedefs | Functions | Variables
MIPS Architecture Support. More...
 CPU Related Definitions
 RTEMS no cpu Build Information
 Register Structure
struct  Context_Control
 Thread register context. More...
struct  Context_Control_fp
 SPARC basic context. More...
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   TRUE
#define CPU_HARDWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   CPU_HARDWARE_FP
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   16
#define CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
#define CPU_MODES_INTERRUPT_MASK   0x000000ff
#define CPU_SIZEOF_POINTER   4
#define CPU_MAXIMUM_PROCESSORS   32
#define _CPU_Context_Get_SP(_context)   (uintptr_t) (_context)->sp
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_STACK_MINIMUM_SIZE   (8 * 1024)
#define CPU_ALIGNMENT   8
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   CPU_ALIGNMENT
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define _CPU_ISR_Disable(_level)
#define _CPU_ISR_Enable(_level)
#define _CPU_ISR_Flash(_xlevel)
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Initialize_fp(_destination)
#define _CPU_Fatal_halt(_source, _error)
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff))
#define CPU_PER_CPU_CONTROL_SIZE   0
typedef CPU_Interrupt_frame CPU_Exception_frame
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
void mips_vector_exceptions (CPU_Interrupt_frame *frame)
uint32_t mips_interrupt_mask (void)
RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled (uint32_t level)
uint32_t _CPU_ISR_Get_level (void)
void _CPU_ISR_Set_level (uint32_t)
 Sets the hardware interrupt level by the level value. More...
void _CPU_Context_Initialize (Context_Control *the_context, uintptr_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
void mips_break (int error)
void _CPU_Initialize (void)
 CPU initialization. More...
void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
RTEMS_INLINE_ROUTINE void _CPU_Context_volatile_clobber (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Context_validate (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal (void)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation (void)
Context_Control_fp _CPU_Null_fp_context
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _destination)
Value:
*(*(_destination)) = _CPU_Null_fp_context; \
◆ _CPU_Fatal_halt
#define _CPU_Fatal_halt (   _source,
  _error
Value:
do { \
unsigned int _level; \
_CPU_ISR_Disable(_level); \
(void)_level; \
loop: goto loop; \
} while (0)
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _level)
Value:
do { \
unsigned int _scratch; \
mips_get_sr( _scratch ); \
mips_set_sr( _scratch & ~SR_INTERRUPT_ENABLE_BITS ); \
_level = _scratch & SR_INTERRUPT_ENABLE_BITS; \
} while(0)
◆ _CPU_ISR_Enable
#define _CPU_ISR_Enable (   _level)
Value:
do { \
mips_set_sr( (_scratch & ~SR_INTERRUPT_ENABLE_BITS) | (_level & SR_INTERRUPT_ENABLE_BITS) ); \
} while(0)
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _xlevel)
Value:
do { \
unsigned int _scratch2 = _xlevel; \
_CPU_ISR_Enable( _scratch2 ); \
_CPU_ISR_Disable( _scratch2 ); \
_xlevel = _scratch2; \
} while(0)
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
◆ _CPU_Context_restore()
void _CPU_Context_restore ( Context_Control *  new_context)
This routine is generally used only to restart self in an efficient manner. It may simply be a label in _CPU_Context_switch.
Parameters
[in]new_contextpoints to the context to be restored.
Note
May be unnecessary to reload some registers.
Port Specific Information:
XXX document implementation including references if appropriate
◆ _CPU_Context_switch()
void _CPU_Context_switch ( Context_Control *  run,
Context_Control *  heir
CPU switch context.
This routine switches from the run context to the heir context.
Parameters
[in]runpoints to the context of the currently executing task
[in]heirpoints to the context of the heir task
◆ _CPU_Exception_frame_print()
void _CPU_Exception_frame_print ( const CPU_Exception_frame *  frame)
See also
rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
◆ _CPU_Initialize()
void _CPU_Initialize ( void  )
CPU initialization.
CPU initialize. This routine performs CPU dependent initialization.
CPU initialization.
◆ _CPU_ISR_Get_level()
uint32_t _CPU_ISR_Get_level ( void  )
Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode.
Note
This routine usually must be implemented as a subroutine.
◆ _CPU_ISR_Set_level()
void _CPU_ISR_Set_level ( uint32_t  new_level)
Parameters
[in]levelfor or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15.
See also
OpenRISC architecture manual.
