RTEMS  5.1
cpu.h
1
12 /*
13  * COPYRIGHT (c) 1989-2011.
14  * On-Line Applications Research Corporation (OAR).
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_SCORE_CPU_H
22 #define _RTEMS_SCORE_CPU_H
23
24 #ifdef __cplusplus
25 extern "C" {
26 #endif
27
28 #include <rtems/score/basedefs.h>
29 #include <rtems/score/m68k.h>
30
31 /* conditional compilation parameters */
32
33 /*
34  * Does the CPU follow the simple vectored interrupt model?
35  *
36  * If TRUE, then RTEMS allocates the vector table it internally manages.
37  * If FALSE, then the BSP is assumed to allocate and manage the vector
38  * table
39  *
40  * M68K Specific Information:
41  *
42  * XXX document implementation including references if appropriate
43  */
44 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
45
46 /*
47  * Does the RTEMS invoke the user's ISR with the vector number and
48  * a pointer to the saved interrupt frame (1) or just the vector
49  * number (0)?
50  */
51
52 #define CPU_ISR_PASSES_FRAME_POINTER FALSE
53
54 /*
55  * Some family members have no FP, some have an FPU such as the
56  * MC68881/MC68882 for the MC68020, others have it built in (MC68030, 040).
57  *
58  * NOTE: If on a CPU without hardware FP, then one can use software
59  * emulation. The gcc software FP emulation code has data which
60  * must be contexted switched on a per task basis.
61  */
62
63 #if ( M68K_HAS_FPU == 1 ) || ( M68K_HAS_EMAC == 1 )
64  #define CPU_HARDWARE_FP TRUE
65  #define CPU_SOFTWARE_FP FALSE
66 #else
67  #define CPU_HARDWARE_FP FALSE
68  #if defined( __GNUC__ )
69  #define CPU_SOFTWARE_FP TRUE
70  #else
71  #define CPU_SOFTWARE_FP FALSE
72  #endif
73 #endif
74
75 /*
76  * All tasks are not by default floating point tasks on this CPU.
77  * The IDLE task does not have a floating point context on this CPU.
78  * It is safe to use the deferred floating point context switch
79  * algorithm on this CPU.
80  */
81
82 #define CPU_ALL_TASKS_ARE_FP FALSE
83 #define CPU_IDLE_TASK_IS_FP FALSE
84 #define CPU_USE_DEFERRED_FP_SWITCH TRUE
85 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
86
87 #define CPU_STACK_GROWS_UP FALSE
88
89 /* FIXME: Is this the right value? */
90 #define CPU_CACHE_LINE_BYTES 16
91
92 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
93
94 #define CPU_MAXIMUM_PROCESSORS 32
95
96 #if ( CPU_HARDWARE_FP == TRUE ) && !defined( __mcoldfire__ )
97  #if defined( __mc68060__ )
98  #define M68K_FP_STATE_SIZE 16
99  #else
100  #define M68K_FP_STATE_SIZE 216
101  #endif
102 #endif
103
104 #ifndef ASM
105
106 /* structures */
107
108 /*
109  * Basic integer context for the m68k family.
110  */
111
112 typedef struct {
113  uint32_t sr; /* (sr) status register */
114  uint32_t d2; /* (d2) data register 2 */
115  uint32_t d3; /* (d3) data register 3 */
116  uint32_t d4; /* (d4) data register 4 */
117  uint32_t d5; /* (d5) data register 5 */
118  uint32_t d6; /* (d6) data register 6 */
119  uint32_t d7; /* (d7) data register 7 */
120  void *a2; /* (a2) address register 2 */
121  void *a3; /* (a3) address register 3 */
122  void *a4; /* (a4) address register 4 */
123  void *a5; /* (a5) address register 5 */
124  void *a6; /* (a6) address register 6 */
125  void *a7_msp; /* (a7) master stack pointer */
126  #if defined( __mcoldfire__ ) && ( M68K_HAS_FPU == 1 )
127  uint8_t fpu_dis;
128  #endif
130
131 #define _CPU_Context_Get_SP( _context ) \
132  (_context)->a7_msp
133
134 /*
135  * Floating point context areas and support routines
136  */
137
138 #if ( CPU_SOFTWARE_FP == TRUE )
139  /*
140  * This is the same as gcc's view of the software FP condition code
141  * register _fpCCR. The implementation of the emulation code is
142  * in the gcc-VERSION/config/m68k directory. This structure is
143  * correct as of gcc 2.7.2.2.
144  */
145  typedef struct {
146  uint16_t _exception_bits;
147  uint16_t _trap_enable_bits;
148  uint16_t _sticky_bits;
149  uint16_t _rounding_mode;
150  uint16_t _format;
151  uint16_t _last_operation;
152  union {
153  float sf;
154  double df;
155  } _operand1;
156  union {
157  float sf;
158  double df;
159  } _operand2;
161
162  #define _CPU_Context_Initialize_fp( _fp_area ) \
163  { \
164  Context_Control_fp *_fp; \
165  _fp = *(Context_Control_fp **)_fp_area; \
166  _fp->_exception_bits = 0; \
167  _fp->_trap_enable_bits = 0; \
168  _fp->_sticky_bits = 0; \
169  _fp->_rounding_mode = 0; /* ROUND_TO_NEAREST */ \
170  _fp->_format = 0; /* NIL */ \
171  _fp->_last_operation = 0; /* NOOP */ \
172  _fp->_operand1.df = 0; \
173  _fp->_operand2.df = 0; \
174  }
175 #endif
176
177 #if ( CPU_HARDWARE_FP == TRUE )
178  #if defined( __mcoldfire__ )
179  /* We need memset() to initialize the FP context */
180  #include <string.h>
181
182  #if ( M68K_HAS_FPU == 1 )
183  /*
184  * The Cache Control Register (CACR) has write-only access. It is also
185  * used to enable and disable the FPU. We need to maintain a copy of
186  * this register to allow per thread values.
187  */
188  extern uint32_t _CPU_cacr_shadow;
189  #endif
190
191  /* We assume that each ColdFire core with a FPU has also an EMAC unit */
192  typedef struct {
193  uint32_t emac_macsr;
194  uint32_t emac_acc0;
195  uint32_t emac_acc1;
196  uint32_t emac_acc2;
197  uint32_t emac_acc3;
198  uint32_t emac_accext01;
199  uint32_t emac_accext23;
200  uint32_t emac_mask;
201  #if ( M68K_HAS_FPU == 1 )
202  uint16_t fp_state_format;
203  uint16_t fp_state_fpcr;
204  double fp_state_op;
205  uint32_t fp_state_fpsr;
206
207  /*
208  * We need to save the FP Instruction Address Register (FPIAR), because
209  * a context switch can occur within a FP exception before the handler
210  * was able to save this register.
211  */
212  uint32_t fp_fpiar;
213
214  double fp_data [8];
215  #endif
217
218  /*
219  * The reset value for all context relevant registers except the FP data
220  * registers is zero. The reset value of the FP data register is NAN. The
221  * restore of the reset FP state will reset the FP data registers, so the
222  * initial value of them can be arbitrary here.
223  */
224  #define _CPU_Context_Initialize_fp( _fp_area ) \
225  memset( *(_fp_area), 0, sizeof( Context_Control_fp ) )
226  #else
227  /*
228  * FP context save area for the M68881/M68882 and 68060 numeric
229  * coprocessors.
230  */
231  typedef struct {
232  /*
233  * M68K_FP_STATE_SIZE bytes for FSAVE/FRESTORE
234  * 96 bytes for FMOVEM FP0-7
235  * 12 bytes for FMOVEM CREGS
236  * 4 bytes for non-null flag
237  */
238  uint8_t fp_save_area [M68K_FP_STATE_SIZE + 112];
240
241  /*
242  * The floating-point context is saved/restored via FSAVE/FRESTORE which
243  * use a growing down stack. Initialize the stack and adjust the FP area
244  * pointer accordingly.
245  */
246  #define _CPU_Context_Initialize_fp( _fp_area ) \
247  { \
248  uint32_t *_fp_context = (uint32_t *) \
249  ( (uintptr_t) *( _fp_area ) + CPU_CONTEXT_FP_SIZE - 4 ); \
250  *(--(_fp_context)) = 0; \
251  *(_fp_area) = (void *)(_fp_context); \
252  }
253  #endif
254 #endif
255
256 /*
257  * The following structures define the set of information saved
258  * on the current stack by RTEMS upon receipt of each exc/interrupt.
259  * These are not used by m68k handlers.
260  * The exception frame is for rdbg.
261  */
262
263 typedef struct {
264  uint32_t vecnum; /* vector number */
266
267 typedef struct {
268  uint32_t vecnum; /* vector number */
269  uint32_t sr; /* status register */
270  uint32_t pc; /* program counter */
271  uint32_t d0, d1, d2, d3, d4, d5, d6, d7;
272  uint32_t a0, a1, a2, a3, a4, a5, a6, a7;
274
275 /* variables */
276
277 extern void* _VBR;
278
279 #endif /* ASM */
280
281 /* constants */
282
283 /*
284  * This defines the number of levels and the mask used to pick those
285  * bits out of a thread mode.
286  */
287
288 #define CPU_MODES_INTERRUPT_MASK 0x00000007 /* interrupt level in mode */
289
290 /*
291  * context size area for floating point
292  */
293
294 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
295
296 /*
297  * extra stack required by the MPCI receive server thread
298  */
299
300 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
301
302 /*
303  * m68k family supports 256 distinct vectors.
304  */
305
306 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 256
307 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
308
309 /*
310  * This is defined if the port has a special way to report the ISR nesting
311  * level. Most ports maintain the variable _ISR_Nest_level.
312  */
313
314 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
315
316 /*
317  * Minimum size of a thread's stack.
318  */
319
320 #define CPU_STACK_MINIMUM_SIZE M68K_CPU_STACK_MINIMUM_SIZE
321
322 /*
323  * Maximum priority of a thread. Note based from 0 which is the idle task.
324  */
325 #define CPU_PRIORITY_MAXIMUM M68K_CPU_PRIORITY_MAXIMUM
326
327 #define CPU_SIZEOF_POINTER 4
328
329 /*
330  * m68k is pretty tolerant of alignment. Just put things on 4 byte boundaries.
331  */
332
333 #define CPU_ALIGNMENT 4
334 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
335
336 /*
337  * On m68k thread stacks require no further alignment after allocation
338  * from the Workspace.
339  */
340
341 #define CPU_STACK_ALIGNMENT 0
342
343 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
344
345 #ifndef ASM
346
347 /* macros */
348
349 /*
350  * ISR handler macros
351  *
352  * These macros perform the following functions:
353  * + initialize the RTEMS vector table
354  * + disable all maskable CPU interrupts
355  * + restore previous interrupt level (enable)
356  * + temporarily restore interrupts (flash)
357  * + set a particular level
358  */
359
360 #define _CPU_Initialize_vectors()
361
362 #define _CPU_ISR_Disable( _level ) \
363  m68k_disable_interrupts( _level )
364
365 #define _CPU_ISR_Enable( _level ) \
366  m68k_enable_interrupts( _level )
367
368 #define _CPU_ISR_Flash( _level ) \
369  m68k_flash_interrupts( _level )
370
371 RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
372 {
373  return ( level & 0x0700 ) == 0;
374 }
375
376 #define _CPU_ISR_Set_level( _newlevel ) \
377  m68k_set_interrupt_level( _newlevel )
378
379 uint32_t _CPU_ISR_Get_level( void );
380
381 /* end of ISR handler macros */
382
383 /*
384  * Context handler macros
385  *
386  * These macros perform the following functions:
387  * + initialize a context area
388  * + restart the current thread
389  * + calculate the initial pointer into a FP context area
390  * + initialize an FP context area
391  */
392
394  Context_Control *the_context,
395  void *stack_area_begin,
396  size_t stack_area_size,
397  uint32_t new_level,
398  void (*entry_point)( void ),
399  bool is_fp,
400  void *tls_area
401 );
402
403 /* end of Context handler macros */
404
405 void *_CPU_Thread_Idle_body( uintptr_t ignored );
406
407 /*
408  * Fatal Error manager macros
409  *
410  * These macros perform the following functions:
411  * + disable interrupts and halt the CPU
412  */
413
414 #if ( defined(__mcoldfire__) )
415 #define _CPU_Fatal_halt( _source, _error ) \
416  { __asm__ volatile( "move.w %%sr,%%d0\n\t" \
417  "or.l %2,%%d0\n\t" \
418  "move.w %%d0,%%sr\n\t" \
419  "move.l %1,%%d0\n\t" \
420  "move.l #0xDEADBEEF,%%d1\n\t" \
421  "halt" \
422  : "=g" (_error) \
423  : "0" (_error), "d"(0x0700) \
424  : "d0", "d1" ); \
425  }
426 #else
427 #define _CPU_Fatal_halt( _source, _error ) \
428  { __asm__ volatile( "movl %0,%%d0; " \
429  "orw #0x0700,%%sr; " \
430  "stop #0x2700" : "=d" ((_error)) : "0" ((_error)) ); \
431  }
432 #endif
433
434 /* end of Fatal Error manager macros */
435
436 /*
437  * Bitfield handler macros
438  *
439  * These macros perform the following functions:
440  * + scan for the highest numbered (MSB) set in a 16 bit bitfield
441  *
442  * NOTE:
443  *
444  * It appears that on the M68020 bitfield are always 32 bits wide
445  * when in a register. This code forces the bitfield to be in
446  * memory (it really always is anyway). This allows us to
447  * have a real 16 bit wide bitfield which operates "correctly."
448  */
449
450 #define CPU_USE_GENERIC_BITFIELD_CODE FALSE
451
452 #if ( M68K_HAS_BFFFO != 1 )
453 /*
454  * Lookup table for BFFFO simulation
455  */
456 extern const unsigned char _CPU_m68k_BFFFO_table[256];
457 #endif
458
459 #if ( M68K_HAS_BFFFO == 1 )
460
461 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
462  __asm__ volatile( "bfffo (%1),#0,#16,%0" : "=d" (_output) : "a" (&_value));
463
464 #elif ( __mcfisaaplus__ )
465  /* This is simplified by the fact that RTEMS never calls it with _value=0 */
466 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
467  __asm__ volatile ( \
468  " swap %0\n" \
469  " ff1.l %0\n" \
470  : "=d" ((_output)) \
471  : "0" ((_value)) \
472  : "cc" ) ;
473
474 #else
475 /* duplicates BFFFO results for 16 bits (i.e., 15-(_priority) in
476  _CPU_Priority_bits_index is not needed), handles the 0 case, and
477  does not molest _value -- jsg */
478 #if ( defined(__mcoldfire__) )
479
480 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
481  { \
482  int dumby; \
483  \
484  __asm__ volatile ( \
485  " clr.l %1\n" \
486  " move.w %2,%1\n" \
487  " lsr.l #8,%1\n" \
488  " beq.s 1f\n" \
489  " move.b (%3,%1),%0\n" \
490  " bra.s 0f\n" \
491  "1: move.w %2,%1\n" \
492  " move.b (%3,%1),%0\n" \
493  " addq.l #8,%0\n" \
494  "0: and.l #0xff,%0\n" \
495  : "=&d" ((_output)), "=&d" ((dumby)) \
496  : "d" ((_value)), "ao" ((_CPU_m68k_BFFFO_table)) \
497  : "cc" ) ; \
498  }
499 #elif ( M68K_HAS_EXTB_L == 1 )
500 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
501  { \
502  int dumby; \
503  \
504  __asm__ volatile ( " move.w %2,%1\n" \
505  " lsr.w #8,%1\n" \
506  " beq.s 1f\n" \
507  " move.b (%3,%1.w),%0\n" \
508  " extb.l %0\n" \
509  " bra.s 0f\n" \
510  "1: moveq.l #8,%0\n" \
511  " add.b (%3,%2.w),%0\n" \
512  "0:\n" \
513  : "=&d" ((_output)), "=&d" ((dumby)) \
514  : "d" ((_value)), "ao" ((_CPU_m68k_BFFFO_table)) \
515  : "cc" ) ; \
516  }
517 #else
518 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
519  { \
520  int dumby; \
521  \
522  __asm__ volatile ( " move.w %2,%1\n" \
523  " lsr.w #8,%1\n" \
524  " beq.s 1f\n" \
525  " move.b (%3,%1.w),%0\n" \
526  " and.l #0x000000ff,%0\n"\
527  " bra.s 0f\n" \
528  "1: moveq.l #8,%0\n" \
529  " add.b (%3,%2.w),%0\n" \
530  "0:\n" \
531  : "=&d" ((_output)), "=&d" ((dumby)) \
532  : "d" ((_value)), "ao" ((_CPU_m68k_BFFFO_table)) \
533  : "cc" ) ; \
534  }
535 #endif
536
537 #endif
538
539 /* end of Bitfield handler macros */
540
541 /*
542  * Priority handler macros
543  *
544  * These macros perform the following functions:
545  * + return a mask with the bit for this major/minor portion of
546  * of thread priority set.
547  * + translate the bit number returned by "Bitfield_find_first_bit"
548  * into an index into the thread ready chain bit maps
549  */
550
551 #define _CPU_Priority_Mask( _bit_number ) \
552  ( 0x8000 >> (_bit_number) )
553
554 #define _CPU_Priority_bits_index( _priority ) \
555  (_priority)
556
557 /* end of Priority handler macros */
558
559 /* functions */
560
561 /*
562  * _CPU_Initialize
563  *
564  * This routine performs CPU dependent initialization.
565  */
566
567 void _CPU_Initialize(void);
568
569 typedef void ( *CPU_ISR_raw_handler )( void );
570
572  uint32_t vector,
573  CPU_ISR_raw_handler new_handler,
574  CPU_ISR_raw_handler *old_handler
575 );
576
577 typedef void ( *CPU_ISR_handler )( uint32_t );
578
580  uint32_t vector,
581  CPU_ISR_handler new_handler,
582  CPU_ISR_handler *old_handler
583 );
584
585 /*
586  * _CPU_Context_switch
587  *
588  * This routine switches from the run context to the heir context.
589  */
590
592  Context_Control *run,
593  Context_Control *heir
594 );
595
597  Context_Control *the_context
599
600 /*
601  * _CPU_Context_save_fp
602  *
603  * This routine saves the floating point context passed to it.
604  */
605
607  Context_Control_fp **fp_context_ptr
608 );
609
610 /*
611  * _CPU_Context_restore_fp
612  *
613  * This routine restores the floating point context passed to it.
614  */
615
617  Context_Control_fp **fp_context_ptr
618 );
619
626  const CPU_Exception_frame *frame
627 );
628
629 typedef uint32_t CPU_Counter_ticks;
630
631 uint32_t _CPU_Counter_frequency( void );
632
633 CPU_Counter_ticks _CPU_Counter_read( void );
634
635 static inline CPU_Counter_ticks _CPU_Counter_difference(
636  CPU_Counter_ticks second,
637  CPU_Counter_ticks first
638 )
639 {
640  return second - first;
641 }
642
643 #if (M68K_HAS_FPSP_PACKAGE == 1)
644 /*
645  * Hooks for the Floating Point Support Package (FPSP) provided by Motorola
646  *
647  * NOTES:
648  *
649  * Motorola 68k family CPU's before the 68040 used a coprocessor
650  * (68881 or 68882) to handle floating point. The 68040 has internal
651  * floating point support -- but *not* the complete support provided by
652  * the 68881 or 68882. The leftover functions are taken care of by the
653  * M68040 Floating Point Support Package. Quoting from the MC68040
654  * Microprocessors User's Manual, Section 9, Floating-Point Unit (MC68040):
655  *
656  * "When used with the M68040FPSP, the MC68040 FPU is fully
657  * compliant with IEEE floating-point standards."
658  *
659  * M68KFPSPInstallExceptionHandlers is in libcpu/m68k/MODEL/fpsp and
660  * is invoked early in the application code to ensure that proper FP
661  * behavior is installed. This is not left to the BSP to call, since
662  * this would force all applications using that BSP to use FPSP which
663  * is not necessarily desirable.
664  *
665  * There is a similar package for the 68060 but RTEMS does not yet
666  * support the 68060.
667  */
668
669 void M68KFPSPInstallExceptionHandlers (void);
670
671 extern int (*_FPSP_install_raw_handler)(
672  uint32_t vector,
673  CPU_ISR_raw_handler new_handler,
674  CPU_ISR_raw_handler *old_handler
675 );
676
677 #endif
678
680 typedef uintptr_t CPU_Uint32ptr;
681
682 #endif
683
684 #ifdef __cplusplus
685 }
686 #endif
687
688 #endif
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
#define _CPU_Context_Restart_self(_the_context)
Definition: cpu.h:480
CPU initialization.
Definition: cpu.c:45
#define pc
pc, used on mips16 */
Definition: regs.h:67
SPARC basic context.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
Motorola M68K CPU Dependent Source.
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
