#define | CPU_SIMPLE_VECTORED_INTERRUPTS TRUE |
#define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 16 |
#define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | M68K_FP_STATE_SIZE 216 |
#define | _CPU_Context_Get_SP(_context) (_context)->a7_msp |
| #define | _CPU_Context_Initialize_fp(_fp_area) |
#define | CPU_MODES_INTERRUPT_MASK 0x00000007 /* interrupt level in mode */ |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024 |
#define | CPU_INTERRUPT_NUMBER_OF_VECTORS 256 |
#define | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE M68K_CPU_STACK_MINIMUM_SIZE |
#define | CPU_PRIORITY_MAXIMUM M68K_CPU_PRIORITY_MAXIMUM |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT 4 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 0 |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | _CPU_Initialize_vectors() |
#define | _CPU_ISR_Disable(_level) m68k_disable_interrupts( _level ) |
#define | _CPU_ISR_Enable(_level) m68k_enable_interrupts( _level ) |
#define | _CPU_ISR_Flash(_level) m68k_flash_interrupts( _level ) |
#define | _CPU_ISR_Set_level(_newlevel) m68k_set_interrupt_level( _newlevel ) |
| #define | _CPU_Fatal_halt(_source, _error) |
#define | CPU_USE_GENERIC_BITFIELD_CODE FALSE |
| #define | _CPU_Bitfield_Find_first_bit(_value, _output) |
#define | _CPU_Priority_Mask(_bit_number) ( 0x8000 >> (_bit_number) ) |
#define | _CPU_Priority_bits_index(_priority) (_priority) |
RTEMS_INLINE_ROUTINE bool | _CPU_ISR_Is_enabled (uint32_t level) |
| uint32_t | _CPU_ISR_Get_level (void) |
| void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| | Initializes the CPU context. More...
void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void | _CPU_Initialize (void) |
| | CPU initialization. More...
void | _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler) |
void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| | CPU switch context. More...
void | _CPU_Context_Restart_self (Context_Control *the_context) RTEMS_NO_RETURN |
void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| | Prints the exception frame via printk(). More...
uint32_t | _CPU_Counter_frequency (void) |
CPU_Counter_ticks | _CPU_Counter_read (void) |
Motorola M68K CPU Dependent Source.
