    RTEMS
    5.1
Input/output module definitions. More...
| struct | lpc176x_module_entry |
| Defines the module entry.  More... | |
Enumerations | |
| enum | lpc176x_pin_function {  LPC176X_PIN_FUNCTION_00, LPC176X_PIN_FUNCTION_01, LPC176X_PIN_FUNCTION_10, LPC176X_PIN_FUNCTION_11, LPC176X_PIN_FUNCTION_COUNT }  |
| Defines the functions according to the pin.  More... | |
| enum | lpc176x_pin_mode {  LPC176X_PIN_MODE_PULLUP, LPC176X_PIN_MODE_REPEATER, LPC176X_PIN_MODE_NONE, LPC176X_PIN_MODE_PULLDOWN, LPC176X_PIN_MODE_COUNT }  |
| Defines the pin modes.  More... | |
| enum | lpc176x_pin_type { LPC176X_PIN_TYPE_DEFAULT, LPC176X_PIN_TYPE_ADC, LPC176X_PIN_TYPE_DAC, LPC176X_PIN_TYPE_OPEN_DRAIN } |
| Defines all type of pins.  More... | |
| enum | lpc176x_scb_value_pclksel { LPC176X_SCB_PCLKSEL0, LPC176X_SCB_PCLKSEL1, LPC176X_SCB_PCLKSEL_COUNT } |
| Represents each pclksel number.  More... | |
| #define LPC176X_IO_INDEX_MAX |
| #define LPC176X_MODULE_ENTRY | ( | mod, | |
| pwr, | |||
| clk, | |||
| idx | |||
| enum lpc176x_pin_function |
Enumerated type to define the set of pin function for a io device.
| enum lpc176x_pin_mode |
| enum lpc176x_pin_type |
Enumerated type to define the set of pin type for a io device.
Enumerated type to define the set of values for a pcklsel.
 1.8.15
