RTEMS  5.1
cpu.h
1
10 /*
11  * COPYRIGHT (c) 1989-2011.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_SCORE_CPU_H
20 #define _RTEMS_SCORE_CPU_H
21
22 #ifndef ASM
23 #include <string.h> /* for memcpy */
24 #endif
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
30 #include <rtems/score/basedefs.h>
31 #if defined(RTEMS_PARAVIRT)
32 #include <rtems/score/paravirt.h>
33 #endif
34 #include <rtems/score/i386.h>
35
45 /* conditional compilation parameters */
46
47 /*
48  * Does the CPU follow the simple vectored interrupt model?
49  *
50  * If TRUE, then RTEMS allocates the vector table it internally manages.
51  * If FALSE, then the BSP is assumed to allocate and manage the vector
52  * table
53  *
54  * PowerPC Specific Information:
55  *
56  * The PowerPC and x86 were the first to use the PIC interrupt model.
57  * They do not use the simple vectored interrupt model.
58  */
59 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
60
61 /*
62  * Does the RTEMS invoke the user's ISR with the vector number and
63  * a pointer to the saved interrupt frame (1) or just the vector
64  * number (0)?
65  */
66
67 #define CPU_ISR_PASSES_FRAME_POINTER FALSE
68
69 /*
70  * Some family members have no FP, some have an FPU such as the i387
71  * for the i386, others have it built in (i486DX, Pentium).
72  */
73
74 #ifdef __SSE__
75 #define CPU_HARDWARE_FP TRUE
76 #define CPU_SOFTWARE_FP FALSE
77
78 #define CPU_ALL_TASKS_ARE_FP TRUE
79 #define CPU_IDLE_TASK_IS_FP TRUE
80 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
81 #else /* __SSE__ */
82
83 #if ( I386_HAS_FPU == 1 )
84 #define CPU_HARDWARE_FP TRUE /* i387 for i386 */
85 #else
86 #define CPU_HARDWARE_FP FALSE
87 #endif
88 #define CPU_SOFTWARE_FP FALSE
89
90 #define CPU_ALL_TASKS_ARE_FP FALSE
91 #define CPU_IDLE_TASK_IS_FP FALSE
92 #if defined(RTEMS_SMP)
93  #define CPU_USE_DEFERRED_FP_SWITCH FALSE
94 #else
95  #define CPU_USE_DEFERRED_FP_SWITCH TRUE
96 #endif
97 #endif /* __SSE__ */
98
99 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
100
101 #define CPU_STACK_GROWS_UP FALSE
102
103 /* FIXME: The Pentium 4 used 128 bytes, it this processor still relevant? */
104 #define CPU_CACHE_LINE_BYTES 64
105
106 #define CPU_STRUCTURE_ALIGNMENT
107
108 #define CPU_MAXIMUM_PROCESSORS 32
109
110 #define I386_CONTEXT_CONTROL_EFLAGS_OFFSET 0
111 #define I386_CONTEXT_CONTROL_ESP_OFFSET 4
112 #define I386_CONTEXT_CONTROL_EBP_OFFSET 8
113 #define I386_CONTEXT_CONTROL_EBX_OFFSET 12
114 #define I386_CONTEXT_CONTROL_ESI_OFFSET 16
115 #define I386_CONTEXT_CONTROL_EDI_OFFSET 20
116 #define I386_CONTEXT_CONTROL_GS_0_OFFSET 24
117 #define I386_CONTEXT_CONTROL_GS_1_OFFSET 28
118 #define I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 32
119
120 #ifdef RTEMS_SMP
121  #define I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 36
122 #endif
123
124 /* structures */
125
126 #ifndef ASM
127
128 /*
129  * Basic integer context for the i386 family.
130  */
131
132 typedef struct {
133  uint32_t eflags; /* extended flags register */
134  void *esp; /* extended stack pointer register */
135  void *ebp; /* extended base pointer register */
136  uint32_t ebx; /* extended bx register */
137  uint32_t esi; /* extended source index register */
138  uint32_t edi; /* extended destination index flags register */
139  segment_descriptors gs; /* gs segment descriptor */
141 #ifdef RTEMS_SMP
142  volatile bool is_executing;
143 #endif
145
146 #define _CPU_Context_Get_SP( _context ) \
147  (_context)->esp
148
149 #ifdef RTEMS_SMP
150  static inline bool _CPU_Context_Get_is_executing(
151  const Context_Control *context
152  )
153  {
154  return context->is_executing;
155  }
156
157  static inline void _CPU_Context_Set_is_executing(
159  bool is_executing
160  )
161  {
162  context->is_executing = is_executing;
163  }
164 #endif
165
166 /*
167  * FP context save area for the i387 numeric coprocessors.
168  */
169 #ifdef __SSE__
170 /* All FPU and SSE registers are volatile; hence, as long
171  * as we are within normally executing C code (including
172  * a task switch) there is no need for saving/restoring
173  * any of those registers.
174  * We must save/restore the full FPU/SSE context across
175  * interrupts and exceptions, however:
176  * - after ISR execution a _Thread_Dispatch() may happen
177  * and it is therefore necessary to save the FPU/SSE
178  * registers to be restored when control is returned
179  * to the interrupted task.
180  * - gcc may implicitly use FPU/SSE instructions in
181  * an ISR.
182  *
183  * Even though there is no explicit mentioning of the FPU
184  * control word in the SYSV ABI (i386) being non-volatile
185  * we maintain MXCSR and the FPU control-word for each task.
186  */
187 typedef struct {
188  uint32_t mxcsr;
189  uint16_t fpucw;
191
192 #else
193
194 typedef struct {
195  uint8_t fp_save_area[108]; /* context size area for I80387 */
196  /* 28 bytes for environment */
198
199 #endif
200
201
202 /*
203  * The following structure defines the set of information saved
204  * on the current stack by RTEMS upon receipt of execptions.
205  *
206  * idtIndex is either the interrupt number or the trap/exception number.
207  * faultCode is the code pushed by the processor on some exceptions.
208  *
209  * Since the first registers are directly pushed by the CPU they
210  * may not respect 16-byte stack alignment, which is, however,
211  * mandatory for the SSE register area.
212  * Therefore, these registers are stored at an aligned address
213  * and a pointer is stored in the CPU_Exception_frame.
214  * If the executive was compiled without SSE support then
215  * this pointer is NULL.
216  */
217
218 struct Context_Control_sse;
219
220 typedef struct {
221  struct Context_Control_sse *fp_ctxt;
222  uint32_t edi;
223  uint32_t esi;
224  uint32_t ebp;
225  uint32_t esp0;
226  uint32_t ebx;
227  uint32_t edx;
228  uint32_t ecx;
229  uint32_t eax;
230  uint32_t idtIndex;
231  uint32_t faultCode;
232  uint32_t eip;
233  uint32_t cs;
234  uint32_t eflags;
236
237 #ifdef __SSE__
238 typedef struct Context_Control_sse {
239  uint16_t fcw;
240  uint16_t fsw;
241  uint8_t ftw;
242  uint8_t res_1;
243  uint16_t fop;
244  uint32_t fpu_ip;
245  uint16_t cs;
246  uint16_t res_2;
247  uint32_t fpu_dp;
248  uint16_t ds;
249  uint16_t res_3;
250  uint32_t mxcsr;
251  uint32_t mxcsr_mask;
252  struct {
253  uint8_t fpreg[10];
254  uint8_t res_4[ 6];
255  } fp_mmregs[8];
256  uint8_t xmmregs[8][16];
257  uint8_t res_5[224];
259 __attribute__((aligned(16)))
260 ;
261 #endif
262
263 typedef void (*cpuExcHandlerType) (CPU_Exception_frame*);
264 extern cpuExcHandlerType _currentExcHandler;
265 extern void rtems_exception_init_mngt(void);
266
267 /*
268  * This port does not pass any frame info to the
269  * interrupt handler.
270  */
271
272 typedef struct {
273 /* allow for 16B alignment (worst case 12 Bytes more) and isr right after pushfl */
274  uint32_t reserved[3];
275 /* registers saved by _ISR_Handler */
276  uint32_t isr_vector;
277  uint32_t ebx;
278  uint32_t ebp;
279  uint32_t esp;
280 /* registers saved by rtems_irq_prologue_##_vector */
281  uint32_t edx;
282  uint32_t ecx;
283  uint32_t eax;
284 /* registers saved by CPU */
285  uint32_t eip;
286  uint32_t cs;
287  uint32_t eflags;
289
290 typedef enum {
291  I386_EXCEPTION_DIVIDE_BY_ZERO = 0,
292  I386_EXCEPTION_DEBUG = 1,
293  I386_EXCEPTION_NMI = 2,
294  I386_EXCEPTION_BREAKPOINT = 3,
295  I386_EXCEPTION_OVERFLOW = 4,
296  I386_EXCEPTION_BOUND = 5,
297  I386_EXCEPTION_ILLEGAL_INSTR = 6,
298  I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7,
299  I386_EXCEPTION_DOUBLE_FAULT = 8,
300  I386_EXCEPTION_I386_COPROC_SEG_ERR = 9,
301  I386_EXCEPTION_INVALID_TSS = 10,
302  I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11,
303  I386_EXCEPTION_STACK_SEGMENT_FAULT = 12,
304  I386_EXCEPTION_GENERAL_PROT_ERR = 13,
305  I386_EXCEPTION_PAGE_FAULT = 14,
306  I386_EXCEPTION_INTEL_RES15 = 15,
307  I386_EXCEPTION_FLOAT_ERROR = 16,
308  I386_EXCEPTION_ALIGN_CHECK = 17,
309  I386_EXCEPTION_MACHINE_CHECK = 18,
310  I386_EXCEPTION_ENTER_RDBG = 50 /* to enter manually RDBG */
311
312 } Intel_symbolic_exception_name;
313
314
315 /*
316  * context size area for floating point
317  *
318  * NOTE: This is out of place on the i386 to avoid a forward reference.
319  */
320
321 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
322
323 /* variables */
324
326
327 #endif /* ASM */
328
329 /* constants */
330
331 /*
332  * This defines the number of levels and the mask used to pick those
333  * bits out of a thread mode.
334  */
335
336 #define CPU_MODES_INTERRUPT_MASK 0x00000001 /* interrupt level in mode */
337
338 /*
339  * extra stack required by the MPCI receive server thread
340  */
341
342 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
343
344 /*
345  * This is defined if the port has a special way to report the ISR nesting
346  * level. Most ports maintain the variable _ISR_Nest_level.
347  */
348
349 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
350
351 /*
352  * Minimum size of a thread's stack.
353  */
354
355 #define CPU_STACK_MINIMUM_SIZE 4096
356
357 #define CPU_SIZEOF_POINTER 4
358
359 /*
360  * i386 is pretty tolerant of alignment. Just put things on 4 byte boundaries.
361  */
362
363 #define CPU_ALIGNMENT 4
364 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
365
366 /*
367  * On i386 thread stacks require no further alignment after allocation
368  * from the Workspace. However, since gcc maintains 16-byte alignment
369  * we try to respect that. If you find an option to let gcc squeeze
370  * the stack more tightly then setting CPU_STACK_ALIGNMENT to 16 still
371  * doesn't waste much space since this only determines the *initial*
372  * alignment.
373  */
374
375 #define CPU_STACK_ALIGNMENT 16
376
377 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
378
379 /* macros */
380
381 #ifndef ASM
382 /*
383  * ISR handler macros
384  *
385  * These macros perform the following functions:
386  * + initialize the RTEMS vector table
387  * + disable all maskable CPU interrupts
388  * + restore previous interrupt level (enable)
389  * + temporarily restore interrupts (flash)
390  * + set a particular level
391  */
392
393 #if !defined(I386_DISABLE_INLINE_ISR_DISABLE_ENABLE)
394 #define _CPU_ISR_Disable( _level ) i386_disable_interrupts( _level )
395
396 #define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
397
398 #define _CPU_ISR_Flash( _level ) i386_flash_interrupts( _level )
399
400 #define _CPU_ISR_Set_level( _new_level ) \
401  { \
402  if ( _new_level ) __asm__ volatile ( "cli" ); \
403  else __asm__ volatile ( "sti" ); \
404  }
405 #else
406 #define _CPU_ISR_Disable( _level ) _level = i386_disable_interrupts()
407 #define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
408 #define _CPU_ISR_Flash( _level ) i386_flash_interrupts( _level )
409 #define _CPU_ISR_Set_level( _new_level ) i386_set_interrupt_level(_new_level)
410 #endif
411
412 RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
413 {
414  return ( level & EFLAGS_INTR_ENABLE ) != 0;
415 }
416
417 uint32_t _CPU_ISR_Get_level( void );
418
419 /* Make sure interrupt stack has space for ISR
420  * 'vector' arg at the top and that it is aligned
421  * properly.
422  */
423
424 #define _CPU_Interrupt_stack_setup( _lo, _hi ) \
425  do { \
426  _hi = (void*)(((uintptr_t)(_hi) - 4) & ~ (CPU_STACK_ALIGNMENT - 1)); \
427  } while (0)
428
429 #endif /* ASM */
430
431 /* end of ISR handler macros */
432
433 /*
434  * Context handler macros
435  *
436  * These macros perform the following functions:
437  * + initialize a context area
438  * + restart the current thread
439  * + calculate the initial pointer into a FP context area
440  * + initialize an FP context area
441  */
442
443 #define CPU_EFLAGS_INTERRUPTS_ON 0x00003202
444 #define CPU_EFLAGS_INTERRUPTS_OFF 0x00003002
445
446 #ifndef ASM
447
449  Context_Control *the_context,
450  void *stack_area_begin,
451  size_t stack_area_size,
452  uint32_t new_level,
453  void (*entry_point)( void ),
454  bool is_fp,
455  void *tls_area
456 );
457
458 #define _CPU_Context_Restart_self( _the_context ) \
459  _CPU_Context_restore( (_the_context) );
460
461 #if defined(RTEMS_SMP)
462  uint32_t _CPU_SMP_Initialize( void );
463
464  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
465
466  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
467
468  void _CPU_SMP_Prepare_start_multitasking( void );
469
470  uint32_t _CPU_SMP_Get_current_processor( void );
471
472  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
473
474  static inline void _CPU_SMP_Processor_event_broadcast( void )
475  {
476  __asm__ volatile ( "" : : : "memory" );
477  }
478
479  static inline void _CPU_SMP_Processor_event_receive( void )
480  {
481  __asm__ volatile ( "" : : : "memory" );
482  }
483 #endif
484
485 #define _CPU_Context_Initialize_fp( _fp_area ) \
486  { \
487  memcpy( *_fp_area, &_CPU_Null_fp_context, CPU_CONTEXT_FP_SIZE ); \
488  }
489
490 /* end of Context handler macros */
491
492 /*
493  * Fatal Error manager macros
494  *
495  * These macros perform the following functions:
496  * + disable interrupts and halt the CPU
497  */
498
499 extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
501
502 #endif /* ASM */
503
504 /* end of Fatal Error manager macros */
505
506 /*
507  * Bitfield handler macros
508  *
509  * These macros perform the following functions:
510  * + scan for the highest numbered (MSB) set in a 16 bit bitfield
511  */
512
513 #define CPU_USE_GENERIC_BITFIELD_CODE FALSE
514
515 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
516  { \
517  uint16_t __value_in_register = ( _value ); \
518  uint16_t __output = 0; \
519  __asm__ volatile ( "bsfw %0,%1 " \
520  : "=r" ( __value_in_register ), "=r" ( __output ) \
521  : "0" ( __value_in_register ), "1" ( __output ) \
522  ); \
523  ( _output ) = __output; \
524  }
525
526 /* end of Bitfield handler macros */
527
528 /*
529  * Priority handler macros
530  *
531  * These macros perform the following functions:
532  * + return a mask with the bit for this major/minor portion of
533  * of thread priority set.
534  * + translate the bit number returned by "Bitfield_find_first_bit"
535  * into an index into the thread ready chain bit maps
536  */
537
538 #define _CPU_Priority_Mask( _bit_number ) \
539  ( 1 << (_bit_number) )
540
541 #define _CPU_Priority_bits_index( _priority ) \
542  (_priority)
543
544 /* functions */
545
546 #ifndef ASM
547 /*
548  * _CPU_Initialize
549  *
550  * This routine performs CPU dependent initialization.
551  */
552
553 void _CPU_Initialize(void);
554
555 typedef void ( *CPU_ISR_handler )( void );
556
558  uint32_t vector,
559  CPU_ISR_handler new_handler,
560  CPU_ISR_handler *old_handler
561 );
562
563 void *_CPU_Thread_Idle_body( uintptr_t ignored );
564
565 /*
566  * _CPU_Context_switch
567  *
568  * This routine switches from the run context to the heir context.
569  */
570
572  Context_Control *run,
573  Context_Control *heir
574 );
575
576 /*
577  * _CPU_Context_restore
578  *
579  * This routine is generally used only to restart self in an
580  * efficient manner and avoid stack conflicts.
581  */
582
584  Context_Control *new_context
586
587 /*
588  * _CPU_Context_save_fp
589  *
590  * This routine saves the floating point context passed to it.
591  */
592
593 #ifdef __SSE__
594 #define _CPU_Context_save_fp(fp_context_pp) \
595  do { \
596  __asm__ __volatile__( \
597  "fstcw %0" \
598  :"=m"((*(fp_context_pp))->fpucw) \
599  ); \
600  __asm__ __volatile__( \
601  "stmxcsr %0" \
602  :"=m"((*(fp_context_pp))->mxcsr) \
603  ); \
604  } while (0)
605 #else
607  Context_Control_fp **fp_context_ptr
608 );
609 #endif
610
611 /*
612  * _CPU_Context_restore_fp
613  *
614  * This routine restores the floating point context passed to it.
615  */
616 #ifdef __SSE__
617 #define _CPU_Context_restore_fp(fp_context_pp) \
618  do { \
619  __asm__ __volatile__( \
620  "fldcw %0" \
621  ::"m"((*(fp_context_pp))->fpucw) \
622  :"fpcr" \
623  ); \
624  __builtin_ia32_ldmxcsr(_Thread_Executing->fp_context->mxcsr); \
625  } while (0)
626 #else
628  Context_Control_fp **fp_context_ptr
629 );
630 #endif
631
632 #ifdef __SSE__
633 #define _CPU_Context_Initialization_at_thread_begin() \
634  do { \
635  __asm__ __volatile__( \
636  "finit" \
637  : \
638  : \
639  :"st","st(1)","st(2)","st(3)", \
640  "st(4)","st(5)","st(6)","st(7)", \
641  "fpsr","fpcr" \
642  ); \
643  if ( _Thread_Executing->fp_context ) { \
644  _CPU_Context_restore_fp(&_Thread_Executing->fp_context); \
645  } \
646  } while (0)
647 #endif
648
650
651 typedef uint32_t CPU_Counter_ticks;
652
653 uint32_t _CPU_Counter_frequency( void );
654
655 CPU_Counter_ticks _CPU_Counter_read( void );
656
657 static inline CPU_Counter_ticks _CPU_Counter_difference(
658  CPU_Counter_ticks second,
659  CPU_Counter_ticks first
660 )
661 {
662  return second - first;
663 }
664
668 typedef uintptr_t CPU_Uint32ptr;
669
670 #endif /* ASM */
671
672 #ifdef __cplusplus
673 }
674 #endif
675
676 #endif
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
uint32_t isr_dispatch_disable
Definition: cpu.h:140
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
Intel I386 CPU Dependent Source.
void _CPU_Fatal_halt(uint32_t source, uint32_t error) RTEMS_NO_RETURN
Definition: bsp_fatal_halt.c:12
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
CPU initialization.
Definition: cpu.c:45
lpc176x_can_isr_vector isr_vector
Vector of isr for the can_driver .
Definition: can.c:37
SPARC basic context.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
Definition: sse_test.c:126
unsigned context
Definition: tlb.h:108
Context_Control_fp _CPU_Null_fp_context
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
