#define  | CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE |
#define  | CPU_ISR_PASSES_FRAME_POINTER   FALSE |
#define  | CPU_HARDWARE_FP   FALSE |
#define  | CPU_SOFTWARE_FP   FALSE |
#define  | CPU_ALL_TASKS_ARE_FP   FALSE |
#define  | CPU_IDLE_TASK_IS_FP   FALSE |
#define  | CPU_USE_DEFERRED_FP_SWITCH   TRUE |
#define  | CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE |
#define  | CPU_STACK_GROWS_UP   FALSE |
#define  | CPU_CACHE_LINE_BYTES   64 |
#define  | CPU_STRUCTURE_ALIGNMENT |
#define  | CPU_MAXIMUM_PROCESSORS   32 |
#define  | I386_CONTEXT_CONTROL_EFLAGS_OFFSET   0 |
#define  | I386_CONTEXT_CONTROL_ESP_OFFSET   4 |
#define  | I386_CONTEXT_CONTROL_EBP_OFFSET   8 |
#define  | I386_CONTEXT_CONTROL_EBX_OFFSET   12 |
#define  | I386_CONTEXT_CONTROL_ESI_OFFSET   16 |
#define  | I386_CONTEXT_CONTROL_EDI_OFFSET   20 |
#define  | I386_CONTEXT_CONTROL_GS_0_OFFSET   24 |
#define  | I386_CONTEXT_CONTROL_GS_1_OFFSET   28 |
#define  | I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE   32 |
#define  | _CPU_Context_Get_SP(_context)   (_context)->esp |
#define  | CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp ) |
#define  | CPU_MODES_INTERRUPT_MASK   0x00000001 /* interrupt level in mode */ |
#define  | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024 |
#define  | CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE |
#define  | CPU_STACK_MINIMUM_SIZE   4096 |
#define  | CPU_SIZEOF_POINTER   4 |
#define  | CPU_ALIGNMENT   4 |
#define  | CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT |
#define  | CPU_STACK_ALIGNMENT   16 |
#define  | CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES |
#define  | _CPU_ISR_Disable(_level)   i386_disable_interrupts( _level ) |
#define  | _CPU_ISR_Enable(_level)   i386_enable_interrupts( _level ) |
#define  | _CPU_ISR_Flash(_level)   i386_flash_interrupts( _level ) |
| #define  | _CPU_ISR_Set_level(_new_level) |
| #define  | _CPU_Interrupt_stack_setup(_lo,  _hi) |
#define  | CPU_EFLAGS_INTERRUPTS_ON   0x00003202 |
#define  | CPU_EFLAGS_INTERRUPTS_OFF   0x00003002 |
#define  | _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) ); |
| #define  | _CPU_Context_Initialize_fp(_fp_area) |
#define  | CPU_USE_GENERIC_BITFIELD_CODE   FALSE |
| #define  | _CPU_Bitfield_Find_first_bit(_value,  _output) |
#define  | _CPU_Priority_Mask(_bit_number)   ( 1 << (_bit_number) ) |
#define  | _CPU_Priority_bits_index(_priority)   (_priority) |
| enum   | Intel_symbolic_exception_name {
  I386_EXCEPTION_DIVIDE_BY_ZERO = 0,
I386_EXCEPTION_DEBUG = 1,
I386_EXCEPTION_NMI = 2,
I386_EXCEPTION_BREAKPOINT = 3,
  I386_EXCEPTION_OVERFLOW = 4,
I386_EXCEPTION_BOUND = 5,
I386_EXCEPTION_ILLEGAL_INSTR = 6,
I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7,
  I386_EXCEPTION_DOUBLE_FAULT = 8,
I386_EXCEPTION_I386_COPROC_SEG_ERR = 9,
I386_EXCEPTION_INVALID_TSS = 10,
I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11,
  I386_EXCEPTION_STACK_SEGMENT_FAULT = 12,
I386_EXCEPTION_GENERAL_PROT_ERR = 13,
I386_EXCEPTION_PAGE_FAULT = 14,
I386_EXCEPTION_INTEL_RES15 = 15,
  I386_EXCEPTION_FLOAT_ERROR = 16,
I386_EXCEPTION_ALIGN_CHECK = 17,
I386_EXCEPTION_MACHINE_CHECK = 18,
I386_EXCEPTION_ENTER_RDBG = 50
void  | rtems_exception_init_mngt (void) |
RTEMS_INLINE_ROUTINE bool  | _CPU_ISR_Is_enabled (uint32_t level) |
| uint32_t  | _CPU_ISR_Get_level (void) |
| void  | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
|   | Initializes the CPU context.  More...
| void  | _CPU_Fatal_halt (uint32_t source, uint32_t error) RTEMS_NO_RETURN |
| void  | _CPU_Initialize (void) |
|   | CPU initialization.  More...
void  | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
void *  | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void  | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
|   | CPU switch context.  More...
| void  | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
void  | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
void  | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
| void  | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
|   | Prints the exception frame via printk().  More...
uint32_t  | _CPU_Counter_frequency (void) |
CPU_Counter_ticks  | _CPU_Counter_read (void) |
Intel I386 CPU Dependent Source.
This include file contains information pertaining to the Intel i386 processor.
