RTEMS  5.1
Modules | Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Block Device Management
 Flash Disk Device
 Generic Disk Device
 RAM Disk Device
 Sparse Disk Device
file  blkdev.h
 Block Device Management.
file  blkdev-blkstats.c
 Block Device Statistics Command.
file  blkdev-ioctl.c
 Common IO Control Primitive.
file  blkdev-ops.c
 Block device management.
file  blkdev-print-stats.c
 Prints the Block Device Statistics.
file  blkdev.c
struct  rtems_blkdev_sg_buffer
 Block device scatter or gather buffer structure. More...
struct  rtems_blkdev_request
 The block device transfer request is used to read or write a number of blocks from or to the device. More...
#define RTEMS_BLKDEV_START_BLOCK(req)   (req->bufs[0].block)
 The start block in a request. More...
typedef enum rtems_blkdev_request_op rtems_blkdev_request_op
 Block device request type. More...
typedef void(* rtems_blkdev_request_cb) (struct rtems_blkdev_request *req, rtems_status_code status)
 Block device request done callback function type.
typedef struct rtems_blkdev_sg_buffer rtems_blkdev_sg_buffer
typedef struct rtems_blkdev_request rtems_blkdev_request
enum  rtems_blkdev_request_op { RTEMS_BLKDEV_REQ_READ, RTEMS_BLKDEV_REQ_WRITE, RTEMS_BLKDEV_REQ_SYNC }
int rtems_blkdev_ioctl (rtems_disk_device *dd, uint32_t req, void *argp)
 Common IO control primitive. More...
rtems_status_code rtems_blkdev_create (const char *device, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, rtems_block_device_ioctl handler, void *driver_data)
 Creates a block device. More...
rtems_status_code rtems_blkdev_create_partition (const char *partition, const char *parent_block_device, rtems_blkdev_bnum media_block_begin, rtems_blkdev_bnum media_block_count)
 Creates a partition within a parent block device. More...
void rtems_blkdev_print_stats (const rtems_blkdev_stats *stats, uint32_t media_block_size, uint32_t media_block_count, uint32_t block_size, const rtems_printer *printer)
 Prints the block device statistics.
void rtems_blkstats (const rtems_printer *printer, const char *device, bool reset)
 Block device statistics command.
IO Control Request Codes
#define RTEMS_BLKIO_REQUEST   _IOWR('B', 1, rtems_blkdev_request)
#define RTEMS_BLKIO_GETMEDIABLKSIZE   _IOR('B', 2, uint32_t)
#define RTEMS_BLKIO_GETBLKSIZE   _IOR('B', 3, uint32_t)
#define RTEMS_BLKIO_SETBLKSIZE   _IOW('B', 4, uint32_t)
#define RTEMS_BLKIO_GETSIZE   _IOR('B', 5, rtems_blkdev_bnum)
#define RTEMS_BLKIO_SYNCDEV   _IO('B', 6)
#define RTEMS_BLKIO_DELETED   _IO('B', 7)
#define RTEMS_BLKIO_CAPABILITIES   _IO('B', 8)
#define RTEMS_BLKIO_GETDISKDEV   _IOR('B', 9, rtems_disk_device *)
#define RTEMS_BLKIO_PURGEDEV   _IO('B', 10)
#define RTEMS_BLKIO_GETDEVSTATS   _IOR('B', 11, rtems_blkdev_stats *)
#define RTEMS_BLKIO_RESETDEVSTATS   _IO('B', 12)
Block Device Driver Capabilities
#define RTEMS_BLKDEV_CAP_MULTISECTOR_CONT   (1 << 0)
 Only consecutive multi-sector buffer requests are supported. More...
#define RTEMS_BLKDEV_CAP_SYNC   (1 << 1)
 The driver will accept a sync call. More...
Interface between device drivers and the block device buffer module.
The heart of the block device driver is the RTEMS_BLKIO_REQUEST IO control. This call puts IO requests to the block device for asynchronous processing. When a driver executes a request, it invokes the request done callback function to finish the request.
◆ RTEMS_BLKDEV_CAP_MULTISECTOR_CONT
This option means the cache will only supply multiple buffers that are inorder so the ATA multi-sector command for example can be used. This is a hack to work around the current ATA driver.
◆ RTEMS_BLKDEV_CAP_SYNC
A sync call is made to a driver after a bdbuf cache sync has finished.
◆ RTEMS_BLKDEV_START_BLOCK
#define RTEMS_BLKDEV_START_BLOCK (   req)    (req->bufs[0].block)
Only valid if the driver has returned the RTEMS_BLKDEV_CAP_MULTISECTOR_CONT capability.
Typedef Documentation
◆ rtems_blkdev_request
Transfer requests are issued to the disk device driver with the RTEMS_BLKIO_REQUEST IO control. The transfer request completion status must be signalled with rtems_blkdev_request_done(). This function must be called exactly once per request. The return value of the IO control will be ignored for transfer requests.
See also
rtems_blkdev_create().
◆ rtems_blkdev_request_op
Warning
The sync request is an IO one and only used from the cache. Use the Block IO when operating at the device level. We need a sync request to avoid requests looping for ever.
Warning
Read the requested blocks of data.
Write the requested blocks of data.
Sync any data with the media.
◆ rtems_blkdev_create()
rtems_status_code rtems_blkdev_create ( const char *  device,
void *  driver_data
The block size is set to the media block size.
Parameters
[in]deviceThe path for the new block device.
[in]media_block_sizeThe media block size in bytes. Must be positive.
[in]media_block_countThe media block count. Must be positive.
[in]handlerThe block device IO control handler. Must not be NULL.
[in]driver_dataThe block device driver data.
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_INVALID_NUMBERMedia block size or count is not positive.
RTEMS_NO_MEMORYNot enough memory.
RTEMS_UNSATISFIEDCannot create generic device node.
RTEMS_INCORRECT_STATECannot initialize bdbuf.
See also
rtems_blkdev_create_partition(), rtems_bdbuf_set_block_size(), and rtems_blkdev_request.
◆ rtems_blkdev_create_partition()
rtems_status_code rtems_blkdev_create_partition ( const char *  partition,
const char *  parent_block_device,
A partition manages a subset of consecutive blocks contained in a parent block device. The blocks must be within the range of blocks managed by the associated parent block device. The media block size and IO control handler are inherited by the parent block device. The block size is set to the media block size.
Parameters
[in]partitionThe path for the new partition device.
[in]parent_block_deviceThe parent block device path.
[in]media_block_beginThe media block begin of the partition within the parent block device.
[in]media_block_countThe media block count of the partition.
Return values
RTEMS_INVALID_IDBlock device node does not exist.
RTEMS_INVALID_NODEFile system node is not a block device.
RTEMS_NOT_IMPLEMENTEDBlock device implementation is incomplete.
RTEMS_INVALID_NUMBERBlock begin or block count is invalid.
See also
rtems_blkdev_create() and rtems_bdbuf_set_block_size().
◆ rtems_blkdev_ioctl()
int rtems_blkdev_ioctl ( rtems_disk_device *  dd,
uint32_t  req,
void *  argp
Use this in all block devices to handle the common set of IO control requests.
