i8259 Chip Support
More...
| file   | i8259.h |
|   | Data structure and functions used to control i8259 chip.
#define  | ISA8259_M_ELCR   0x4d0 |
#define  | ISA8259_S_ELCR   0x4d1 |
#define  | ELCRS_INT15_LVL   0x80 |
#define  | ELCRS_INT14_LVL   0x40 |
#define  | ELCRS_INT13_LVL   0x20 |
#define  | ELCRS_INT12_LVL   0x10 |
#define  | ELCRS_INT11_LVL   0x08 |
#define  | ELCRS_INT10_LVL   0x04 |
#define  | ELCRS_INT9_LVL   0x02 |
#define  | ELCRS_INT8_LVL   0x01 |
#define  | ELCRM_INT7_LVL   0x80 |
#define  | ELCRM_INT6_LVL   0x40 |
#define  | ELCRM_INT5_LVL   0x20 |
#define  | ELCRM_INT4_LVL   0x10 |
#define  | ELCRM_INT3_LVL   0x8 |
#define  | ELCRM_INT2_LVL   0x4 |
#define  | ELCRM_INT1_LVL   0x2 |
#define  | ELCRM_INT0_LVL   0x1 |
#define  | PIC_EOSI   0x60 |
|   | End of Specific Interrupt (EOSI) */.
#define  | SLAVE_PIC_EOSI   0x62 |
|   | End of Specific Interrupt (EOSI) for cascade */.
#define  | PIC_EOI   0x20 |
|   | Generic End of Interrupt (EOI) */.
void  | BSP_i8259s_init (void) |
| int  | BSP_irq_disable_at_i8259s (const rtems_irq_number irqLine) |
|   | function to disable a particular irq at 8259 level.  More...
| int  | BSP_irq_enable_at_i8259s (const rtems_irq_number irqLine) |
|   | function to enable a particular irq at 8259 level.  More...
| int  | BSP_irq_ack_at_i8259s (const rtems_irq_number irqLine) |
|   | function to acknowledge a particular irq at 8259 level.  More...
int  | BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine) |
|   | function to check if a particular irq is enabled at 8259 level.
int  | BSP_i8259s_int_process (void) |
void  | BSP_rtems_irq_mng_init (unsigned cpuId) |
i8259 Chip Support
◆ BSP_irq_ack_at_i8259s()
          | int BSP_irq_ack_at_i8259s  |
          const rtems_irq_number  |
          irqLine | ) |
After calling this function, if a device asserts an enabled interrupt line it will be propagated further to the processor. Mainly useful for people writing raw handlers as this is automagically done for RTEMS managed handlers.
◆ BSP_irq_disable_at_i8259s()
          | int BSP_irq_disable_at_i8259s  |
          irqLine | ) |
After calling this function, even if the device asserts the interrupt line it will not be propagated further to the processor.
- Return values
    | 1 | the interrupt was enabled originally  |
    | 0 | the interrupt was disabled originally  |
    | <0 | error  |
◆ BSP_irq_enable_at_i8259s()
          | int BSP_irq_enable_at_i8259s  |
          irqLine | ) |
After calling this function, if the device asserts the interrupt line it will be propagated further to the processor.
