RTEMS  5.1
Files | Data Structures | Macros | Functions
Simple Priority Scheduler
Simple Priority Scheduler. More...
file  schedulersimple.h
 Manipulation of Threads Simple-Priority-Based Ready Queue.
file  schedulersimpleimpl.h
 Inlined Routines Associated with the Manipulation of the Priority-Based Scheduling Structures.
struct  Scheduler_simple_Context
 Simple scheduler context. More...
#define SCHEDULER_SIMPLE_MAXIMUM_PRIORITY   255
#define SCHEDULER_SIMPLE_ENTRY_POINTS
void _Scheduler_simple_Initialize (const Scheduler_Control *scheduler)
 Initializes simple scheduler. More...
void _Scheduler_simple_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Schedules threads. More...
void _Scheduler_simple_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Performs the yield of a thread. More...
void _Scheduler_simple_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Blocks the thread. More...
void _Scheduler_simple_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Unblocks the thread. More...
void _Scheduler_simple_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Updates the priority of the node. More...
RTEMS_INLINE_ROUTINE Scheduler_simple_Context * _Scheduler_simple_Get_context (const Scheduler_Control *scheduler)
 Gets context of the scheduler. More...
RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Priority_less_equal (const void *to_insert, const Chain_Node *next)
 Checks if the priority is less or equal than the priority of the node. More...
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert (Chain_Control *chain, Thread_Control *to_insert, unsigned int insert_priority)
 Inserts the thread control with the given priority into the chain. More...
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Extract (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Extracts the threads node. More...
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Schedule_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch)
 Scheduling decision logic. More...
◆ SCHEDULER_SIMPLE_ENTRY_POINTS
Value:
_Scheduler_simple_Initialize, /* initialize entry point */ \
_Scheduler_simple_Schedule, /* schedule entry point */ \
_Scheduler_simple_Yield, /* yield entry point */ \
_Scheduler_simple_Block, /* block entry point */ \
_Scheduler_simple_Unblock, /* unblock entry point */ \
_Scheduler_simple_Update_priority, /* update priority entry point */ \
_Scheduler_default_Map_priority, /* map priority entry point */ \
_Scheduler_default_Unmap_priority, /* unmap priority entry point */ \
_Scheduler_default_Node_initialize, /* node initialize entry point */ \
_Scheduler_default_Node_destroy, /* node destroy entry point */ \
_Scheduler_default_Release_job, /* new period of task */ \
_Scheduler_default_Cancel_job, /* cancel period of task */ \
_Scheduler_default_Tick, /* tick entry point */ \
_Scheduler_default_Start_idle /* start idle entry point */ \
SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
void _Scheduler_default_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Performs the scheduler base node initialization.
Definition: schedulerdefaultnodeinit.c:24
Entry points for Scheduler Simple
◆ _Scheduler_simple_Block()
void _Scheduler_simple_Block ( const Scheduler_Control *  scheduler,
Thread_Control *  the_thread,
Scheduler_Node *  node
Blocks the thread.
Parameters
schedulerThe scheduler instance.
[in,out]the_threadThe thread to block.
[in,out]nodeThe thread's scheduler node.
◆ _Scheduler_simple_Extract()
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Extract ( const Scheduler_Control *  scheduler,
Parameters
schedulerThis parameter is unused.
[in,out]the_threadThe thread of which to extract the node out of its chain.
nodeThis parameter is unused.
◆ _Scheduler_simple_Get_context()
RTEMS_INLINE_ROUTINE Scheduler_simple_Context* _Scheduler_simple_Get_context ( const Scheduler_Control *  scheduler)
Parameters
schedulerThe scheduler instance to get the context of.
Returns
The context of scheduler.
◆ _Scheduler_simple_Initialize()
void _Scheduler_simple_Initialize ( const Scheduler_Control *  scheduler)
This routine initializes the simple scheduler.
Parameters
schedulerThe scheduler to be initialized.
◆ _Scheduler_simple_Insert()
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert ( Chain_Control *  chain,
Thread_Control *  to_insert,
Parameters
[in,out]chainThe chain to insert to_insert in.
[in,out]to_insertThe node to insert into chain.
insert_priorityThe priority to insert to_insert with.
◆ _Scheduler_simple_Priority_less_equal()
RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Priority_less_equal ( const void *  to_insert,
const Chain_Node *  next
Parameters
to_insertThe priority to check whether it is less or equal than next.
nextThe Chain node to compare the priority of.
Return values
trueto_insert is smaller or equal than the priority of next.
falseto_insert is greater than the priority of next.
◆ _Scheduler_simple_Schedule()
void _Scheduler_simple_Schedule ( const Scheduler_Control *  scheduler,
Schedules threads.
This routine sets the heir thread to be the next ready thread on the ready queue by getting the first node in the scheduler information.
Parameters
the_threadcausing the scheduling operation.
◆ _Scheduler_simple_Schedule_body()
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Schedule_body ( const Scheduler_Control *  scheduler,
bool  force_dispatch
This kernel routine implements scheduling decision logic for the simple scheduler.
Parameters
[in,out]schedulerThe scheduler instance.
the_threadThis parameter is unused.
force_dispatchIndicates whether the dispatch happens also if the currently executing thread is set as not preemptible.
◆ _Scheduler_simple_Unblock()
void _Scheduler_simple_Unblock ( const Scheduler_Control *  scheduler,
Parameters
[in,out]the_threadThe thread to unblock.
◆ _Scheduler_simple_Update_priority()
void _Scheduler_simple_Update_priority ( const Scheduler_Control *  scheduler,
Parameters
the_threadThe thread for the operation.
◆ _Scheduler_simple_Yield()
void _Scheduler_simple_Yield ( const Scheduler_Control *  scheduler,
Parameters
[in,out]the_threadThe thread that performed the yield operation.
nodeThe scheduler node of the_thread.
