RTEMS  5.1
Files | Data Structures | Macros | Functions
Deterministic Priority Affinity SMP Scheduler
Deterministic Priority Affinity SMP Scheduler. More...
file  schedulerpriorityaffinitysmp.h
 Deterministic Priority Affinity SMP Scheduler API.
file  schedulerpriorityaffinitysmp.c
 Deterministic Priority Affinity SMP Scheduler Implementation.
struct  Scheduler_priority_affinity_SMP_Node
 Scheduler node specialization for Deterministic Priority Affinity SMP schedulers. More...
#define SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS
 Entry points for the Deterministic Priority Affinity SMP Scheduler. More...
void _Scheduler_priority_affinity_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes per thread scheduler information. More...
void _Scheduler_priority_affinity_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Blocks a thread. More...
void _Scheduler_priority_affinity_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Unblocks a thread. More...
void _Scheduler_priority_affinity_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Updates the priority of the node. More...
bool _Scheduler_priority_affinity_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Asks for help. More...
void _Scheduler_priority_affinity_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Reconsiders help. More...
void _Scheduler_priority_affinity_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
 Withdraws node. More...
void _Scheduler_priority_affinity_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle)
 Adds idle to scheduler. More...
Thread_Control * _Scheduler_priority_affinity_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
 Removes an idle thread from the given cpu. More...
bool _Scheduler_priority_affinity_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node, const Processor_mask *affinity)
 Sets affinity for the priority affinity SMP scheduler. More...
This is an extension of the Deterministic Priority SMP Scheduler. which is an implementation of the global fixed priority scheduler (G-FP). It adds thread to core affinity support.
Note
This is the first iteration of this scheduler. It currently tracks the requested affinity to exercise the Scheduler Framework but it does not honor that affinity in assigning threads to cores. This will be added in a subsequent revision.
◆ SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS
Value:
_Scheduler_priority_SMP_Initialize, \
_Scheduler_default_Schedule, \
_Scheduler_priority_SMP_Yield, \
_Scheduler_priority_affinity_SMP_Block, \
_Scheduler_priority_affinity_SMP_Unblock, \
_Scheduler_priority_affinity_SMP_Update_priority, \
_Scheduler_default_Map_priority, \
_Scheduler_default_Unmap_priority, \
_Scheduler_priority_affinity_SMP_Ask_for_help, \
_Scheduler_priority_affinity_SMP_Reconsider_help_request, \
_Scheduler_priority_affinity_SMP_Withdraw_node, \
_Scheduler_default_Pin_or_unpin, \
_Scheduler_priority_affinity_SMP_Add_processor, \
_Scheduler_priority_affinity_SMP_Remove_processor, \
_Scheduler_priority_affinity_SMP_Node_initialize, \
_Scheduler_default_Node_destroy, \
_Scheduler_default_Release_job, \
_Scheduler_default_Cancel_job, \
_Scheduler_default_Tick, \
_Scheduler_SMP_Start_idle, \
_Scheduler_priority_affinity_SMP_Set_affinity \
◆ _Scheduler_priority_affinity_SMP_Add_processor()
void _Scheduler_priority_affinity_SMP_Add_processor ( const Scheduler_Control *  scheduler,
Thread_Control *  idle
Parameters
[in,out]schedulerThe scheduler instance to add the processor to.
idleThe idle thread control.
◆ _Scheduler_priority_affinity_SMP_Ask_for_help()
bool _Scheduler_priority_affinity_SMP_Ask_for_help ( const Scheduler_Control *  scheduler,
Thread_Control *  the_thread,
Scheduler_Node *  node
Asks for help.
Parameters
schedulerThe scheduler instance to ask for help.
the_threadThe thread needing help.
nodeThe scheduler node.
Return values
trueAsk for help was successful.
falseAsk for help was not successful.
◆ _Scheduler_priority_affinity_SMP_Block()
void _Scheduler_priority_affinity_SMP_Block ( const Scheduler_Control *  scheduler,
Thread_Control *  thread,
Blocks a thread.
Parameters
schedulerThe scheduler instance.
[in,out]Thethread to block.
[in,out]nodeThe scheduler node of the thread.
◆ _Scheduler_priority_affinity_SMP_Node_initialize()
void _Scheduler_priority_affinity_SMP_Node_initialize ( const Scheduler_Control *  scheduler,
Scheduler_Node *  node,
This routine allocates thread->scheduler.
Parameters
schedulerPoints to the scheduler specific information.
[in,out]nodeThe node the scheduler is allocating management memory for.
the_threadThe thread of the node.
priorityThe thread priority.
◆ _Scheduler_priority_affinity_SMP_Reconsider_help_request()
void _Scheduler_priority_affinity_SMP_Reconsider_help_request ( const Scheduler_Control *  scheduler,
Reconsiders help.
Parameters
schedulerThe scheduler instance to reconsider the help request.
the_threadThe thread reconsidering a help request.
◆ _Scheduler_priority_affinity_SMP_Remove_processor()
Thread_Control* _Scheduler_priority_affinity_SMP_Remove_processor ( const Scheduler_Control *  scheduler,
struct Per_CPU_Control *  cpu
Parameters
cpuThe cpu control to remove from scheduler.
Returns
The idle thread of the processor.
◆ _Scheduler_priority_affinity_SMP_Set_affinity()
bool _Scheduler_priority_affinity_SMP_Set_affinity ( const Scheduler_Control *  scheduler,
const Processor_mask *  affinity
Parameters
schedulerThe scheduler of the thread.
[in,out]threadThe associated thread.
[in,out]nodeThe scheduler node.
affinityThe new affinity set.
Return values
trueif successful
falseif unsuccessful
◆ _Scheduler_priority_affinity_SMP_Unblock()
void _Scheduler_priority_affinity_SMP_Unblock ( const Scheduler_Control *  scheduler,
Unblocks a thread.
Parameters
[in,out]Thethread to unblock.
◆ _Scheduler_priority_affinity_SMP_Update_priority()
void _Scheduler_priority_affinity_SMP_Update_priority ( const Scheduler_Control *  scheduler,
Parameters
[in,out]Thenode to update the priority of.
◆ _Scheduler_priority_affinity_SMP_Withdraw_node()
void _Scheduler_priority_affinity_SMP_Withdraw_node ( const Scheduler_Control *  scheduler,
Withdraws node.
Parameters
schedulerThe scheduler instance to withdraw the node.
the_threadThe thread using the node.
nodeThe scheduler node to withdraw.
next_stateThe next thread scheduler state in the case the node is scheduled.
