MRM332 Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | CONSOLE_SCI |
#define  | STACK_SIZE   0x800 |
| #define  | RAW_PUTS(str) |
| #define  | RAW_PUTI(n) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
void  | Spurious_Initialize (void) |
void  | _UART_flush (void) |
void  | outbyte (char) |
char  | _etext [] |
char  | _copy_start [] |
char  | _edata [] |
char  | _clear_start [] |
char  | end [] |
bool  | _copy_data_from_rom |
rtems_isr_entry  | M68Kvec [] |
int  | stack_size |
int  | stack_start |
◆ RAW_PUTI
Value:{ \
    register int i, j; \
    RAW_PUTS("0x"); \
    for (i=28;i>=0;i -= 4) { \
      j = (n>>i) & 0xf; \
      SCI_output_char( (j>9 ? j-10+'a' : j+'0') ); \
◆ RAW_PUTS
Value:{ register char *ptr = str; \
    while (*ptr) SCI_output_char(*ptr++); \
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
