    RTEMS
    5.1
Global BSP definitions. More...
#include <bspopts.h>#include <bsp/default-initial-extension.h>#include <rtems.h>#include <rtems/bspIo.h>#include <mrm332.h>Go to the source code of this file.
| #define | CONSOLE_SCI |
| #define | STACK_SIZE 0x800 |
| #define | RAW_PUTS(str) |
| #define | RAW_PUTI(n) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler.  More... | |
| void | Spurious_Initialize (void) |
| void | _UART_flush (void) |
| void | outbyte (char) |
| char | _etext [] |
| char | _copy_start [] |
| char | _edata [] |
| char | _clear_start [] |
| char | end [] |
| bool | _copy_data_from_rom |
| rtems_isr_entry | M68Kvec [] |
| int | stack_size |
| int | stack_start |
 1.8.15
