#define  | BSP_FEATURE_IRQ_EXTENSION |
#define  | UART_CLOCK   48000000 |
#define  | mmio_read(a)   (*(volatile uint32_t *)(a)) |
#define  | mmio_write(a,  v)   (*(volatile uint32_t *)(a) = (v)) |
#define  | mmio_set(a,  v)   mmio_write((a), mmio_read((a)) | (v)) |
#define  | mmio_clear(a,  v)   mmio_write((a), mmio_read((a)) & ~(v)) |
#define  | REG16(x)   (*((volatile uint16_t *)(x))) |
#define  | REG(x)   (*((volatile uint32_t *)(x))) |
#define  | BIT(x)   (0x1 << (x)) |
#define  | BITS(Start,  End)   (((1 << (End+1)) - 1) & ~((1 << (Start)) - 1)) |
#define  | udelay(u)   rtems_task_wake_after(1 + ((u)/rtems_configuration_get_microseconds_per_tick())) |
#define  | __arch_getb(a)   (*(volatile unsigned char *)(a)) |
#define  | __arch_getw(a)   (*(volatile unsigned short *)(a)) |
#define  | __arch_getl(a)   (*(volatile unsigned int *)(a)) |
#define  | __arch_putb(v,  a)   (*(volatile unsigned char *)(a) = (v)) |
#define  | __arch_putw(v,  a)   (*(volatile unsigned short *)(a) = (v)) |
#define  | __arch_putl(v,  a)   (*(volatile unsigned int *)(a) = (v)) |
#define  | writeb(v,  c)   ({ unsigned char  __v = v; __arch_putb(__v,c); __v; }) |
#define  | writew(v,  c)   ({ unsigned short __v = v; __arch_putw(__v,c); __v; }) |
#define  | writel(v,  c)   ({ unsigned int __v = v; __arch_putl(__v,c); __v; }) |
#define  | readb(c)   ({ unsigned char  __v = __arch_getb(c); __v; }) |
#define  | readw(c)   ({ unsigned short __v = __arch_getw(c); __v; }) |
#define  | readl(c)   ({ unsigned int __v = __arch_getl(c); __v; }) |
#define  | SYSTEM_CLOCK_12   12000000 |
#define  | SYSTEM_CLOCK_13   13000000 |
#define  | SYSTEM_CLOCK_192   19200000 |
#define  | SYSTEM_CLOCK_96   96000000 |
#define  | BSP_PRINT_EXCEPTION_CONTEXT   1 |
#define  | BSP_RESET_BOARD_AT_EXIT   1 |
Beaglebone Board Support Package.
