    RTEMS
    5.1
Global BSP definitions. More...
#include <bspopts.h>#include <stdint.h>#include <bsp/start.h>#include <bsp/default-initial-extension.h>#include <bsp/beagleboneblack.h>#include <rtems.h>#include <rtems/irq-extension.h>#include <libcpu/omap3.h>#include <libcpu/am335x.h>Go to the source code of this file.
| struct | beagle_i2c |
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | UART_CLOCK 48000000 |
| #define | mmio_read(a) (*(volatile uint32_t *)(a)) |
| #define | mmio_write(a, v) (*(volatile uint32_t *)(a) = (v)) |
| #define | mmio_set(a, v) mmio_write((a), mmio_read((a)) | (v)) |
| #define | mmio_clear(a, v) mmio_write((a), mmio_read((a)) & ~(v)) |
| #define | REG16(x) (*((volatile uint16_t *)(x))) |
| #define | REG(x) (*((volatile uint32_t *)(x))) |
| #define | BIT(x) (0x1 << (x)) |
| #define | BITS(Start, End) (((1 << (End+1)) - 1) & ~((1 << (Start)) - 1)) |
| #define | udelay(u) rtems_task_wake_after(1 + ((u)/rtems_configuration_get_microseconds_per_tick())) |
| #define | __arch_getb(a) (*(volatile unsigned char *)(a)) |
| #define | __arch_getw(a) (*(volatile unsigned short *)(a)) |
| #define | __arch_getl(a) (*(volatile unsigned int *)(a)) |
| #define | __arch_putb(v, a) (*(volatile unsigned char *)(a) = (v)) |
| #define | __arch_putw(v, a) (*(volatile unsigned short *)(a) = (v)) |
| #define | __arch_putl(v, a) (*(volatile unsigned int *)(a) = (v)) |
| #define | writeb(v, c) ({ unsigned char __v = v; __arch_putb(__v,c); __v; }) |
| #define | writew(v, c) ({ unsigned short __v = v; __arch_putw(__v,c); __v; }) |
| #define | writel(v, c) ({ unsigned int __v = v; __arch_putl(__v,c); __v; }) |
| #define | readb(c) ({ unsigned char __v = __arch_getb(c); __v; }) |
| #define | readw(c) ({ unsigned short __v = __arch_getw(c); __v; }) |
| #define | readl(c) ({ unsigned int __v = __arch_getl(c); __v; }) |
| #define | SYSTEM_CLOCK_12 12000000 |
| #define | SYSTEM_CLOCK_13 13000000 |
| #define | SYSTEM_CLOCK_192 19200000 |
| #define | SYSTEM_CLOCK_96 96000000 |
| #define | BSP_PRINT_EXCEPTION_CONTEXT 1 |
| #define | BSP_RESET_BOARD_AT_EXIT 1 |
| BSP_START_TEXT_SECTION void | beagle_setup_mmu_and_cache (void) |
| Beagleboard specific set up of the MMU.  More... | |
 1.8.15
