27 #ifndef LIBBSP_ARM_BEAGLE_BSP_H    28 #define LIBBSP_ARM_BEAGLE_BSP_H    42 #include <bsp/start.h>    49 #include <libcpu/omap3.h>    50 #include <libcpu/am335x.h>    52 #define BSP_FEATURE_IRQ_EXTENSION    55 #define UART_CLOCK     48000000    58 #define mmio_read(a)    (*(volatile uint32_t *)(a))    59 #define mmio_write(a,v) (*(volatile uint32_t *)(a) = (v))    60 #define mmio_set(a,v)   mmio_write((a), mmio_read((a)) | (v))    61 #define mmio_clear(a,v) mmio_write((a), mmio_read((a)) & ~(v))    63 #define REG16(x)(*((volatile uint16_t *)(x)))    64 #define REG(x)(*((volatile uint32_t *)(x)))    65 #define BIT(x)(0x1 << (x))    67 #define BITS(Start, End) (((1 << (End+1)) - 1) & ~((1 << (Start)) - 1))    69 #define udelay(u) rtems_task_wake_after(1 + ((u)/rtems_configuration_get_microseconds_per_tick()))    73 write32(uint32_t address, uint32_t value)
    79 static inline uint32_t
    80 read32(uint32_t address)
    87 set32(uint32_t address, uint32_t mask, uint32_t value)
    90     val = read32(address);
    94     val |= (value & mask);
    95     write32(address, val);
   100 write16(uint32_t address, uint16_t value)
   102     REG16(address) = value;
   106 static inline uint16_t
   107 read16(uint32_t address)
   109     return REG16(address);
   113 static inline void dsb(
void)
   115     asm volatile(
"dsb" : : :
"memory");
   119 static inline void isb(
void)
   121     asm volatile(
"isb" : : :
"memory");
   125 static inline void flush_data_cache(
void)
   129         "mcr p15, #0, r0, c7, c10, #4\n"   136 #define __arch_getb(a)      (*(volatile unsigned char *)(a))   137 #define __arch_getw(a)      (*(volatile unsigned short *)(a))   138 #define __arch_getl(a)      (*(volatile unsigned int *)(a))   140 #define __arch_putb(v,a)    (*(volatile unsigned char *)(a) = (v))   141 #define __arch_putw(v,a)    (*(volatile unsigned short *)(a) = (v))   142 #define __arch_putl(v,a)    (*(volatile unsigned int *)(a) = (v))   144 #define writeb(v,c) ({ unsigned char  __v = v; __arch_putb(__v,c); __v; })   145 #define writew(v,c) ({ unsigned short __v = v; __arch_putw(__v,c); __v; })   146 #define writel(v,c) ({ unsigned int __v = v; __arch_putl(__v,c); __v; })   148 #define readb(c)  ({ unsigned char  __v = __arch_getb(c); __v; })   149 #define readw(c)  ({ unsigned short __v = __arch_getw(c); __v; })   150 #define readl(c)  ({ unsigned int __v = __arch_getl(c); __v; })   152 #define SYSTEM_CLOCK_12       12000000   153 #define SYSTEM_CLOCK_13       13000000   154 #define SYSTEM_CLOCK_192      19200000   155 #define SYSTEM_CLOCK_96       96000000   157 #if !defined(IS_DM3730) && !defined(IS_AM335X)   158 #error Unrecognized BSP configured.   162 #define BSP_DEVICEMEM_START 0x48000000   163 #define BSP_DEVICEMEM_END   0x5F000000   167 #define BSP_DEVICEMEM_START 0x44000000   168 #define BSP_DEVICEMEM_END   0x57000000   173 #define BSP_CONSOLE_UART        1   174 #define BSP_CONSOLE_UART_BASE   BEAGLE_BASE_UART_1   175 #define BSP_CONSOLE_UART_IRQ    OMAP3_UART1_IRQ   176 #define BEAGLE_BASE_UART_1      0x44E09000   177 #define BEAGLE_BASE_UART_2      0x48022000   178 #define BEAGLE_BASE_UART_3      0x48024000   183 #define BSP_CONSOLE_UART        3   184 #define BSP_CONSOLE_UART_BASE   BEAGLE_BASE_UART_3   185 #define BSP_CONSOLE_UART_IRQ    OMAP3_UART3_IRQ   186 #define BEAGLE_BASE_UART_1      0x4806A000   187 #define BEAGLE_BASE_UART_2      0x4806C000   188 #define BEAGLE_BASE_UART_3      0x49020000   193 #define BSP_GPIO_PIN_COUNT 128   194 #define BSP_GPIO_PINS_PER_BANK 32   198 #define BSP_GPIO_PIN_COUNT 192   199 #define BSP_GPIO_PINS_PER_BANK 32   202 #if BSP_START_COPY_FDT_FROM_U_BOOT   203 #define BSP_FDT_IS_SUPPORTED   224 static inline uint32_t read_sctlr(
void)
   228     asm volatile(
"mrc p15, 0, %[ctl], c1, c0, 0 @ Read SCTLR\n\t"   234 static inline void write_sctlr(uint32_t ctl)
   236     asm volatile(
"mcr p15, 0, %[ctl], c1, c0, 0 @ Write SCTLR\n\t"   237         : : [ctl]
"r" (ctl));
   242 static inline uint32_t read_actlr(
void)
   246     asm volatile(
"mrc p15, 0, %[ctl], c1, c0, 1 @ Read ACTLR\n\t"   252 static inline void write_actlr(uint32_t ctl)
   254     asm volatile(
"mcr p15, 0, %[ctl], c1, c0, 1 @ Write ACTLR\n\t"   255         : : [ctl]
"r" (ctl));
   260 static inline void write_ttbcr(uint32_t bcr)
   262         asm volatile(
"mcr p15, 0, %[bcr], c2, c0, 2 @ Write TTBCR\n\t"   263                         : : [bcr]
"r" (bcr));
   269 static inline uint32_t read_dacr(
void)
   273         asm volatile(
"mrc p15, 0, %[dacr], c3, c0, 0 @ Read DACR\n\t"   274                         : [dacr]
"=r" (dacr));
   281 static inline void write_dacr(uint32_t dacr)
   283         asm volatile(
"mcr p15, 0, %[dacr], c3, c0, 0 @ Write DACR\n\t"   284                         : : [dacr]
"r" (dacr));
   289 static inline void refresh_tlb(
void)
   294     asm volatile(
"mcr p15, 0, %[zero], c8, c7, 0 @ TLBIALL\n\t"   299     asm volatile(
"mcr p15, 0, %[zero], c7, c5, 0"   303     asm volatile(
"mcr p15, 0, %[zero], c7, c5, 6"   311 static inline uint32_t read_ttbr0(
void)
   315     asm volatile(
"mrc p15, 0, %[bar], c2, c0, 0 @ Read TTBR0\n\t"   318     return bar & ARM_TTBR_ADDR_MASK;
   323 static inline uint32_t read_ttbr0_unmasked(
void)
   327     asm volatile(
"mrc p15, 0, %[bar], c2, c0, 0 @ Read TTBR0\n\t"   334 static inline void write_ttbr0(uint32_t bar)
   342     uint32_t
v  =  (bar  & ARM_TTBR_ADDR_MASK ) | ARM_TTBR_FLAGS_CACHED;
   343     asm volatile(
"mcr p15, 0, %[bar], c2, c0, 0 @ Write TTBR0\n\t"   354 #define    BSP_PRINT_EXCEPTION_CONTEXT 1   356 #define    BSP_RESET_BOARD_AT_EXIT 1 DEFAULT_INITIAL_EXTENSION Support.
BeagleBone Black BSP definitions.
Header file for the Interrupt Manager Extension.
BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
Beagleboard specific set up of the MMU.
Definition: bspstartmmu.c:41
unsigned v
Definition: tte.h:73
