RTEMS  5.1
Files | Data Structures | Macros | Functions | Variables
User Extensions Implementation
file  extensiondata.h
 Classic User Extensions Data Structures.
file  extensionimpl.h
 Classic User Extensions Implementation.
struct  Extension_Control
#define EXTENSION_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Extensions objects. More...
RTEMS_INLINE_ROUTINE Extension_Control * _Extension_Allocate (void)
RTEMS_INLINE_ROUTINE void _Extension_Free (Extension_Control *the_extension)
RTEMS_INLINE_ROUTINE Extension_Control * _Extension_Get (Objects_Id id)
Objects_Information _Extension_Information
 The Classic Extensions objects information.
◆ EXTENSION_INFORMATION_DEFINE
#define EXTENSION_INFORMATION_DEFINE (   max)
Value:
_Extension, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_EXTENSIONS, \
max, \
NULL \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:101
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:427
Definition: extensiondata.h:35
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
