RTEMS  5.1
Files | Data Structures | Macros | Functions | Variables
Dual Ported Memory Manager Implementation
file  dpmemdata.h
 Classic Dual Ported Memory Manager Data Structures.
file  dpmemimpl.h
 Dual Ported Memory Manager Implementation.
struct  Dual_ported_memory_Control
#define DUAL_PORTED_MEMORY_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Dual Ported Memory objects. More...
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * _Dual_ported_memory_Allocate (void)
 Allocates a port control block from the inactive chain of free port control blocks. More...
RTEMS_INLINE_ROUTINE void _Dual_ported_memory_Free (Dual_ported_memory_Control *the_port)
 Frees a port control block to the inactive chain of free port control blocks. More...
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * _Dual_ported_memory_Get (Objects_Id id, ISR_lock_Context *lock_context)
Objects_Information _Dual_ported_memory_Information
 The Classic Dual Ported Memory objects information.
◆ DUAL_PORTED_MEMORY_INFORMATION_DEFINE
#define DUAL_PORTED_MEMORY_INFORMATION_DEFINE (   max)
Value:
_Dual_ported_memory, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_PORTS, \
max, \
NULL \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:101
Definition: dpmemdata.h:38
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:427
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
◆ _Dual_ported_memory_Allocate()
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control* _Dual_ported_memory_Allocate ( void  )
This routine allocates a port control block from the inactive chain of free port control blocks.
◆ _Dual_ported_memory_Free()
RTEMS_INLINE_ROUTINE void _Dual_ported_memory_Free ( Dual_ported_memory_Control *  the_port)
This routine frees a port control block to the inactive chain of free port control blocks.
