40   volatile unsigned int data;
    41   volatile unsigned int status;
    42   volatile unsigned int ctrl;
    43   volatile unsigned int scaler;
    48   volatile unsigned int counter;
    50   volatile unsigned int assertion;
    51   volatile unsigned int ack;
    56   volatile unsigned int ilevel;
    57   volatile unsigned int ipend;
    58   volatile unsigned int iforce;
    59   volatile unsigned int iclear;
    60   volatile unsigned int mpstat;
    61   volatile unsigned int bcast;
    62   volatile unsigned int notused02;
    63   volatile unsigned int wdgctrl;
    64   volatile unsigned int ampctrl;
    65   volatile unsigned int icsel[2];
    66   volatile unsigned int notused13;
    67   volatile unsigned int notused20;
    68   volatile unsigned int notused21;
    69   volatile unsigned int notused22;
    70   volatile unsigned int notused23;
    71   volatile unsigned int mask[16];
    72   volatile unsigned int force[16];
    74   volatile unsigned int intid[16];
    76   volatile unsigned int resetaddr[4];
    77   volatile unsigned int resv0[12];
    78   volatile unsigned int pboot;
    79   volatile unsigned int resv1[47];
    80   volatile unsigned int irqmap[8];
    81   volatile unsigned int resv2[824];
    86   volatile unsigned int value;
    87   volatile unsigned int reload;
    88   volatile unsigned int ctrl;
    89   volatile unsigned int notused;
    92 #define GPTIMER_TIMER_CTRL_EN 0x00000001U    93 #define GPTIMER_TIMER_CTRL_RS 0x00000002U    94 #define GPTIMER_TIMER_CTRL_LD 0x00000004U    95 #define GPTIMER_TIMER_CTRL_IE 0x00000008U    96 #define GPTIMER_TIMER_CTRL_IP 0x00000010U    97 #define GPTIMER_TIMER_CTRL_CH 0x00000020U    98 #define GPTIMER_TIMER_CTRL_DH 0x00000040U   102   volatile unsigned int scaler_value;
   103   volatile unsigned int scaler_reload;
   104   volatile unsigned int cfg;
   105   volatile unsigned int notused;
   111   volatile unsigned int data;
   112   volatile unsigned int output;
   113   volatile unsigned int dir;
   114   volatile unsigned int imask;
   115   volatile unsigned int ipol;
   116   volatile unsigned int iedge;
   117   volatile unsigned int bypass;
   118   volatile unsigned int cap;
   119   volatile unsigned int irqmap[4];
   120   volatile unsigned int res_30;
   121   volatile unsigned int res_34;
   122   volatile unsigned int res_38;
   123   volatile unsigned int res_3C;
   124   volatile unsigned int iavail;
   125   volatile unsigned int iflag;
   126   volatile unsigned int res_48;
   127   volatile unsigned int pulse;
   128   volatile unsigned int res_50;
   129   volatile unsigned int output_or;
   130   volatile unsigned int dir_or;
   131   volatile unsigned int imask_or;
   132   volatile unsigned int res_60;
   133   volatile unsigned int output_and;
   134   volatile unsigned int dir_and;
   135   volatile unsigned int imask_and;
   136   volatile unsigned int res_70;
   137   volatile unsigned int output_xor;
   138   volatile unsigned int dir_xor;
   139   volatile unsigned int imask_xor;
   145   volatile unsigned int status;
   146   volatile unsigned int flush_mem_addr;
   147   volatile unsigned int flush_set_index;
   148   volatile unsigned int access_counter;
   149   volatile unsigned int hit_counter;
   150   volatile unsigned int bus_cycle_counter;
   151   volatile unsigned int bus_usage_counter;
   152   volatile unsigned int error_status_control;
   153   volatile unsigned int error_addr;
   154   volatile unsigned int tag_check_bit;
   155   volatile unsigned int data_check_bit;
   156   volatile unsigned int scrub_control_status;
   157   volatile unsigned int scrub_delay;
   158   volatile unsigned int error_injection;
   159   volatile unsigned int access_control;
   160   volatile unsigned int reserved_40[16];
   161   volatile unsigned int mtrr[32];
   162   volatile unsigned int reserved_100[131008];
   163   volatile unsigned int diag_iface_tag[16384];
   164   volatile unsigned int reserved_90000[376832];
   165   volatile unsigned int diag_iface_data[524288];
Definition: intercom.c:74
