volatile unsigned int  | control |
volatile unsigned int  | status |
volatile unsigned int  | flush_mem_addr |
volatile unsigned int  | flush_set_index |
volatile unsigned int  | access_counter |
volatile unsigned int  | hit_counter |
volatile unsigned int  | bus_cycle_counter |
volatile unsigned int  | bus_usage_counter |
volatile unsigned int  | error_status_control |
volatile unsigned int  | error_addr |
volatile unsigned int  | tag_check_bit |
volatile unsigned int  | data_check_bit |
volatile unsigned int  | scrub_control_status |
volatile unsigned int  | scrub_delay |
volatile unsigned int  | error_injection |
volatile unsigned int  | access_control |
volatile unsigned int  | reserved_40 [16] |
volatile unsigned int  | mtrr [32] |
volatile unsigned int  | reserved_100 [131008] |
volatile unsigned int  | diag_iface_tag [16384] |
volatile unsigned int  | reserved_90000 [376832] |
volatile unsigned int  | diag_iface_data [524288] |
