volatile unsigned int  | data |
volatile unsigned int  | output |
volatile unsigned int  | dir |
volatile unsigned int  | imask |
volatile unsigned int  | ipol |
volatile unsigned int  | iedge |
volatile unsigned int  | bypass |
volatile unsigned int  | cap |
volatile unsigned int  | irqmap [4] |
volatile unsigned int  | res_30 |
volatile unsigned int  | res_34 |
volatile unsigned int  | res_38 |
volatile unsigned int  | res_3C |
volatile unsigned int  | iavail |
volatile unsigned int  | iflag |
volatile unsigned int  | res_48 |
volatile unsigned int  | pulse |
volatile unsigned int  | res_50 |
volatile unsigned int  | output_or |
volatile unsigned int  | dir_or |
volatile unsigned int  | imask_or |
volatile unsigned int  | res_60 |
volatile unsigned int  | output_and |
volatile unsigned int  | dir_and |
volatile unsigned int  | imask_and |
volatile unsigned int  | res_70 |
volatile unsigned int  | output_xor |
volatile unsigned int  | dir_xor |
volatile unsigned int  | imask_xor |
