API definitions of the GPIO driver for the lpc176x bsp in RTEMS.
More...
#define  | LPC176X_GPIO_BASE_ADDR   0x40028000U |
#define  | LPC176X_GPIO_INTERRUPT_STATUS   0x40028080U |
| #define  | LPC176X_IOPIN0 |
| #define  | LPC176X_IOSET0 |
| #define  | LPC176X_IODIR0 |
| #define  | LPC176X_IOCLR0 |
| #define  | LPC176X_IOPIN1 |
| #define  | LPC176X_IOSET1 |
| #define  | LPC176X_IODIR1 |
| #define  | LPC176X_IOCLR1 |
| #define  | LPC176X_IO0_INT_EN_R |
| #define  | LPC176X_IO0_INT_EN_F |
| #define  | LPC176X_IO0_INT_STAT_R |
| #define  | LPC176X_IO0_INT_STAT_F |
| #define  | LPC176X_IO0_INT_CLR |
| #define  | LPC176X_IO2_INT_EN_R |
| #define  | LPC176X_IO2_INT_EN_F |
| #define  | LPC176X_IO2_INT_STAT_R |
| #define  | LPC176X_IO2_INT_STAT_F |
| #define  | LPC176X_IO2_INT_CLR |
| #define  | LPC176X_IO_INT_STAT |
#define  | LPC176X_RESERVED_ISR_FUNCT_SIZE   2U |
#define  | LPC176X_RESERVED_ISR_FUNCT_MAX_SIZE   5U |
#define  | LPC176X_MAX_PORT_NUMBER   160U |
#define  | LPC176X_SET_BIT(reg,  pin,  value)   reg = ( reg & ~( 1U << pin ) ) | ( ( value & 1U ) << pin ) |
| #define  | LPC176X_INT_STATUS |
#define  | LPC176X_INT_STATUS_P0   1U |
#define  | LPC176X_INT_STATUS_P2   ( 1U << 2U ) |
#define  | LPC176X_INT_ENABLE   1U |
#define  | LPC176X_INT_DISABLE   0U |
#define  | LPC176X_IRQ_EINT_3   21U |
#define  | LPC176X_PIN_BIT(pin)   ( 1U << pin ) |
| enum   | lpc176x_gpio_direction { LPC176X_GPIO_FUNCTION_INPUT,
LPC176X_GPIO_FUNCTION_OUTPUT,
LPC176X_GPIO_FUNCTION_COUNT
|   | The direction of the GPIO port (input or output).  More...
| enum   | lpc176x_gpio_interrupt {
  LPC176X_GPIO_INTERRUPT_DISABLE,
LPC176X_GPIO_INTERRUPT_RISING,
LPC176X_GPIO_INTERRUPT_FALLING,
LPC176X_GPIO_INTERRUPT_BOTH,
  LPC176X_GPIO_INTERRUPT_COUNT
|   | The interrupt sources edge for a GPIO.  More...
| enum   | lpc176x_gpio_ports {
  LPC176X_GPIO_PORT_0,
LPC176X_GPIO_PORT_1,
LPC176X_GPIO_PORT_2,
LPC176X_GPIO_PORT_3,
  LPC176X_GPIO_PORT_4,
LPC176X_GPIO_PORTS_COUNT
|   | The ports for a GPIO.  More...
| enum   | lpc176x_gpio_address {
  LPC176X_FIO0_BASE_ADDRESS = 0x2009C000U,
LPC176X_FIO1_BASE_ADDRESS = 0x2009C020U,
LPC176X_FIO2_BASE_ADDRESS = 0x2009C040U,
LPC176X_FIO3_BASE_ADDRESS = 0x2009C060U,
  LPC176X_FIO4_BASE_ADDRESS = 0x2009C080U
|   | Addresses for a GPIO.  More...
| enum   | lpc176x_interrupt_address { LPC176X_IO0_INT_BASE_ADDRESS = 0x40028084U,
LPC176X_IO2_INT_BASE_ADDRESS = 0x400280A4U
|   | Addresses for the two interrupts.  More...
◆ LPC176X_INT_STATUS
          | #define LPC176X_INT_STATUS |
Value:( *(volatile uint32_t *) \
                             ( LPC176X_GPIO_INTERRUPT_STATUS ) )
◆ LPC176X_IO0_INT_CLR
          | #define LPC176X_IO0_INT_CLR |
Value:( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \
                                                       + 0x8CU ) )
◆ LPC176X_IO0_INT_EN_F
          | #define LPC176X_IO0_INT_EN_F |
                                                        + 0x94U ) )
◆ LPC176X_IO0_INT_EN_R
          | #define LPC176X_IO0_INT_EN_R |
                                                        + 0x90U ) )
◆ LPC176X_IO0_INT_STAT_F
          | #define LPC176X_IO0_INT_STAT_F |
Value:( *(volatile uint32_t *) ( \
                                   + 0x88U ) )
◆ LPC176X_IO0_INT_STAT_R
          | #define LPC176X_IO0_INT_STAT_R |
                                   + 0x84U ) )
◆ LPC176X_IO2_INT_CLR
          | #define LPC176X_IO2_INT_CLR |
                                                       + 0xACU ) )
◆ LPC176X_IO2_INT_EN_F
          | #define LPC176X_IO2_INT_EN_F |
                                                        + 0xB4U ) )
◆ LPC176X_IO2_INT_EN_R
          | #define LPC176X_IO2_INT_EN_R |
                                                        + 0xB0U ) )
◆ LPC176X_IO2_INT_STAT_F
          | #define LPC176X_IO2_INT_STAT_F |
                                   + 0xA8U ) )
◆ LPC176X_IO2_INT_STAT_R
          | #define LPC176X_IO2_INT_STAT_R |
                                   + 0xA4U ) )
◆ LPC176X_IO_INT_STAT
          | #define LPC176X_IO_INT_STAT |
                                                       + 0x80U ) )
◆ LPC176X_IOCLR0
Value:( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \
                                                  0x0CU ) )
◆ LPC176X_IOCLR1
                                                  0x1CU ) )
◆ LPC176X_IODIR0
                                                  0x08U ) )
◆ LPC176X_IODIR1
                                                  0x18U ) )
◆ LPC176X_IOPIN0
                                                  0x00U ) )
◆ LPC176X_IOPIN1
                                                  0x10U ) )
◆ LPC176X_IOSET0
                                                  0x04U ) )
◆ LPC176X_IOSET1
                                                  0x14U ) )
◆ lpc176x_gpio_interrupt_function
A function that attends an interrupt for GPIO.
- Parameters
    | pin | Pin number.  |
    | edge | Interrupt.  |
- Returns
 - Pointer to the interrupt function.
◆ lpc176x_gpio_address
Enumerated type to define the set of fio bases addresses for a gpio device.
◆ lpc176x_gpio_direction
Enumerated type to define the set of function types for a gpio device.
Enumerated type to define the set of interrupt types for a gpio device.
◆ lpc176x_gpio_ports
Enumerated type to define the set of ports for a gpio device.
◆ lpc176x_interrupt_address
Enumerated type to define the set of interrupt addresses for a gpio device.
